February MOM Contest
Welcome to February's Model of the Month contest!
The February Dragon Model of the Month contest is open for entries.
Please also take a moment to read through the rules, regarding bases, structures and figures.
All models finished during the month of February are elligible.
the rules
Submissions follow the rules as follows:
1. The model should be a recent one that you have completed in the past few months, ideally in the month the contest is running. This rule is based on an honour system and we hope everyone will comply with it. More than one entry per user is permitted provided the models completed comply with this criteria. Please do not submit a model to the contest more than once. The winner of the previous month's contest is not eligible to win the current contest, but is not prohibited from entering.
2. The photos should be of a single aicrcraft-related model against a plain background (white or Blue preferred, but other neutral colours are acceptable. If your model is painted in light colours then a darker background is preferable) not attached to any base or with any figures. If the model is built gear-up, it may be displayed on a simple stand. It must be clearly marked as your entry with the photo titled "Contest Entry (month)" with the month replaced by the name of the month you are entering i.e. January for January etc. Do not include watermarks, text or any other identifying features in the pictures. The contest photo should be as anonymous as possible in order to avoid any appearance of outside influence.
b. Your full name
c. Date the photo was taken
a. Your full name
b. Your shipping address (for prize fulfilment)
c. Your KitMaker username
e. Your preferred contest entry photo.
If you do not indicate an entry, Jessica will choose one which may not be your favourite.
About Is a secret (Jessie_C)
The supply of round tuits has arrived, and with them, some entries.
FEB 10, 2015 - 05:53 AM
A fresh entry has come in.
FEB 12, 2015 - 06:24 AM
