2014 Model of the Year
history
The Roland D.VI was a German fighter aircraft built at the end of World War I. It lost a fly-off to the Fokker D.VII, but production went ahead anyway as insurance against problems with the Fokker.
In January 1918, two D.VIs were entered into the first fighter competition held by Idflieg at Adlershof, one powered by a 160 hp (119 kW) Mercedes D.III engine and the other by a Benz Bz.IIIa of similar power and, like the Mercedes, another upright, inline, six cylinder engine . Although the winner of the competition was the Fokker D.VII, orders were placed for the Roland as insurance against production problems with the Fokker.
A total of 350 were built, 150 D.VIas powered by the Mercedes, while the remaining 200 were powered by the Benz and were called D.VIb. Deliveries started in May 1918, with 70 D.VIs in frontline service on 31 August 1918.
The only surviving artifact of the LFG Roland D.VI still existing in the 21st century is the complete fuselage of a D.VIb, displaying IdFlieg military serial number 2225/18, on display at the Polish Aviation Museum in Kraków, Poland.
the model
Well, in my article I described briefly the build, and as some of you wanted to know more about my technique of painting the wood grain, here are some details: It was not the first time for me to paint wood grain by hand, as I built several ww1 models before - the last one being the Austro-Hungarian seaplane Hansa-Brandenburg CC in 1/48 scale - but the Roland had a very light toned wooden fuselage so it was a great challenge te represent it correctly. I must admit that although I admire products such as Uschi's wood grain decals, I decided to paint the wood grain by hand, just to prove that I can do it at least as good.
To the contrary of other modelers who use acrylic or enamel paints for this job, I chose water based tempera colours, primarily because I was affraid of failing to achieve realistic effects. Tempera could be easily removed with a soft cloth and a bit of water, and the process could be restarted without fear of damaging the model forever. I am also an artist (I produce box covers for Revell) and work with tempera is familiar to me so I was pretty assured that the experiment will end up happily.
It is important for tempera work that the surface is first sprayed with very flat acrylic or enamel base coat - satin or clear shiny finish will make the diluted tempera to "run away" and it would be impossible to paint. So, after the light sand colored base coat has dried, I prepared several shades of brown tempera diluted with water so that it can be easily painted by sharp pointed brush of 0, 00 and 000 sizes. Each plank was then painted by hand taking care to change grain patterns. I simply looked at the photos of the real machine in WNW superb instruction sheet, but I also looked to the wooden floor in my dining room, trying to represent similar patterns. For the zig-zag joints which must be clearly visible on the planks, I made some masks from Tamiya tape cut by a very sharp scalpel knife, and once masked they were painted with airbrush using lighter and darker shades of brown. This didn't turn very well, so I had to correct every such joint with some dark paint and a 000 brush. At first the painted wood grain looked a bit too contrasting in respect to the base coat, but I didn't worry too much about that because I intended to tone down the complete wooden surface with successive coats of satin varnish.
I advise you to wear thin latex gloves while handling the fuselage during the wood grain painting process, to prevent that you accidentally wipe away all that lovely wood detail with your wet fingers before applying the protective varnish. After the painting of the wood grain structure, I sprayed several protective layers of acrylic transparent paint, all of them being very diluted in order to retain the fine surface details such as nail holes. I added a few drops of reddish brown flat paint in the first layer of flat transparent coat so that after spraying, it effectively toned down the contrast between the base coat and painted wood grain structure. The last layer was a satin one and it effectively protected the fuselage during subsequent building work on the model.
I was quite satisfied with my model, my only regret was that I didn't leave that nice engine opened.
About DANIJEL FRKA (frka11)
Would you honour us with a step by step write up with photos? I don't quite get it.. Just on sheet styrene or such. We already know you can handle a camera!
JAN 03, 2015 - 05:50 AM
Great model. Congratulation !!!
JAN 03, 2015 - 04:24 PM
Nicely done!
JAN 04, 2015 - 09:09 PM
Beautifully done, the wood grain and detail are spectacular! Nice to see an Early Aviation subject Model of the Year. Cheers, Lance
JAN 24, 2015 - 06:36 PM
