135
Luft 46 Colours Part 3: Fighters & Ground-Attack Aircraft
FOREWORD
I noticed I missed off the mixes for RLM 80, Olive Green in the colour charts in Part 2 so I have included these in the first picture including those with RLM 76 Hellblau, RLM 21 White and RLM 22 Black.
THE EXPERIMENT PHASE 2
Following the first phase where I mixed percentages of RLM 76 and again with RLM 21 White to standard late war RLM shades, I did exactly the same but this time based on RLM 22 Black. The results have again proved interesting, although not as many useful colours emerged due to the obvious darkening power of black. But it can be seen that new colours, derived from mixing to eke out supplies of paint, might have been produced.
Naturally, lighter shades took more set percentage steps before the power of black made them too dark than the already dark colours.
The amazing thing is that many shades seem to retain a definite Luftwaffe feel and look as though they belong to the family of official RLM colours. Maybe this familiarity is due to so many variations used in real life due to the criteria already discussed in Parts 1 and 2. It lends definite, if circumstantial, evidence that many colours reported to have been seen did exist. I suppose that is the crux of this experiment after all....to show what might have been distinctly possible due to the circumstances under which paint would have been used and applied at the time.
When doing Luft 46 aircraft models, it seems there are a massive number of shades that one might adapt to suit any particular role or theatre of operations, all derived from official stocks.
I am modifying my view due to the results so far. Previously I preferred using standard RLM’s to try and give any particular model a sense of reality. But now I am swinging round to accepting “rogue “ colours as a possible and distinctive alternative.
INSPIRATION
We are not only exploring colour possibilities, but I also think it worth mentioning also patterns. If one considers the ultimate master of camouflage is Mother Nature, we need look no further for inspiration. I’m not saying an aircraft should be painted exactly like a tiger but influences can be applied effectively.
(Note: Recently you may have noticed a news item featuring Gekko Graphics decals for the Fw Ta183. Here you will find some examples were nature has been used as a major influence).
I realise I have set myself an impossible yet intriguing task, as the variations from mixing official RLM colours is infinite. However, I am now convinced that it was more than probable ground crews did in fact resort to similar methods with parallel results. And so far I have only made both lighter and darker shades.
A whole new world of colours awaits the 3rd phase of this experiment, mixing the shades other than Hellblau, White and Black with each other. It will be, I hope, interesting to see what the results will be from mixing, for example, RLM 81 Brownviolet to RLM 82 Bright Green.
PROFILE NOTES
The Ju “Warthog” was an unnamed project that historians and researchers have nicknamed after the current day A10, due to its remarkable similarities in layout, concept and role. The original design had a retractable landing skid under the nose, but I thought this would have soon been replaced by a nose wheel if it had made prototype or production stages and have done the profiles to suit.
COMING SOON
I have already started Part 4 based on a great idea of Rowan’s (Merlin). Basically the theme will be Naval Aircraft, both shore based and carrier-borne. The foundation being what if the Graph Zeppelin had been completed, along with other carriers and what colour/camo schemes might have been adopted and what Luft 46 aircraft might have taken off from their decks?
  • MEP_1100_FRAMED_SET_
  • MEP_1099_FRAME_SET_
  • JU_EF_WARTHOG_FRAME_SET
  • JU_EF_112_FRAME_SET
  • BV_193_FRAMED_SET
  • BV_178_FRAMED_SET
  • Black_mix_2
  • OLIVE_MIX1
About Peter Allen (flitzer)
Greetings to all. My real name is Peter Allen and I have recently returned to UK from working in Riyadh, Saudi Arabia, as a creative director in an advertising agency. My home town is Wigan in the north of England. I’m married to Emily, a Polish lass who tolerates my modelling well. I’ve wor...
RLM is the abreviation of Reichluftministerium, the German Air Ministry and in charge of all things aviation during WWII. The prefice RLM is equivalent to FS with US colour codes.
NOV 15, 2004 - 07:10 AM
Superb as usual. I Have question, Peter but on something slightly different. Do you have any thoughts on the likely camouflage that could have been used if the Germans had managed to carry out their planned attack on the US continent? I'm thinking more about the "fighter escort", cos my plan, if feasable, is to complete my Ta 183 as just this What do you think? I'm planning on adding the kit drop tank and replacing 2 of the missiles with 2 more? I would really like to do a spectacular camouflage pattern :-) Mal
NOV 15, 2004 - 08:23 AM
Hi again! Thank u for answering my question but I was still wondering how u managed to get the list of all RLM colours and actually apply them to ur models?
NOV 29, 2004 - 10:33 AM
Model Master and Gunze paints are available in RLM shades. Just check the label!
NOV 29, 2004 - 02:29 PM
Hi Mal...oh psychic one I was on holiday when this was posted...and I nearly missed it. I'm in the middle of doing bombers (part 5) and will be doing a few long range camo schemes with this in mind. High altitude over mostly water.... I'm also doing a Fighters revisited set too. Cheers Peter :-)
NOV 29, 2004 - 05:47 PM
Peter, Stop doing this.... I am not, nor ever will, nor have any intention of getting into Luft '46 - ever!! Emm, when are you doing Part IV?...Jim :-)
NOV 29, 2004 - 08:55 PM
Hi Jim... Soon....soon...don't worry Jim I'll give you advance warning then you can look the other way... :-) don't want you catching Luft46itis... :-) Cheers Peter
NOV 30, 2004 - 12:55 AM
I'm with you Jim, not even slightly interested, Luft 46 .......................errr....... whats that Mal
NOV 30, 2004 - 07:41 AM
Mal, these guys have got it wrong. Where it is... Is 'Luft '47 ,,,Jim :-)
NOV 30, 2004 - 10:04 AM
Hello! Thanks for the reference, I will be on the look out for those colours!
DEC 02, 2004 - 06:51 AM
