135
Focke Wulf Fw 190 F-1
Introduction
I built this model for the Down Low campaign. As it is very similar to the A-4, I decided to build both kits parallel, so you find most of the hints will be true for both kits and you'll see some pictures with both models shown. In general the Fw 190 F-1 is just a Fw 190 A-4 which was used differently. The outboard MG FF are optional also for fighters and could be fitted or not (feldmäßig = by front line unit). I intended to show a little difference with the camouflage; The Fw 190 F-1 and A-4 would be both painted in 74/75/76 camo, but I'd try to achieve a more dusted and faded look on the Tunisian machine and a glossy Kommodore aircraft for the other. The F-1 would be done with the kit decals (Tunisia, III./SKG 10), while the Fw 190 A-4 would be as deployed with JG 101 in Pau (France).
Construction
The Hasegawa kit is quite easy to build and I decided not to add much after market stuff - just the seat belts (Eduard) and a 500kg bomb for the fighter bomber.
First I put the wings together. The F-1 has no outer wing weapons but a bomb rack, while the A-4 has the MG FF (maybe it would also get the rack for a fuel tank later). (Picture 1). I sprayed the cockpit tub and all other necessary parts RLM 66 and added some detail painting with Citadel acrylics. (pic 2) And of course some Eduard seat belts were also used.
When everything was dry the fuselage halves were glued together and the fin inserts were added and sanded in. Do not forget the tail wheel! Some filler was required as on the under wing panels. I first tried Tamiya's Light Curing stuff, but it did not stick very well to such a small gap, so I used my usual Mr.Surfacer 500 ... sanding and polishing it after it has dried over night. (pic 3)
I inserted two small spreaders left and right from the cockpit tub to spread the fuselage just 1/2 mm on each side. The wing to fuselage join is much better after this easy improvement. (picture 4, 5, 6) I still needed some clamps and inserts on one of the fuselages. This would cause a little trouble when fitting the cowl, (but the problem is manageable, as I know from experience, having already done it on the Hasegawa's Fw 190 A-3).
Then I added the power plants and cowlings. The engine replicas were painted RLM 66 and polished with MiG pigments "gun metal", then I glued them into place. All parts of the cowling were cleaned up and then fit into place. Some small gaps at the lower engine to fuselage join were filled with Tamiya putty and Mr Surfacer. (picture 7, 8, 9)
Afterwards I attached the main u/c legs to the models, as I like to have them on for painting -- so I do not need a special holder or stand --- but I leave off the undercarriage covers until after airbrushing the camo. As you can see I have also attached the elevators by now. (picture 10)
I started work on the canopies. First all 4 parts got a bath in Klear, then I mounted the gun sight and the windshield.
Now the problems started. So far I'd made most progress on the 190 A-4 and I wanted to research the type of canopy armor I would have to install. Well, the machine I wanted to build ("Wumm" Schnell's a/c of JG 2) does not have the cooling flaps but the "Kiemenspalten" (cooling "holes") --- those are in the Fw 190 A-3 kit but not in the A-4 kits. This put me into some trouble. Much later I found a machine I want to replicate, but from this point on I put the fighter aside and concentrated on the Fw 190 F-1, which luckily seems to have the cooling louvers mounted.
The canopy was masked (picture 12), sprayed RLM 66 and the whole model got a nice coat of white primer (Citadel), then I checked for imperfections .. sanding, polishing, respraying ... I also managed to break some parts of the ETC during the process, which had to be reattached. (picture 13)
  • Picture 1
    Picture 1
  • Fw190A-4_F-1_im_Bau_02
    Picture 2
  • Fw190A-4_F-1_im_Bau_03
    Picture 3
  • Fw190A-4_F-1_im_Bau_04
    Picture 4
  • Fw190A-4_F-1_im_Bau_05
    Picture 5
  • Fw190A-4_F-1_im_Bau_06
    Picture 6
  • Fw190A-4_F-1_im_Bau_07
    Picture 7
  • Picture 8
    Picture 8
  • Fw190A-4_F-1_im_Bau_09
    Picture 9
  • Picture 10
    Picture 10
  • Fw190A-4_F-1_im_Bau_11
    Picture 11
  • Fw190A-4_F-1_im_Bau_12
    Picture 12
  • Fw190A-4_F-1_im_Bau_13
    Picture 13
About Steffen Arndt (alpha_tango)
I was born in 1974 and started modelling in the 80ies. The first models I remember are a MiG 21 F-13, Saab Draken (both 1/100) and the Tu-2 (72) all from the east German producer Plastikart. during my first years I built all kind of models mainly 1/72 and 1/100. Beside the mentioned Plasticart kits ...
Thank you Rowan!! especially for ironing my mistakes out!!! cheers Steffen
JUN 23, 2007 - 12:56 AM
Hi Steffen My pleasure! It's a great article - keep 'em coming! All the best Rowan
JUN 23, 2007 - 02:06 AM
Hi Steffen! Nice one! Congratulations for your first article here! Unfortunately (for me) I don't have the Hasegawa Focke Wulf in my stash... now I have to buy one to follow your advices. Jean-Luc
JUN 23, 2007 - 07:32 AM
