Unfortunately, while I have no problem with the reviewer, I must say that I rate the kit lower than he does as I wished very much for it to be a triumph in offering what previous kits (Trumpeter 32nd, Maintrack 48th and Falcon 72nd), did not.
While the basic kit is alright (if rather fiddly with unnecessarily 'Hasegawa like' greebly elements such as the drop in refueling port, gun and exposed TF-34 casing peanuts), it still has a Trumpeter like windscreen width issue while the 'missing link' elements necessary to model a true N/AW prototype and easily fixed with 6 parts, are in fact STILL not included.
At All.
These being the Texas Instruments AAR-42 FLIR and the Westinghouse WX-50 Radar. Podded in the prototype, they would have been mounted in the forward halves of the landing gear sponsons in production versions. These systems are what made the N/AW special and they are simply nowhere to be found in this kit or any other of the Night All Weather A-10.
To not include them is akin to not putting LANTIRN pods in an F-15E boxing and still calling it a 'Strike Eagle' (in fact Revell, Hase and AMT have all done exactly this but that's not an excuse).
That this is especially eggregious in this case is because, excepting a few old hands working the FOLs out in Saudi, the A-10 was strictly a daytime aircraft in the low level role until LASTE brought an autopilot and radar altimeters after 1991 and Deny Flight brought nightvision compatible cockpit lighting in about 1992-93.
All of which the N/AW would've had from the start.
I would add that a GE LLTV was also tested, mounted in the Pave Penny pod so that the N/AW pilot would not lose HUD vision when the WSO 'stole' the FLIR for targeting work and that production aircraft would have had this item fixed in the wing leading edge and altogether, these THREE sensorization systems are what gave the aircraft it's highly distinctive look, as much if not more than the humped cockpit or tall tails.
Speaking of which: while also an 'intended for production' change, the dual canopies would have been replaced with a conventional opening, single piece, version along with a no-frame windscreen as the heavy armor-glass center panel in the current model had a significant lead content at the time which was found to interfere with night vision goggle performance too much.
The weight penalty of extending the bathtub aft to protect the systems operator was indeed considered too great but applique aluminum/composite panels for at least the quarter panel areas between the main instrument panel and side consoles would have been scabbed on in the production version as well.
Finally, though the aircraft is prototype-accurate for having a 20" extension to the vertical tails, these were found to be overkill as they dampened roll and added rather severe structural loads to the horizontal tail attachments. Production versions would have been only 6-8" taller than standard A-10 verticals.
Weapons are indeed good but unfortunately, almost none are appropriate to the aircraft as it flew or ever would have.
Specifically, it should be noted that while the initial FSD aircraft carriage cleared the Paveway I (2,000lb LGB, KMU-351, **NOT** the included GBU-10, as the A-10 needs the longspan tailfins for added stability at lower release speeds) at Edwards in 1976 or so, any 2,000lb munition is essentially unuseable from the A-10 in a modern threat environment. Which applies equally to the GBU-8 HOBOS EOGB which was in any case retired in 1978 as the GBU-15 came online.
The Mavericks are nice but the AGM-65B was nearly useless in Europe, even in daylight, and the AGM-65C was cancelled after service testing while the AGM-65D went back to the laboratory and spent an extended period there before reaching squadron service about 4 years (1986 with the 'Blue Dragons') after the official N/AW program ended. Don't use the LAU-88 in anything but outboard slant-two loads as loading the inner shoe resulted in burnoff problems with the gear sponson and tire. The LAU-88 also has some electrical reliability issues and is a draggy, heavy, system and so was rarely loaded once the LAU-117 was regularly available after about 1984.
MERs, while also carried during Seek Eagle workups at Edwards, were never cleared for use on the A-10 during service because of drag and release issues and today are completely out of USAF service thanks to hazmat requirements with the pyro carts.
The ECM pods, though accurate for an early 80's aircraft, would have rapidly transitioned to the deep model ALQ-131 in USAFE (Bentwaters) service. Some guard/rez units persisted with the ALQ-119 up until ODS but the ALQ-131 Blk.2 was pretty much standardized throughout the TAC forces with CentCom or NATO commitments. After Desert Storm, all CONUS based units quickly transitioned to the Raytheon ALQ-184 long and short.
Hasegawa has a passable equivalent to the deep Westinghouse pod in one of their weapons sets. Shawn Hull and Tamiya have the only ALQ-184s in 48th scale.
Malaysia wanted the N/AW for anti-shipping use during their 1980s troubles with pirates and for this role, Fairchild promoted the aircraft as a maritime patrol platform with up to four Harpoon or Penguin missiles as an alternative to Mavericks (against PCI/FIAC type craft, the AGM-65 is more than sufficient).
Unfortunately, the A-10 has never had the best legs and as the engines get older this has become a real problem. The 600 gallon tank, while useable, looks a bit 'stretched', the Monogram equivalent is rather better IMO but in any case my memories are always of double bubbles on the inboards during extended deployment transits to Bright Star or Team Spirit. In any case, the tank isn't pressure inerted and has a low G-rating of about +2.5 or so and thus would never be slung on a combat mission.
Though never used, the AGM-114 was also checked out early on the A-10 (1979) just as the N/AW program was getting going because the M272 launcher was found to be readily compatible with the Hog's lower top end speeds and altitudes. Photos show it on Stations 3/9, replacing Maverick. Many early pilots felt that the weapons extended lo-loft 'below clouds' capability, as well as lower overall carriage penalties, actually made it an ideal SEAD weapon and finally gave the Army JAAT doctrine if not beanie prop brigade a reason for existing. Especially once the AHIP allowed them to rapidly designate over-hill.
The Sidewinder DRA was unknown in the period 1979-82 when N/AW was most active and frankly, without boresight cueing or a VERY hot lookup target, the AIM-9L was more or less 'for show', especially at night and in European weather. ODS proved this when Sidewinder effectively refused to lockon to helicopters, forcing A-10s down for the gun kill which exposed them to missile traps and flak.
Parent loaded SUU-25 or TER mounted LUU-2 flares for the Night FFAC/Illumination role and probably AGM-45 Shrike would be acceptable alternatives to AAM as the WX-50 had both a precision MTI and a dedicated X-Band ELS mode that used the main radar array to track slow moving ground targets and pinpoint ZSU/SA-13 type threat emitters in the convoy.
Given the existing mission aircraft at that time were the OA-37 in Korea and the OV-10/Alphajet in Europe, there effectively was no survivable Fast FAC (A backseater would have also been _very nice_ to run the radios which the A-10 FM-has but seldom employs well.).
Due to the added drag of the raised forward fuselage, iron bombs would be parent loaded inboard if carried at all and after about 1985 largely consisted of Mk.82 with BSU-49 AIR tails and Radar noses. The Mk.82 conical fin with mechanical fuze prop would almost never be used below 1,500ft which is at least twice as high as the hogs ever wanted to go in Europe.
Early on, CBU-52/58/72, along with Mk.20, were available as PPME and depot warstocks in various theaters but being Vietnam era ordnance these were considered largely unreliable and dangerous to employ compared to the gun and maverick which were the primary trained weapons systems.
The N/AW might have changed this with the advent of the backseater and effective mission systems but it is equally likely that a rocket assisted version of Paveway (ala Skipper) would have been employed as a (friendly) bridge busting aid to contain breakouts while the A-7D went in for the kill (it was faster with superior coupled T/A + mapping and a smarter HUD) in the laydown mission.
Though it did use quite a few in ODS, the A-10 was one of the last tacjets to qualify with the SUU-60 series TMD (which is not included) so if you want one of those, you have to go to Shawn Hull or the Italeri F-16C and assume N/AW operations after 1990.
Finally, F.S.36118 is indeed accurate, indeed, in some shots the N/AW looks almost black. The boxart 'photo' has clearly been digitally manipulated while the airframe was allowed to weather considerably on the main Edwards ramp for a decade or more before being withdrawn to one of the side hangars for a quasi-restoration. It was kept pristine during the program and for a few years after while serving as a range hack.
The true 'mange grey' A-10s were either JAWS birds or those painted in the early MASK-10A colors which were hand mixed from various alkyd based paints and _did not_ weather well.
CONCLUSION:
All is forgiveable except for the system pods. The WX-50 is more or less a tube with a rounded off radome like a chunky rocket pod. Unfortunately, the AAR-42 is a lot more complicated as a shape with a frontend like one of those old fashioned ice scream scoops (with the articulated separator) acting as a 'lenscover' to the main FLIR aperture and mounted to the pod via a 'dog collar' clamp. There is also a strange looking ECS ram inlet and exhaust vent underneath and what looks like an electrical connection wire. Though not impossible to scratchbuild, they should REALLY have been a part of the kit from the outset. As it is in fact presently closer to being the proposed A-10B trainer than the N/AW.
http://photos.kitmaker.net/data/500/thumbs/NAW_Mission_Pods_1.jpghttp://photos.kitmaker.net/data/500/thumbs/NAW_Mission_Pods_2.jpgCJ
