Fw 200 C-5/C-8 CONDOR
TedMamere
Moselle, France
KitMaker: 5,653 posts
AeroScale: 4,347 posts
Posted: Sunday, February 04, 2007 - 07:30 PM UTC
Here''s a review by Fred Rick Boucher (JPTRR) of what prime Minister Winston Churchill called the Scourge of the Atlantic. This new mold 1/72 scale Fw 200 Condor kit is produced by Revell Germany.
KitMaker: 7,772 posts
AeroScale: 3,175 posts
Posted: Monday, February 05, 2007 - 01:33 AM UTC
Hello Condor Connoisseurs,
I hope I am getting better with photographs. Unfortunately, the fuselage interior shot is washed-out. The fuselage interior of the cockpit and mid-fuselage have ribs and stringers molded in.
The reason I gave the model only 60% is the bizarre molding of 'waves' on the outer wing sections. Before I researched that the Condor did not have fabric wing panels (a 'la F4U Corsair), I rated it at 80%. Ordinarily I do not think I can go higher without actually gluing plastic together. But those wing panels are too much to overlook, no different than mistakenly molding in-line engines for a radial powered plane.
Posted: Monday, February 05, 2007 - 02:34 AM UTC
Nice review. Very helpful as I have fingered around with this kit several times in my LHS.
However, I would have liked pictures of the different camouflage/marking options in the kit. This is an aspect that can often be the deciding factor for me.
Thanks for sharing
Posted: Monday, February 05, 2007 - 02:54 AM UTC
However, I would have liked pictures of the different camouflage/marking options ...
Hi SGTJKJ,
My model has decals for 4 versions. The painting guide shows 3 in the same splinter camo. One one is shown with the squiggles as per the box art. All the illustrations are in black and white.
Posted: Monday, February 05, 2007 - 03:23 AM UTC
Hi all
Straying a bit off topic...
So, both Trumpeter's 1/48 scale kit and now the smaller Revell Kondor have both got a bit of a mauling at the hands of reviewers... which rather begs the question - is there a decent OOB Fw 200 out there? Steffen has previously noted correction sets for the seriously flawed Trumpeter model, but has anyone here tackled the Koster 1/48 vacuform and how does that stack up? I passed on it when it was released because of the perennial problem of space - but it'd be fun to know if it still the best option for anyone prepared for a vacu-challenge
alpha_tango
KitMaker: 5,609 posts
AeroScale: 5,231 posts
Posted: Monday, February 05, 2007 - 03:42 AM UTC
Sure you researched that right?
I am not debating the overdone panels, but they were fabric covered on the real a/c!!!
see e.g Nowarra Focke-Wulf FW 200 Condor (German Edition, Motorbuch Verlag) page116 (burnt a/c) or page 60 (in flight).
best wishes
P.S. @ Rowan: this kit is waaaaay better than the dreaded Trumpeter ... but 72 is just not my scale, so I won't debate if the Revell kit is good or bad
Posted: Monday, February 05, 2007 - 09:18 PM UTC
best wishes
This means that the kit is correct, but "only" with overdone fabric covering on the wings?
alpha_tango
Posted: Monday, February 05, 2007 - 09:30 PM UTC
I cannot comment if the kit is correct (I have heard so though) but the "fabric" (looks more like corrugated iron) is at the right places.
best wishes
Posted: Tuesday, February 06, 2007 - 01:31 AM UTC
Sure you researched that right? I am not debating the overdone panels, but they were fabric covered on the real a/c!!! see e.g Nowarra Focke-Wulf FW 200 Condor (German Edition, Motorbuch Verlag) page116 (burnt a/c) or page 60 (in flight).
I read in various books that the Condor is "all-metal". No mention about fabric panels. I don't have the book you mention but if it is a burnt-out a/c, airplanes can partially burn so that the structure is not melted or destroyed but the aluminum skinning is gone, giving the appearance of removed fabric. If anyone can produce fact that Condor had fabric panels, I am more than happy to re-rate her at 80%, with my apologies for my ignorance.
Removed by original poster on 02/07/07 - 04:26:39 (GMT).
alpha_tango
Posted: Tuesday, February 06, 2007 - 02:26 AM UTC
Hi Fred
I do not care how you rate the kit, because that is totally up to you and as I wrote in the P-51 thread a matter of personal taste. But you wanted me to prove you wrong .. which made me a lot of trouble with my scanner :
Picture 1 in flight .. you can clearly see the panels on both wings but better on the right one (arrows)
Still do not believe me .. beat this: :-) :-) :-) :-)
and do not tell me only that "aluminium" that was over the fabric covered areas burnt away
P.S. save the photos I will delete them tomorrow
Posted: Tuesday, February 06, 2007 - 03:45 AM UTC
Hi Steffen,
Oh my my my! That second photo is quite conclusive that the Condor was built with fabric covered outer panels! I also found the following photos of the wing structure of the Norway Wreck showing the bare frame aft of the spar.
Also, IPMS of the Philippines addresses this: Trumpeter Condor Review
Seems I need to revise my review! Curious how none of the references I have found of the aircraft's structure mention this.
While we are at it, here are some sites with good interior shots of FW 200s:
Interiors
http://www.fluggeraet.de/fw200_1.html
http://www.trefall.net/kvitanosi/index_en.htm
alpha_tango
Posted: Tuesday, February 06, 2007 - 03:53 AM UTC
could you please link to the pictures that prove your view?
It is as if you were pointing to google as reference ...
Kriegshund
Missouri, United States
KitMaker: 132 posts
AeroScale: 108 posts
Posted: Tuesday, February 06, 2007 - 08:21 AM UTC
Hi Fred and all,
I too was under the impression that the Fw 200 was an all-metal aircraft. The pictures you present do seem to bear this out. Reading the ongoing debate got me thinking, so I dug out my copy of "Warplanes Of The Luftwaffe" and did some reading. Regarding the Fw 200 Condor, on page 85:
"The wing was built as a horizontal centre-section including the engines, with dihedralled and tapered outer panels. Structure was stress-skinned throughout, with flush rivetting, except for the fabric-covered wing aft of the rear spar and fabric-covered control surfaces."
Unfortunately this book does not have any pictures showing the surface of the wings, just side views of the aircraft.
TedMamere
Moselle, France
Posted: Tuesday, February 06, 2007 - 11:39 AM UTC
Hi Steffen!
Try this link: wreck
Jean-Luc
Posted: Tuesday, February 06, 2007 - 12:32 PM UTC
Wow!! This tread is really turning into a tressure trove of information on the FW 200.
Great pictures and good links.
Thanks for sharing all your information on the subject.
alpha_tango
Posted: Tuesday, February 06, 2007 - 01:05 PM UTC
Hi gang
@ Jean-Luc: that also only gets me on the starting page of the wreck site (I am aware of the concept of "copy and paste" :-) :-) ), it is surely useful for general reseach, but for my discussion with Fred it is not really, because it is too less specific
@ Jesper:
Not for me, somehow I have the feeling we got into a deadlock ...
1. I cannot find pictures that convince Fred that I am right ----- after scanning, that is .. because in the book they look ok.
2. Fred does insist on his position
Stretched fabric never looks like the model companies make us believe, the difference to metal planking is marginal, but can clearly be seen in 1/1 because of the different structure of the fabric and because you can see where it is glued to the framing .. so it is very hard to find pix that clearly show that, I thought my examples did...
I know I am right, but I cannot convince him.... so I better drop out here
best wishes to all
Posted: Tuesday, February 06, 2007 - 03:43 PM UTC
Hi gang
@ Jesper:
best wishes to all
The discussion here is good enough to me. It proves that the model might have some overdone details, but are fundamentally correct. That is fine with me and good enough for me to build this beautiful aircraft. It does not have to be a work of art. It normally never is, when I am done with it :-) :-)
Posted: Wednesday, February 07, 2007 - 01:14 AM UTC
Steffen, Steffen, Steffen! Hit the reset button mine Freund! You did convince me yesterday evening. I rewrote my post with
Hi Steffen,
I just sent Jean-Luc the revised text and a re-rating of 80%. You did well and I appreciate your correcting me.
TedMamere
Moselle, France
Posted: Wednesday, February 07, 2007 - 01:23 AM UTC
Hi Fred!
I've re-re-re-edited the review! :-)
Jetzt ist alles wieder gut...
Jean-Luc
alpha_tango
Posted: Wednesday, February 07, 2007 - 01:28 AM UTC
Hi Fred
well, first your post only had the links (see my reaction above) ... so I thought you tried to prove you are right ....
Well, now it all came to a good end .. as I like it
