Dioramas: Campaigns
Group builds and online competetions. Join the fun!
Contest Update: An Unwanted Friend Part II
YodaMan
KitMaker: 1,561 posts
Posted: Monday, November 04, 2002 - 08:31 AM UTC
Another thing you can use for a base is dry floral foam. You can get six blocks of it for $1.50... that's about an 8 inch by 20 inch rectangle 3-4 inches high. See a tutorial for a quick and easy dio base here
YodaMan
Eagle
Noord-Brabant, Netherlands
KitMaker: 4,082 posts
Posted: Monday, November 04, 2002 - 07:56 AM UTC
Anders,
sounds exciting !! Jus't can't wait to see it ! Please keep us posted.
Danny "The contest Shedman" Eagle
AndersHeintz
KitMaker: 2,250 posts
AeroScale: 22 posts
Posted: Monday, November 04, 2002 - 06:32 AM UTC
Hola Basturk!
Foam Board is a piece of foam inbetween two card board pieces. Great for buildings etc. Look at your art store for it
basturk
Singapore / 新加坡
KitMaker: 212 posts
Posted: Sunday, November 03, 2002 - 04:30 PM UTC
wow sounds like good progress there........... I haven t even started mine yet!!! Btw i have a stupid question: Does foam board = styrofoam board? Need to figure this out if i want to scratchbuild buildings............
AndersHeintz
AeroScale: 22 posts
Posted: Sunday, November 03, 2002 - 02:50 PM UTC
Hola Guys!
Ok, the show is on! This is what I have todate finished:
The base is finished, 6" x 4" x 13" are the dimensions. Its primed and ready for finishing.
The tower if 95% finished still, need to add some bolts and then its ready for painting.
The Water Tank is 95% finished. Added the copper shell and about 210 bolts so far, need to add some more bolts and weld seems. Its not too much fun :
The next steps are:
Start the wall facade in foam board and resin window frames (Wood might be used instead)
Figure sculpting need to comence, just awaiting the new fresh shipment of Magic Sculpt.
Ground work will be started as soon as the base is finished.
Water tower to be primed and painted then weathered.
And thats about it for now Will keep you posted on further progress and pictures are soon to come!
