Armor/AFV: Modern Armor
Modern armor in general.
MENG 1/35 Terminator BMPT
robw_uk
KitMaker: 1,224 posts
Posted: Friday, October 09, 2020 - 11:23 PM UTC
Starting this one, first foray in to workable suspension/tracks...
most likely plan is for a what if pixel scheme (unsure of colours as yet)
robw_uk
Posted: Saturday, October 10, 2020 - 04:19 AM UTC
ok so some progress... workable suspension was a pain so thats fixed but the workable tracks are going together nicely...
grunt136mike
KitMaker: 1,896 posts
Posted: Saturday, October 10, 2020 - 06:03 PM UTC
Hi;
You are really going to like your kit, As for myself I liked it so much, I built Two. If you are going to depict your kit in A Dio or Display it on uneven ground then the suspension will be useful; Otherwise its not worth the time making it work.
CHEERS; MIKE.
robw_uk
Posted: Tuesday, October 13, 2020 - 06:32 PM UTC
Hi;
CHEERS; MIKE.
cheers Mike, no dio so fixed suspension is OK. Must say so far so good (might not build another but am assuming the T-90 is a similar configuration of kit...
progress. One side of tracks done (workable tracks went together nicely with only a few casualties) and the running gear done. On to the upper hull now.
robw_uk
Posted: Tuesday, October 20, 2020 - 07:38 PM UTC
both tracks completed - and 81 links/side seems about right. Have moved on to the upper hull and attached it to the lower... nice fit. Still not sure on the paint job this will get but so far so good
robw_uk
Posted: Wednesday, October 21, 2020 - 10:03 PM UTC
More progress, side units mounted, now on to the protective parts on the engine deck
robw_uk
Posted: Saturday, October 24, 2020 - 04:21 AM UTC
moved to new forum: https://forums.kitmaker.net/t/meng-1-35-bmpt-terminator/1109
