Chevy Military Fire Truck Walk-Around
barkingdigger
KitMaker: 3,977 posts
Posted: Tuesday, October 06, 2020 - 03:48 AM UTC
It would perhaps be reasonable for one to create an open cab version of this truck from the old Tamiya LRDC desert truck.
I'd say use the LRDG front, with Italeri closed cab.
(Looks like somebody already did it - see: http://coldemons.blogspot.com/2011/11/chevy-30-cwt-lorry-rebuilt.html )
KitMaker: 9,456 posts
Posted: Tuesday, October 06, 2020 - 11:59 AM UTC
I went to that site but could not find what you are referring to.
I seem to remember an article some years back where the guy made a hard cab cargo truck but it seemed he had to split the cab and make it wider to work.
barkingdigger
Posted: Tuesday, October 06, 2020 - 12:05 PM UTC
Oops - my bad! I didn't leave a space between the end of the link "html" and the rear parentheses. I've edited it and now it works so try again.
Posted: Tuesday, October 06, 2020 - 01:27 PM UTC
Humm: He said rubbing his chin; "Punjab, please hand me my saw!"
I can't help wondering if he laid that camo cloth across the hood and cowl to hide a slight mis-match?
KitMaker: 12,718 posts
Posted: Tuesday, October 06, 2020 - 06:14 PM UTC
Maybe it's just me, but the closed cab doesn't look like it is scratchbuilt :
I would say the rear part of the cab at least is not from the Italeri CCKW kit....
The guy says that "This is old Tamiya's kit but I don't know its number - just the same base as Chevrolet LRDG but with complete cabin" To me this doesn't necessarily mean that he has scrachbuilt the cab....
The Italeri cab to compare :
Tank1812
KitMaker: 1,109 posts
AeroScale: 67 posts
Posted: Tuesday, October 06, 2020 - 09:15 PM UTC
That is a interesting idea. While maybe not a great photo, the first pic of the before project doesn’t appear to look that bad under the tarp area. Maybe damaged the area in the clean up process and needed to hide it.
Posted: Thursday, October 08, 2020 - 12:14 AM UTC
Looks more like perhaps an IH cab???
Posted: Thursday, October 08, 2020 - 12:48 AM UTC
What about the Dodge D15-15CWT from Wespe Models ?
barkingdigger
Posted: Thursday, October 08, 2020 - 09:40 AM UTC
I realised where I'd seen that closed cab before - that guy used the cab from the original Italeri Katyusha kit, the one that used the post-war Soviet copy of the Deuce. Not quite a GM product, but still looks cool...
27-1025
KitMaker: 1,278 posts
AeroScale: 39 posts
Posted: Thursday, October 08, 2020 - 10:03 AM UTC
Sitting here holding the required components for this conversion and realizing that this might be a bit more involved than I thought........🤔
Posted: Friday, October 09, 2020 - 03:29 AM UTC
MUCH GREATER success on my request from Darley this time !*!*!*!*!*!*!*!
Posted: Friday, October 09, 2020 - 03:32 AM UTC
EXACTLY!
barkingdigger
Posted: Friday, October 09, 2020 - 04:12 AM UTC
That's a great section drawing of a pump! Did you get others from different angles?
Posted: Friday, October 09, 2020 - 08:24 AM UTC
Unfortunately no, that was the closest thing to an engineering drawing in the entire install manual. And all the photos in the pdf file were basically just black silhouettes with no rear view of the pump.
18Bravo
KitMaker: 7,219 posts
AeroScale: 101 posts
Posted: Friday, October 09, 2020 - 04:07 PM UTC
Not exactly on the list of things I want to build, but definitely high on the "do-ability" index. But the cab does not need to be widened - it is in fact slightly too wide already. A "V" shaped notch in the hood with a sliver of Evergreen would seem to do the trick.
As for the builder hiding something, personally I find it unlikely given the amount of skill he's already displayed. That and the fact that dudes actually do these sorts of things in real life with angle grinders, welders, maybe a generous supply of Bondo or melted lead.
Posted: Friday, October 09, 2020 - 05:21 PM UTC
I have always thought that LRDG truck to be an excellent work from Tamiya. Just never understood why Pappa Tamiya did not parlay that design/mold work into a hard cab cargo truck version as well.
As a small aside: The seats used in that truck are some of the best model work in the industry. (I guess b/c they are openly exposed to view.) For my money those seats need to be copied into a two part 3D print for use in every CCKW, Chevy and IH truck kit sold on the market today.
HINT, HINT!
barkingdigger
Posted: Saturday, October 10, 2020 - 01:11 AM UTC
HINT, HINT!
Sadly not a hint for me! My CAD is good for "mechanical" things, but not for sculpting soft organic shapes like seat cushions. You'd be better off using RTV rubber to make moulds of the kit parts and then casting them the traditional way...
barkingdigger
Posted: Saturday, October 17, 2020 - 11:30 PM UTC
Hi Mike,
Finally got round to looking at that pump I ordered off Shapeways. I had to throw a coat of primer on it to see the details:
Posted: Monday, October 26, 2020 - 05:50 AM UTC
Well this recent new post was just starting to build some momentum so maybe we can cross this one over as it is only two pages 1700+ hits.
