It's hard to tell if it is indeed fine work, as the model is barely visible in your photos. You should try to experiment with your photography a bit more to achieve clearer and sharper images, as now it is unfortunately just a blurry mess...
Quoted TextIt's hard to tell if it is indeed fine work, as the model is barely visible in your photos. You should try to experiment with your photography a bit more to achieve clearer and sharper images, as now it is unfortunately just a blurry mess...
Building and posting is a learning experience like everything else. So how how about cutting this modeler a little slack.
Sincerely,
Ian
From what I can see in the blurry pics, it looks like it is pretty good. The basic build looks OK. The blade is all wrong though. It looks like a blade off either a Stryker or possibly a ABV. The IDF never used that blade on M60s.
Quoted TextFrom what I can see in the blurry pics, it looks like it is pretty good. The basic build looks OK. The blade is all wrong though. It looks like a blade off either a Stryker or possibly a ABV. The IDF never used that blade on M60s.
"from a kit that included an option of a blade or mine rollers"
Stryker ESV, Trumpeter 01574 comes with LWMR (rollers) and SOB (blade, who came up with SOB as abbreviation?)
http://www.ipmsdeutschland.de/FirstLook/Trumpeter/Tru_M1132_Stryker/Tru_M1132_Stryker.html
Hi Bo,
Having a look again to the pics posted it seems to me that the two side-mounted MGs are different: one FN MAG on the left side and an M1919 cal .30 on the right side of the turret. I am not an expert but it looks incorrect. I think both side MGs would have been replaced with FN MAG on any M60s of the IDF. Never seen a mixed version - again, I am not expert on it, any expert could correct me if I am wrong.
About the pics: you can easily remake the photos from a longer distance where the focus would not matter, and simply crop out the model as main subject of the photo, resulting a kind of “closer look”. I always do it on my models and some photos are really very realistic, like this one (made with my iPhone on a shiny afternoon):
And a last advice: your pics are probably over-edited in a photo editor software. This post-processing surely made the pics worse than they were originally. I rarely post-process my photos to avoid blurs and discolorization.
I am sure you can make much better photos in the future, just try different setups and perspectives...
Tamás
