Bf 109 G-10 ERLA Build
litespeed
Staff MemberNews Reporter
KitMaker: 1,875 posts
AeroScale: 1,695 posts
Posted: Tuesday, May 26, 2020 - 10:55 PM UTC
While I'm waiting for some paint to arrive for the Eduard 1/48 scale ERLA Bf 109 G-10 I will do just a little catch up with the build. I hurriedly built the Bf 109 G-10 ERLA for the review, but quickly released that it was such a good kit it needed finishing.
Being a Profipack Edition there are three options to detailing the cockpit: pre-coloured photo etched parts, dry brushing the excellent detail on the plastic or using the decals supplied on the kit. You do have to be careful fitting the PE parts particularly the parts representing the chains for the flaps. But as you can see it well worth the trouble.
You'll notice I have put in some plasticard shims just to aid the fitting of the two fuselage halves. there are no locating pins, so the shims will help stop any movement when the halves are clamped together.
KitMaker: 4,707 posts
AeroScale: 1,334 posts
Posted: Tuesday, May 26, 2020 - 10:57 PM UTC
Oh cool, watching along Tim and crossing my fingers that you do the Italian option.
litespeed
Posted: Tuesday, May 26, 2020 - 11:05 PM UTC
Sorry Luciano Im going for this one. I like the blue band and the natural metal finish on the under surfaces.
Posted: Tuesday, May 26, 2020 - 11:20 PM UTC
Oh well looks like Iíll have to pick one up myself, donít know when Iíll get around to building it though. Any way still following along.
Oh just remembered I have a 1/32 RA/ANR decal set for the Revell kit.
magnusf
KitMaker: 1,899 posts
AeroScale: 1,848 posts
Posted: Wednesday, May 27, 2020 - 03:34 AM UTC
I would SO MUCH love Eduard to shrink these into 1/72... I do have a stash of Fine Molds-109:s that are nice but these are really something special. I have promised Torsten to do a Finnish one this year...
I could get one in 1/48 just for the box art though !
Magnus
KitMaker: 1,623 posts
AeroScale: 1,290 posts
Posted: Wednesday, May 27, 2020 - 05:47 AM UTC
I'm here to look over your shoulder, Tim. You might have seen my Utti Air Racer Dual Combo build recently of a G-2 and a G-6. This might be an option for me because I have some interesting and rare decals for a G-10 of the Russian Liberation Army which I would like to build.
Happy modelling!
litespeed
Posted: Wednesday, May 27, 2020 - 06:05 AM UTC
Weicome aboard Torsten. Yeah I enjoyed your build Torsten, you inspired me to build the G-10. I must admit I do prefer the 'Gustavs' of the 109 family as I prefer the later Griffon engined Spits.
Naseby
Slovakia
KitMaker: 824 posts
AeroScale: 475 posts
Posted: Wednesday, May 27, 2020 - 08:22 AM UTC
Magnus
Why not the one in 1/48 ? These are some of the easiests kits out there, even with the PE. I did the G-6 coupple months ago and it was easier to build then most 1/72 kits I ever did.
litespeed
Posted: Wednesday, May 27, 2020 - 11:07 PM UTC
The intake for the super charger is made up from three parts. Theres a nice clear recess where the unit fits into the fuselage. The exhausts don't look half bad either.
The undercarriage walls are easy to fit. Also fitted the slats and the rack for the fuel tank. The detail on the radiator face is very good, although there are PE parts for extra detail included.
Posted: Thursday, May 28, 2020 - 07:53 AM UTC
... as I prefer the later Griffon engined Spits.
Hahaha, same here, Tim! I love the angry sound of a Griffon Spit. Seen a Mk. XIX from La Ferte Alais several times at the Hahnweide Festival in Germany.
Concerning your build, I didn't use the PE parts for the radiators because you don't really see them in the end. You also might cut off the pitot tube because it will break anyway during the build and use part I 21 in the end. I did that and would do it again.
Magnus, don't worry about your Ilmavoimat 109. If you can't make it this year, next year is another year ....
litespeed
Posted: Friday, May 29, 2020 - 01:31 AM UTC
[quote]
Youre right Torsten, the PE parts for the radiator are unnecessary. Can't see much detail peering into the radiator housing and the detail on the plastic is first rate. This kit will make a brilliant 'Weekend Edition'
I have just literally knocked off the pitot tube it will glue back on again or I probably change it for a pin
tim
Posted: Friday, May 29, 2020 - 02:37 AM UTC
...I have just literally knocked off the pitot tube it will glue back on again or I probably change it for a pin
tim
Look on page 9 of the instruction and have a look at part I 21, Tim. That's the "substitute" for a lost/broken pitot tube. I also didn't notice it at first. Here's what I did in full purpose ....
litespeed
Posted: Friday, May 29, 2020 - 06:57 AM UTC
Thanks Torsten had not noticed that, different sprue no I21 with this kit, but still page 9
litespeed
Posted: Friday, May 29, 2020 - 08:29 AM UTC
The fuselage went together nicely, the fit of the gun and engine cover is superb. The locating tabs I attached to the inside of the fuselage helped quite a bit particularly when applying the clamps, they stopped the fuselage halves moving around. The fit of the wings and horizontal tail planes is very good. I placed a tab on the fuselage where it meets the wing. I seem to remember Rowan commenting on the step here. It just needs a slight sanding to blend it in The only part that needs attention is part of the leading edge of the wing needs a bit of filler. Also the sprue attachment points need some attention..
litespeed
Posted: Sunday, May 31, 2020 - 10:51 AM UTC
These are some of the images I posted with the review I did of this kit. I applied the minimum amount of adhesive to the undercarriage and props so that I could take them of when I started painting. One thing that needed attention was the windscreen. It was sitting a little high compared to the canopy, so I reduced the height by sanding the base. I used liquid glue very carefully applied to glue the clear parts.
litespeed
Posted: Sunday, May 31, 2020 - 10:56 AM UTC
The paint masks included in the kit are really useful, but they needed a bit of persuading to separate them from the excess masking material. I applied a primer and then some heavily thinned Tamiya white paint as a pre-shade.
litespeed
Posted: Tuesday, June 02, 2020 - 05:06 AM UTC
Now for the fun part for me applying the paint. Iím using Tamiya paints to achieve the camouflage finish. Iím using the IPMS Stockholm paint mix guide as there are no equivalent colours for the late war markings.
Posted: Tuesday, June 02, 2020 - 06:01 AM UTC
Good progress, Tim. Tamiya paints are quite good but they have a limited range so you always have to mix just like Revell. That's why I went for Vallejo some years ago. They have nearly every tone in their programm and my airbrush works well with them. Meanwhile I only use Tamiya paints for japanese aircraft because they look most realistic there.
Weathering on german late war aircraft is always a contentious point among modellers. But all that matters is that the modeller likes his work. Beside that we sometimes just take it too serious. In the end it's just painted plastic.
litespeed
Posted: Tuesday, June 02, 2020 - 10:01 AM UTC
Your absolutely correct there Torsten. Just fancied trying something different with the weathering. If it doesn't quite turn out as I expect then move onto the next build with a bit more experience in my pocket It is meant to be fun....
SF-07-18D
Madrid, Spain / EspaŮa
KitMaker: 361 posts
AeroScale: 58 posts
Posted: Wednesday, June 03, 2020 - 07:52 PM UTC
Very smooth painting Tim!! I really like it.
It's a pity the short range of (realistic) Tamiya colours. They're my favorite paints altogether Gunze. But sometime it's difficult to find equivalences for Tamiya.
Regards!
litespeed
Posted: Wednesday, June 03, 2020 - 10:26 PM UTC
I can see the sense in that Torsten. Trouble with mixing paints is trying to match the colour again when having to touch up areas. I try to mix as much paint as I think I need then a bit more just in case. But it would be much easier having the colour already mixed up
litespeed
Posted: Wednesday, June 03, 2020 - 10:28 PM UTC
Thanks Nacho, yes I am seriously considering a change of paint manufacturer. Trouble is I like Tamiya paints a lot
litespeed
Posted: Wednesday, June 03, 2020 - 10:43 PM UTC
Well had a bit of a nightmare over the last couple of days. I used Vallejoís Aluminium paint for the first time for the unpainted areas under the wings. Normally I use Alclad II, but I have no thinners. Also the fumes are beginning to put me off. Very impressed with the results, though I did thin the paint slightly. Then left the kit alone to dry for a day or so. I started applying Kleer to the model in preparation for the decals. I noticed that the Vallejo aluminium didnít like it at all. Luckily, I had only applied it to the outer panel of the left wing so no real harm done. It was weird it almost rejuvenated the paint and it started to spread it around. I tend to apply Kleer with a brush, donít like it in the airbrush. Could I get away with it by calling it a weathered look? No not really it just looked like a mess and it had ridges. So I sanded the paint back re-applied the Hellblau then sprayed the aluminium over it. I applied three coats of Vallejoís gloss finish over the aluminium parts, after testing it on a scrap bit of plastic this time!
I carried on applying the Kleer on the rest of the kit. I also noticed there was a slight bleed from the Tamiya blue paint into the white on the fuselage band. I had to re-mask and apply some more white paint.
After three coats it became a slippery so and so. It slipped [it leapt honest!] out of my hands and dropped it on the floor knocking off the tail wheel and something is loose in the cockpit! Could have been a lot worse.
Modelling sure is an adventure 😊
litespeed
Posted: Thursday, June 11, 2020 - 07:21 PM UTC
Not to far from finishing. All the decals are in place and there were a quite a few stencils. I must admit I struggled with the spinner decal. The first one just would not sit correctly. Luckily there are others on the sheet, not quite the same, but close enough for me. The other decals seem to settle down really well with the use of Microsol softener and fixer.
Posted: Friday, June 12, 2020 - 03:44 AM UTC
Comes along nicely, Tim. That aluminium underside looks quite unusual. How did you solve that problem with Klear you had?
.... I must admit I struggled with the spinner decal. The first one just would not sit correctly ....
I also always had problems with these decals but since I have discovered that Eduard has their spinner spiral masks EX 500, I don't use them anymore. I can highly recommend them! And they don't cost the world
