Armor/AFV
Tamiya SU-122 (1/35)
kunjuro
Philippines
KitMaker: 490 posts
AeroScale: 24 posts
Posted: Monday, April 27, 2020 - 05:58 AM UTC
Hi folks,
I'd like to share my work on this old Tamiya SU-122 (1/35). Tried a bit of hairspray chipping but did not apply enough hairspray so the chips were hard to bring out. Resorted to sponge and brush chipping, as well as heavy use of oil paints to weather her. Added a bit of thick mud on the running gear as well. NOTE: I do know the rear has a bad fit. I've been using the polycaps to hold the parts in place as per Tamiya but I'll probably glue them together once I'm satisfied with the whole build.
Would appreciate any constructive criticism. Thanks for looking! Hope you stay safe at home and let the COVID-19 pandemic pass
https://i.imgur.com/J5zpGv1.jpg
americanpanzer
Iowa, United States
KitMaker: 532 posts
Posted: Monday, April 27, 2020 - 07:53 AM UTC
Awesome work!! I've built several of those old Tamiya kits and have others in my stash; you have proved they can be made into great-looking models!
youpey
KitMaker: 526 posts
Posted: Monday, April 27, 2020 - 10:18 AM UTC
it looks very good. how was the build? did it go together easily?
i was looking to get one
GeraldOwens
KitMaker: 3,682 posts
Posted: Monday, April 27, 2020 - 12:05 PM UTC
I built it when it came out in the 1970's. Like all Tamiya kits of the time, it builds quickly and easily with no fit problems. It's accuracy dimensionally is only so-so, and if you choose to upgrade with photoetch parts, you must get a set designed for it, as the grills are very different in size from more recent kits. Part and Eduard have offered sets for Tamiya T-34 family kits.
kunjuro
Philippines
KitMaker: 490 posts
AeroScale: 24 posts
Posted: Tuesday, April 28, 2020 - 01:06 AM UTC
Thanks for the positive feedback folks
As GeraldOwens said, this is an old Tamiya product. It was easy to build but oddly enough it had significant gaps and seams on the roof plate and rear hull. You can fix that with TLC sure, but the SU-85 from the same era had less issues. If you can get this kit cheap, go for it - just be aware that it needs a bit more TLC than the usual Tamiya kit I've seen the Mini-art kits of this AFV and if you can afford that, I would wholeheartedly recommend those instead
GeraldOwens
Posted: Tuesday, April 28, 2020 - 09:21 AM UTC
As I said, I had no problems with mine. Occasionally, kit runs may have issues with shrinkage due to the batch of plastic used, so, as they say, your mileage may differ. I wholeheartedly agree that the new Miniart kits are drastically better in detail and accuracy, but the build above shows that it's still possible to take an old dinosaur and turn it into a gem.
Dioramartin
KitMaker: 1,356 posts
Posted: Wednesday, April 29, 2020 - 03:21 AM UTC
This is exceptional painting so good that I imagine if I tapped a hull plate Id hear a metallic clang. Its just a shame you didnt work your magic on the MiniArt version which as you say is highly recommended go on, make our days!
kunjuro
Philippines
KitMaker: 490 posts
AeroScale: 24 posts
Posted: Wednesday, April 29, 2020 - 08:34 PM UTC
Thanks Tim! Maybe when the lockdown ends I'll get myself one of the newer miniart kits I will be avoiding interiors though - I don't have the patience to work on those just yet!
