Armor/AFV: Modern Armor
Modern armor in general.
TPZ-1 Fuchs APC
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Saturday, March 21, 2020 - 06:53 AM UTC
Started this Wednesday after I got locked in...
Revel 1/35 kit. Was the NBC Testing Vehicle but it comes w/ all the parts for the std. APC, Engineers, Medic, Etc...
I downloaded the instructing for the typical APC version an that's what I'm building.
First step in instructions is to glue the two half's of the body together - skipped that.
Suspension is a lot of fiddly parts, 4 way steering rods real pain if you follow the kits direction.
I did...
There is no interior. I'm leaving the hatchs open so you would see big empty space inside.
So I did alittle research and threw in a quick very basic interior. You wont see much but at least it wont be hollow.
Home 24/7 for the next 2-3 weeks (min). Anticipate getting alot of building in unlike the typical spring...
bison126
Correze, France
KitMaker: 5,266 posts
AeroScale: 9 posts
Posted: Saturday, March 21, 2020 - 08:00 AM UTC
Nice job on the driver compartment
Olivier
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 893 posts
Posted: Saturday, March 21, 2020 - 10:28 AM UTC
This vehicle is hugely overlooked by both modellers and companies. I could not believe that TAKOM released a Luchs and not a Fuchs.
Nice work so far, tuned in and watching.
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Saturday, March 21, 2020 - 03:40 PM UTC
Thanks Olivier,
There is a nice resin interior for this kit but not this time, just a filler.
Thanks Nikos,
Yes it is a interesting vehicle w/ alot of build options (style, country, camo, etc...).
I always wanted to build this one, been in my stash for at least 12-15 years...
Sunday always a good day for me to spend on the bench.
Should have more pics tomorrow.
HermannB
Bayern, Germany
KitMaker: 4,000 posts
Posted: Saturday, March 21, 2020 - 06:16 PM UTC
Hi TJ,
if you can it these days, MR Models from German makes some neccesary update sets.
https://www.mrmodellbau.com/1-35-MR-Models/Complete-Models-Conversion-Kit/Bundeswehr:::1_2_54.html
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Wednesday, April 01, 2020 - 12:01 PM UTC
Little bit more progress...
barkingdigger
KitMaker: 3,792 posts
Posted: Wednesday, April 01, 2020 - 11:40 PM UTC
Looking good! I have one in the stash that may come out for the upcoming Bundeswehr campaign. Your interior really does the trick - and the chances of getting any AM stuff at the moment is nil since nothing is moving out there. The skies in east London are empty! At least I can hear the birdsong now...
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Thursday, April 09, 2020 - 10:06 AM UTC
Thanks Tom.
And yes, not alot happening right now...
Minor update and warning:
Glued on the tools, exactly per kit. Tools did not line up w/ mounting holes, no room, etc...
Looked at some of the pics I found on-line. Whole passenger side layout as fantasy.
Everything had to come off, fill holes and sand it out...
Its not major but alot of build time became fix time.
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Saturday, April 11, 2020 - 11:18 AM UTC
Passenger side tool area fixed.
Driver side stowage done. Had to replace tow cable, too perfect, did not look right.
Finish few more parts and its off to the paint booth.
Colors? Not sure yet...
KitMaker: 1,625 posts
AeroScale: 1,290 posts
Posted: Sunday, April 12, 2020 - 12:58 AM UTC
Good work on the "Fuchs" until now. I have build mine some years ago as an SFOR TPz 1. About the colours, that are NATO standard Bronzegrün, Lederbraun and Teerschwarz. The RAL Code No. are 6031, 8027 and 9021. I use Vallejo paints and in their range the paints are numbered as 71249 (Brown), 71250 (Green) and 71251 (Black). Hope this helps.
Happy Easter!
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Sunday, April 12, 2020 - 04:42 AM UTC
Thanks Torsten, I'll check those colors out.
And a Happy Easter to you too!
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Monday, April 13, 2020 - 02:38 PM UTC
More progress, more pics.
Added TOW. The old ITALERI Weapons of the World, w/ the giant launch tube. Think only Danish (or Donuts) used TOW on Fuchs.
Research required.
Little more detailing and correction too...
Need idea for smoke grenade chains:
Thread?
Thin Stretch Sprue?
Magic?
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Monday, April 20, 2020 - 11:36 AM UTC
Posting while the paint dries...
Just put the primer down, waiting on that.
Few pre-paint pics.
MG and mount little sketchy, added & changed few things.
Nothing better then drilling out a few barrels on a Sunday night.
Mount Mounted
Faux Chains an a Bungee Cord
An More...
Paint colors picked (best match from the Pre-Lockdown Supply)
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Wednesday, April 22, 2020 - 12:52 AM UTC
Paint started, pics - On The Way...
Q: I rarely do Rubber Tyres - Paint System / Process for Painting?
EG: Seal, Prime, Acrylics, Oils, Etc.
trahe
Virginia, United States
KitMaker: 1,157 posts
AeroScale: 73 posts
Posted: Wednesday, April 22, 2020 - 01:30 AM UTC
Looking good. Whatever you decide to do with the tires, make sure you paint and seal the styrene rims really well. You don't want the rubber from the tires in contact with the styrene. Takes a while, but bad things will end up happening...
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Thursday, April 23, 2020 - 05:17 AM UTC
Thanks Tom.
Primed and painted the plastic side of the wheels, should be good.
Anybody else got ideas for the rubber side?
And - started to block in colors, very complex pattern with the shape of the side panels...
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Saturday, April 25, 2020 - 04:22 PM UTC
Mini Update:
Wheels done.
Tyres still ?
What it should look like, and what it does...
Black covers great, Brown is OK, Green not so much.
Should sprayed it...
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Tuesday, May 05, 2020 - 12:11 PM UTC
Update:
My take on weathering rubber wheels...
terminators
France
KitMaker: 1,894 posts
AeroScale: 10 posts
Posted: Tuesday, May 05, 2020 - 12:33 PM UTC
Nice work. I have just noticed I'm working on the same kit.
Neo
KitMaker: 910 posts
AeroScale: 22 posts
Posted: Sunday, June 21, 2020 - 11:38 AM UTC
Thanks Alex.
Calling this one done.
Didn't get the level / style of weathering I wanted.
Was trying for just a slight dusty look.
Next time (maybe)...
