Armor/AFV: AA/AT/Artillery
Building the 128mm. Flak 40 from Hobby Boss
OldWarloke
KitMaker: 2,569 posts
Posted: Monday, March 23, 2020 - 05:17 AM UTC
Moving on.
I glued the bottom of the elevation cylinders to their base being shure they were movable.
Then inserted the upper cylinders over the bottom ones. spread the sides and inserted the pins into their openings. On the left side it's really loose because their is another part that goes into the large opening and moves with the gun.
There are 2 different length travel locks.
OldWarloke
Posted: Monday, March 23, 2020 - 05:29 AM UTC
Now the gunner seats, They would have you snap the seat frame to the mount, this is asking for problems.
It's easier to trim off the bottom bump on the mount and drill a hole sutable to what size rod you have.
Insert and glue the rod being shure the frame can move.
Trim off the extra rod and install the rest of the parts.
Easy yes/no ?
Finished for now.
Donald
OldWarloke
Posted: Wednesday, March 25, 2020 - 01:24 AM UTC
Here's how far I am along.
Up detailing the platforms a little.
That's all for today
Donald
dhines
Nova Scotia, Canada
KitMaker: 394 posts
Posted: Wednesday, March 25, 2020 - 02:23 AM UTC
It is really coming along nicely Donald. I will keep following with much interest. Best regards.......Dale
OldWarloke
Posted: Thursday, March 26, 2020 - 08:06 AM UTC
Now for the Transport Frames and Wheels.
The Frames need a lot of filling and sanding on their mating surfaces.
One of the assembled wheels.
Here it is next to one of the Panzer Art Famo wheels I have.
OldWarloke
Posted: Thursday, March 26, 2020 - 08:11 AM UTC
Note the wire at the edge of the rim.
It is shown in the Pics.
And before anyone says the kit rim is larger, it's not!
Here are two pics. showing the kit rim ontop of the Panzer Art Wheel.
Regards.
Donald
OldWarloke
Posted: Saturday, March 28, 2020 - 06:33 AM UTC
Just out of the paint shop.
A little detail, I made some ends for the tow bars, probably not accurate but what the hell it works.
Now for a little detailing and then the final assembly.
Donald
OldWarloke
Posted: Sunday, March 29, 2020 - 09:27 AM UTC
To install the tires on the rims.
First check the sizes of the openings, one will be larger than the other. You will want the larger to be to the inside.
Install the rim as shown, this will keep the paint from being damaged.
Note the tight fit between the tire and rim.
There will be a gap on the back side.
OldWarloke
Posted: Sunday, March 29, 2020 - 09:34 AM UTC
The front and rear wheel units are the same.
I had some fine electrical wire that I used for the cables.
OldWarloke
Posted: Sunday, March 29, 2020 - 09:39 AM UTC
If you are building this kit in the travel position you will have to glue this all together, as it will not stay otherwise.
I also glued the arms in the folded position.
If you wanted the firing position, you should have bought the Amusing Hobby kit, it's a lot cheaper.
Regards.
Donald
OldWarloke
Posted: Tuesday, March 31, 2020 - 05:34 AM UTC
All finished , here are the Pics..
OldWarloke
Posted: Tuesday, March 31, 2020 - 05:38 AM UTC
OldWarloke
Posted: Tuesday, March 31, 2020 - 05:43 AM UTC
You can't really steer this thing as the wheels are too close to the fenders and hit them when turning.
I folded the railing on the loading platform so I could tuck it under the end of the gun. Hey where else is it going to go when traveling?
OldWarloke
Posted: Tuesday, March 31, 2020 - 05:49 AM UTC
This is it for my Pics.
Next are some I got off the internet
Just search Flak 40
OldWarloke
Posted: Tuesday, March 31, 2020 - 05:54 AM UTC
These are off the internet use them for refrence if you like.
OldWarloke
Posted: Tuesday, March 31, 2020 - 06:46 AM UTC
Just some thoughts on this kit and build.
First the minuses
#1 No decals or engraving for the Range setting, and altitude dials.
#2 Wheel units are too close to the fenders preventing this gun from going almost anywhere except in a straight line.
#3 Mix of gun loading platforms, one is a very course grid, and the other 2 are flat plates with a little texture on them.
#4 No end parts to hook up to a tractor.
#5 No cables for the 4 Reels on the fenders.
#6 Anchors shown in the firing position when gun is being towed.
#7 Openings in the tires for the wheels are larger on one side than the other leading to a bad fit of the tires on the rims.
#8 No brake mechanisms on the inside sides of the brake drums.
#9 Rail on the loading platform should have been made fodable so it could be tucked under the gun for travel.
#10 This kit should be built in either Firing or traveling mode, the gun unit won't stay very well on the wheel units if not glued there.
Ok, now for the pluses.
#1 Plastic is easy to work with.
#2 A very desirable subject.
#3 I can't think of anything else.
These are only my thoughts and opinions, but would I reccomend this kit?
Answer- A very very big (NO)
Regards.
Donald
Well I'm glad that's over, now to get on to something else.
BootsDMS
KitMaker: 891 posts
Posted: Tuesday, March 31, 2020 - 06:56 AM UTC
Well done Donald, what a beast! 'Very useful guide; not my particular cup of tea but I'm sure your style will assist those who will tackle it.
Brian
varanusk
KitMaker: 1,211 posts
Posted: Tuesday, March 31, 2020 - 12:53 PM UTC
Thanks for the detailed review. If I remember correctly, Amusing Hobby Flak40 was not better so we are out of options
KitMaker: 9,205 posts
Posted: Tuesday, March 31, 2020 - 01:16 PM UTC
As to the unsteerable wheel dollies: Is there any reference measurements as to if the overall wheelbase of the individual dolly is too long or the rotation point is located too far inboard towards the gun?
jfeenstra
KitMaker: 322 posts
Posted: Wednesday, April 01, 2020 - 04:06 AM UTC
Except Amusing Hobby is not an option if you want to build the Flak 40 in transport mode. AH does not include the bogies/trailer components, only the gun itself. So Hobby Boss becomes the only option, although Bold Division does still have their trailer available for the AH kit. And of course, the tire problem with the HB kit can be remedied with the Bold Division resin tires that are available separately.
