Armor/AFV: Large Scale
Building a 16th. Panzer IV Ausf. F
OldWarloke
KitMaker: 2,663 posts
Posted: Tuesday, January 07, 2020 - 08:17 AM UTC
The tabs on the large end mount are too big and need to be trimmed to fit the spots in the upper hull where they go.
Here is the rack assembled. not really pretty is it?
Test fitted kind of So So
OldWarloke
Posted: Tuesday, January 07, 2020 - 08:10 AM UTC
Today it's the Radios and their rack, first off If you don't have a good photo etch bender I wouldn't try this.
I'm showing just 1 section , they all go together the same.
First shows the rear frame of the single radios holder.
I bent the fixed edge then soldered the side.
Then bent & soldered the next.
Continuing all around.
russamotto
Utah, United States
KitMaker: 3,389 posts
Posted: Sunday, January 05, 2020 - 10:39 AM UTC
That's a lot of work for something that will be hidden. I appreciate that you showed it to us so we know how it all goes in.
OldWarloke
Posted: Sunday, January 05, 2020 - 08:39 AM UTC
The Upper Hull is painted.
Here's a good view of the Generator. Whatt you can't see it? Oh I get it , it must be under that little Radiator.
Just joking guys, though it really is under the radiator and was a waste of time assembling it. Most of the engine area is a waste of time and material.
If I ever do the Ausf.G version I'm skipping the engine.
Regards.
Donald
OldWarloke
Posted: Saturday, January 04, 2020 - 08:59 AM UTC
Finished for today
Donald
OldWarloke
Posted: Saturday, January 04, 2020 - 08:52 AM UTC
got a little painting done.
I remover the 2 raised sections shown in red used for positioning the jack block, I plan on making one out of wood.
OldWarloke
Posted: Saturday, January 04, 2020 - 08:46 AM UTC
After the glue set, it didn't quite work like I had hoped.
It looks like you have to choose the position and glue them in place.
Oh well some other parts installed.
There's a lot of flash to clean up on the fins.
HarrisHawk
KitMaker: 24 posts
Posted: Friday, January 03, 2020 - 11:16 AM UTC
Nice progress, I love functioning covers, hatches, etc...
Thanks for sharing.
OldWarloke
Posted: Friday, January 03, 2020 - 10:00 AM UTC
If you do it right they'll open and close.
After glueing it as shown above close the port and lit the glue set up.
Finished for a while.
Donald
OldWarloke
Posted: Friday, January 03, 2020 - 09:54 AM UTC
That front viewer was a real B itch to get in.
If you want the side view ports to open and close you need a little trimming on the parts so they work.
OldWarloke
Posted: Friday, January 03, 2020 - 09:46 AM UTC
Did the same for the drivers hatch, verry tricky here.
Not so good for the other one.
Hey I'm not purfect I show my screw ups along with what comes out right.
They give you the hatch for the G/H/&J models in the kit.
The hinges on the later hatch look a little bigger.
OldWarloke
Posted: Friday, January 03, 2020 - 09:42 AM UTC
Man I needed that nap (Yahaaan)
Well any way I did get some more done.
I drilled and pined the small hatches on the driver & radio operators hatched.
OldWarloke
Posted: Monday, December 30, 2019 - 08:34 AM UTC
These speak for themselves
I'm tired I think I'll take a long nap
Donald
OldWarloke
Posted: Monday, December 30, 2019 - 08:23 AM UTC
There's a thin line on each side where the upper armor mounts, if you mask it off it should make installing the upper armor easier.
Here's why I wish that I had left the rear fender parts off untill the fenders were installed.
I had to disconect them to get the fenders on.
Installed.
There's a small tab on the part that goes in a grouve as shown.
OldWarloke
Posted: Monday, December 30, 2019 - 08:19 AM UTC
Here I install the Fenders and side Bins.
First of course I had to paint them , painted the part of the interior that is White, then masked it & the areas where the Bins go.
OldWarloke
Posted: Sunday, December 29, 2019 - 04:57 AM UTC
The inner upright bin 23 Rounds here.
Of course I didn't finish the pointy ends here either.
Finished for a while now.
Regards.
Donald
OldWarloke
Posted: Sunday, December 29, 2019 - 04:50 AM UTC
The back side of the bin.
Now for the upright bins.
OldWarloke
Posted: Sunday, December 29, 2019 - 04:44 AM UTC
The final layer.
OldWarloke
Posted: Sunday, December 29, 2019 - 04:38 AM UTC
Now after removing the paint on the mating edges install the outside cover.
It's a verry tight fit if you want to install the cover first.
Now for the other side bins, this went a lot easier.
The first layer.
The second layer.
OldWarloke
Posted: Sunday, December 29, 2019 - 04:31 AM UTC
Like so.
Add the next row.
Add some liquid glue to the back side of the rounds.
It should look like this.
OldWarloke
Posted: Sunday, December 29, 2019 - 04:23 AM UTC
I have all the Ammo loaded in their bins.
Here's how I did it.
Starting with the assembled Bins.
Yes I know this pic is a repost, it's to show how it all starts.
After painting the Bins I slid the rounds in starting with the rear most ones.
This is the 6 Round Bin.
Be shure the edge of the round is against the support block and clear of the end of the Bin edge.
OldWarloke
Posted: Friday, December 27, 2019 - 10:47 PM UTC
Well it took a while but I finally have the ammo finished.
These will go in the side bins, that's why I finished the ends.
The rest go in the verticle storage bins, you cant see the front half of the rounds, so there's no point in finishing them.
I have short pieces of sprue glued to the ends to make it easier to handle them while painting them.
Now to install them.
Donald
OldWarloke
Posted: Saturday, December 21, 2019 - 10:23 AM UTC
That's all for a while, I'm working on the Ammo next.
Regards
Donald
OldWarloke
Posted: Saturday, December 21, 2019 - 10:15 AM UTC
Here are the Side Ammo Bins, it really helps to have a Photo-Etch bender for doing this.
They just need some paint, I'll finish assembling them when I get the Ammo finished.
Now for the 3 Spare Tracks on the fender.
You really have to work it to get the mounts over the Track.
Then I placed the assemblies in position on the fender and glued the mounts to the track. (NOT TO THE FENDER)
OldWarloke
Posted: Thursday, December 19, 2019 - 09:35 AM UTC
I like the Buffing M M Metalizers, as you can buff it, leave as is, or seal it with your choice of clear. It appears you're leaving yours as is.
That is correct, that way it can always be touched up.
Donald
