Hosted by Jim Starkweather
Revell 1/25 Roush IMSA Trans Am JPS Mustang
Posted: Sunday, December 01, 2019 - 02:26 AM UTC
Coming together nicely.
Posted: Tuesday, November 26, 2019 - 02:26 AM UTC
Joel, great work on the interior. I love the various hoses and lines which all add up to the subtle detail that you the longer you look at the pictures.
Seeing that work though raised a question I had been pondering, which is when did they introduce braided lines into race cars. when I look at pictures of early 70s F1 cars(thinking McLaren here) they don't seem to appear at all though when you see them in later life, restored and maintained they all have them. Do you know when they be came popular?
Michael,
Thanks for your thumbs up. It's always much appreciated.
As for the when and why of using braided lines, it's not so easy to nail down. The lines themselves have been around since mid to late WWII used on aircraft. The best I can figure without really doing the proper amount of research is mid 1970's. The lines were used to stop rubber lines from bursting from pressure loads.
As you can see I don't bother with AN fittings, but I'm thinking of painted strips of tape to represent them. When I make my move to 1/12 scale due to failing eyesight, I'll start to use some homemade form of them, as they cost a small fortune from the AM guys.
Posted: Tuesday, November 26, 2019 - 02:08 AM UTC
Joel,
When using masking tape for detailing I don't rely on the adhesive of the tape, I hit the start and finish ends with a fine dot of CA.
Detailing looks spot on, looking forward to seeing the engine work.
David,
Thanks for the tip. I'll try it out today if I can find some modeling time. This week has been a real bummer getting ready for Thanksgiving on Thursday.
Cosimodo
Posted: Monday, November 25, 2019 - 08:52 PM UTC
Dixon66
Posted: Monday, November 25, 2019 - 05:12 AM UTC
Joel,
Posted: Monday, November 25, 2019 - 02:18 AM UTC
Russell,
Thanks for your thumbs up on the added lines. I'm going to try tying them down into place as I'm hoping that it will look more in scale then just using strips of painted masking tape for wire wraps. Also, the tape just doesn't stick to the braided line one bit.
Nick,
Glad that you approve of my detailing efforts. One thing about these race car builders is that they never much considered us modelers when it came to adding color.
As for the engine, I'm starting it hopefully this week. But with Thanksgiving quickly approaching, and my wife is once again hosting both Thanksgiving and Christmas for the few family members that are still left, there is a really full Honey To Do list that I've got to accomplish before Thursday.
Jesper,
Thanks Buddy for your Thumbs up. It's always greatly appreciated.
Nick,
Jesper,
Posted: Sunday, November 24, 2019 - 10:06 PM UTC
Looks spectacular Joel. The added detailing really makes a difference.
Stickframe
Posted: Sunday, November 24, 2019 - 04:16 PM UTC
Hi Joel,
This really beginning to shape up nicely - I like all the contrasting colors under that black body! And yes, I’m still looking forward to seeing that engine!
Looking good - cheers
Nick
Nick
Posted: Sunday, November 24, 2019 - 09:59 AM UTC
Joel, all those additions of fuel lines and wiring etc lifts the build to the next level!
(makes my efforts look ham-fisted at best
Posted: Friday, November 22, 2019 - 07:23 AM UTC
Well, another week, and I actually managed to get some work done for a change.
All my efforts were concentrated on getting the basic detailing done in the trunk area, even though I said that I'd finish the complete rubing and polishing of the two part shell, and lower chassis panels. Rather then go through each item, I'll just list them with any info that might be helpful.
1- Two .035 Braided oil lines from the Dry Sump tank to the tunnel in the Driver's compartment. Lines still need to be somewhat tighter going into the tunnel, and plastic clamps stratched out to hold them in place.
2- One .025 Braided fuel line to the fuel pump on the right hand side of the tube frame, & a over flow line from the tank routed down through the bottom of the chassis made from wire sheathing. Hold down brackets also need to be scratched for the fuel line as well.
3- Two electrical lines from the battery box to the cockpit tunnel out of a larger dia. wire sheathing.
4- The driver's compartment rear bulkead for some strange reason is where the plastic Windshield washer container is located. I ran a clear line from the pump on the bottom of the tank to just to the side of the drivers compartment for now ,till I actually can figure out where it does go.
5- I glued up the basic engine block and transmission, then sanded all the seams to get ready for priming. Nothing special, so no pictures till it's primed. And once again I had real issues with finding a glue that actually glued the Revelll plastic.
Overall view of the chassis.
front of the drivers compartment facing the rear bulkhead. Notice the windshield washer tank and line.
As I've mentioned in previous updates once the main shell is attached, very little of the trunk compartment will be seen, and that's only when looking in through the rear window. Here's a few views to see just how restrictive it actually is.
Posted: Tuesday, November 19, 2019 - 05:09 AM UTC
Russell,
Thanks for your continued support and approval. Just not so sure that I could call what I've accomplished magic by any stretch of the imagination.
Posted: Monday, November 18, 2019 - 11:34 AM UTC
continuing to work your magic, here Joel
Posted: Monday, November 18, 2019 - 02:33 AM UTC
Nick,
Gotcha. Sorry that I missed your point.
My personal opinion is that the roll cage dimensions are spelled out in both the IMSA and SCCA car regulations, it's not something that Roush Engineering completely fabricated on their own. I'm not even sure that they would be allowed to add any additional tubing.
As I said, the cars ran in different eras and used completely different engines. Mine a big HP V8 while yours was a much smaller Inline 4 turbo charged. So it's really hard to compare the engines. But as far as kit molding goes, the Revell engine does leave a lot to be desired. For that matter most of the engine bay components aren't molded very crisply at all.
One thing that I've noticed kit vs actual pictures of the JPS Mustang rear trunk area is that Revell didn't follow anyone design nor specific car, as I can't find a single picture that looks close to what Revell molded. Another reason why I didn't bother to cut open the rear trunk deck.
Now the Folger's Mustang class of Roush Revell cars has a single piece body which I really prefer and like over this two piece affair that does have a ton of fit issues. And the engine hood and trunk lids are both removable. A major plus for me.
Stickframe
Posted: Saturday, November 16, 2019 - 08:19 AM UTC
Hi Joel,
Yep, I realize the differences both in the model kits and the real deal. Nonetheless, or maybe consequently, I’m curious to see how the driver's area and motor turns out on this build. The four link rear end, fuel cell and front struts look similar on both, while the roll cage is clearly dissimilar.
Nick
Nick
Posted: Saturday, November 16, 2019 - 06:39 AM UTC
Nick,
I'm no expert by any means, but our two builds are only related by the name Ford, and that they once ran in IMSA classes.
The Monogram kit is an excellent representation of the 1981 IMSA Camel GT series car, which followed the FIA Class 5 specs. Baically the car was a tight course specialist as it could out preform the twin Turbo Porsches of the day. It was powered by a 1.7L, fuel injected, 4-cylinder, turbo charged motor putting out 560HP.
The Roush JPS Mustang ran in the IMSA GTO class & SCCA Trans AM series, and had a normally aspirated V8 5.1 cu engine pumping out a mere 710 hp. Needless to say it was the cream of the crop, and the dominant winning car.
From following your build and with my struggles with the Revell kit, you built the way better of the two kits.
Stickframe
Posted: Friday, November 15, 2019 - 01:44 PM UTC
Hi Joel,
Your Mustang is coming right along - looking good! I’m curious to see more of the layout inside the chassis - how the driver’s seat and dashboard fit, engine placement etc. It’s also interesting to see how different this kits is from my IMSA Mustang - they don’t look too similar at all!
Keep up the good work
Nick
Nick
Posted: Friday, November 15, 2019 - 01:51 AM UTC
Looking good Joel. I always like your detailing, which conveys the knowledge you have of how race cars should look. I am always undecided what do especially in the interior since usually I don't know what should be there etc unless there is some clear picture.
Michael,
Thanks for the thumbs up. It's always greatly appreciated.
As for my great wealth of knowledge, a vast majority of it is from Google searches asking specific questions, the results most often bring up new sites that sometimes have exactly the information I need.
The Roush Mustangs from 1986 to the 1989 basically all look the same, and most were built on very similar tube frames with body work that was really quite similar. As I confessed to screwing up the issue of the "Whale Tail", the differences per year was mostly engine bay, drivers compartment layout, and trunk bay. Even one car carried over to the next season was so vastly different. Endless, specific Google searches led down different paths with some amazing results.
The Revell kits including the Camaro are all basically the same kit with minor differences like the Ford and Chevy engines, and of course the body shell. But the guts of the kit are Identical. Not so in real life. I have so many detail and technical photos of rebuilds, original builds, interiors at the track, etc., that it quickly becomes apparent that basically one run of cars had major differences from the cars before and the ones to follow. Revell actually just combined a lot to add detail, or even made some of it up to fill open space, but I haven't been able to find a single picture that shows the exact trunk compartment that's in these kits. I guess that Revell figured it was good enough for the time.
For me I have a certain set of goals for each build, and they do vary by build based on the objectives I have in mind. I pick a certain car/driver, and try my best to duplicate the exterior with proper decals and exact colors as a display presentation piece. I like to kind of detail the engine with basic ignition wiring and fuel injection, and maybe some engine bay lines as well. If another section of the car is visible when displayed I try to run some lines and wiring from one component to where ever it goes to add a little more realism.
This isn't by any stretch of the imagination accurate detailing to any real degree. What I do, anyone on our list can do the same, and many of you can do a much better job of it then I do.
Cosimodo
Posted: Thursday, November 14, 2019 - 06:20 PM UTC
Posted: Thursday, November 14, 2019 - 09:15 AM UTC
It's been quite a few days since I last updated my Roush Trans Am JPS Mustang. Honestly, I haven't had much time of late between the same family issues that just never seem to get resolved, and now with the holidays approaching way to fast. But I've managed to get some work accomplished.
I still haven't rubbed out the clear coat as yet, but it's on the top of my "To Do" list this coming week. Instead, I started to focus on various parts and planning details like hoses, braided lines, and electrical lines.
I added the fuel cell, dry sump oil tank, and battery box in the trunk compartment and started to drill the necessary holes for the various lines, keeping in mind that the only viewing angle will be through the glass panel in the trunk lid that will be closed.
Then I started to focus on the driver's compartment by test fitting the rear bulkhead. There's still a few electrical boxes to be added as well as all the various wiring to add before it's glued into place. And then the right side Aluminum sheet cover that all the various lines etc. pass through rather then just being clamped to the driver compartment floor, plus the wiring for the electrical boxes on the top of it.
And that where I'm presently at.
Posted: Thursday, November 07, 2019 - 01:38 AM UTC
Rich,
Got it. And thanks.
Got it. And thanks.
rdt1953
Posted: Wednesday, November 06, 2019 - 02:35 PM UTC
PM sent - check your inbox
Cheers - RT
Cheers - RT
Posted: Wednesday, November 06, 2019 - 02:22 AM UTC
Russell,
Thanks buddy. I really appreciate your thumbs up.
Posted: Tuesday, November 05, 2019 - 09:42 PM UTC
You are the master of shine, Joel!
I have to admit, I admire your determination and effort. Far beyond what I could muster on my own builds
Posted: Monday, November 04, 2019 - 02:32 AM UTC
Russell,
Why thank you my friend. Your thumbs up really means quite a lot to me.
I'm hoping that I can use finer grits of wet emery cloth so that the polish and wax will have a even greater shine and depth to it.
I've really been focusing on tweaking my total gloss painting procedures, especially how I apply the various coats. Finally, the bulb over my head turned on, and it looks like I'm on the right path. Just hoping that the next paint job turns out this well.
Posted: Monday, November 04, 2019 - 02:28 AM UTC
Michael,
Thanks so much for your most positive thumbs up, it's certainly greatly appreciated.
I can assure you that I really lucked out with the stripping, and starting from scratch a 2nd time. Usually I'm not that lucky.
