OFFICIAL: Schwalbe II
Posted: Thursday, August 06, 2020 - 02:19 PM UTC
Russ, I use MLT to thin pretty much everything now, acrylics, enamels and lacquers.
eMan, excellent progress, neat looking build so far. Any issues to report? I'm looking forward to moving forward with this one as part of my A-2a U2 dual build.
Joe, great to hear from you, such good news that you are heading home. Hopefully the recovery will continue at a good pace and you will feel up to building once again.
KitMaker: 4,648 posts
AeroScale: 1,938 posts
Posted: Thursday, August 06, 2020 - 04:55 PM UTC
Nice progress, Lap Man!
KitMaker: 3,959 posts
AeroScale: 598 posts
Posted: Thursday, August 06, 2020 - 09:41 PM UTC
nice progress EMan,
Joe, good to hear you're making the move homeward
Well, here I was in the process of pre-shading and suddenly realised I'd forgotten to spray the canopy first, so out with the grey!
Posted: Thursday, August 06, 2020 - 10:34 PM UTC
Markings and stencils on, seriously some of the best decals I have ever applied. Nice and thin, a quick 10 second dunk in warm water then slide into place. I used a drop of Mr Mark Setter on the surface, then a drop of Mr Mark Softer after it was properly positioned. The carrier film is nice and thin and they conformed beautifully to the surface detail.
Ready now for Dullcote then some light weathering.
Posted: Saturday, August 08, 2020 - 01:45 PM UTC
A couple of thins coats of Dullcote has unified the finish and mostly hidden away the edges of the decal carrier film.
Really nice detail on the undercarriage legs with separate torque links that fit together perfectly.
Locked down and secured for undercarriage assembly.
Posted: Sunday, August 09, 2020 - 11:17 PM UTC
I went over the whole airframe with a highly dilute shot of Tamiya Smoke, concentrated a bit on the underside panel lines and a few lines across the top of the wings. It isn't really visible in the images, but it ties the whole scheme together and adds a bit more variation across the surfaces. Another shot of Dullcote after that, then it was crunch time, off with the masking!
The upper nose section was a very neat fit when I test dry fitted everything, I must have pushed it slightly out of alignment as it cured.
Ready now for the finishing touches, wheels, bombs, RATO pods, antennae and canopy.
Posted: Monday, August 10, 2020 - 03:57 AM UTC
A bit of a late bench session tonight, this one is completed!
A great kit, highly recommended, any errors are from my 10 thumbs, not the kit!
Posted: Monday, August 10, 2020 - 07:48 PM UTC
Russell,
I've done that many times! Great to see more progress!
Gaz
Posted: Monday, August 10, 2020 - 07:50 PM UTC
Damian,
Congratulations! Fantastic looking Schwalbe! I might have a play with the Tamiya smoke some time, Thank you for the tip.
Gaz
Posted: Tuesday, August 11, 2020 - 03:52 AM UTC
Damian,
Gaz
Thanks Gaz, it really was a great kit to build and I had a lot of fun with it.
Thanks also for running another great Campaign, more Schwalbes is always a good thing!
Antilles
KitMaker: 671 posts
AeroScale: 614 posts
Posted: Wednesday, August 12, 2020 - 03:08 AM UTC
Damian, Gary, Joe and Russell: Thank You very much!
Damian: Outstanding work on Your Schwalbe! It really looks great. Congratulation on this one .
Oliver
Posted: Wednesday, August 12, 2020 - 04:00 PM UTC
D, that is really good work on your 262.
I will try to see if I can get paint and decals on these (2) a/c before the deadline.
eMan
#298
Hong Kong S.A.R. / 繁體
KitMaker: 1,182 posts
AeroScale: 351 posts
Posted: Saturday, August 15, 2020 - 05:31 PM UTC
More update pics.
Posted: Saturday, August 15, 2020 - 08:08 PM UTC
NIce Progress, Lap man! Great looking paintwork.
Posted: Monday, August 17, 2020 - 11:25 PM UTC
Sensational finish on V555 Damian!
Lapman, that's some sweet progress!
Ok, so, I ended up ordering the colours I needed (RLM 76 and 83) and in the end I went with enamels from the Sovereign Hobbies range of Colour coats... The reason being I decided not to go with acrylic you may ask? Well, after reviewing my stash and reviewing my paint stock it seems that I have all the paint I need to finish every kit I have in the stash
So why change now? Besides! Colourcoats spray very nicely, indeed
On with the pics...
First up, finished off some pre-shading
and application of the RLM76 Lichtblau
More soon-hopefully before the deadline
Posted: Thursday, August 20, 2020 - 08:29 PM UTC
Well, this is the first time I've freehanded the airbrushing of a plane... not bad if I do say so myself... Although there are a couple of areas around the engines that will need tweaking...
Gaz, I reckon I might need an extension... All this home schooling business has seriously impeded my bench time
Posted: Thursday, August 20, 2020 - 10:50 PM UTC
Nice work Russ, looks like you will tune up this free-hand airbrushing in no time! What paint did you use for the top colour?
Antilles
KitMaker: 671 posts
Posted: Friday, August 21, 2020 - 01:10 AM UTC
Russell: Camo looks spot on ! Nice work!
Oliver
Posted: Friday, August 21, 2020 - 10:45 AM UTC
Russell,
The paint looks great! Nicely free-handed. Extension... no problem.
Our new date will be September 14, 2020. Let me know if you (or anyone else) need(s) more, mate.
Gas
Posted: Friday, August 21, 2020 - 02:06 PM UTC
Damian the top colour is RLM 83 by Colourcoats
Fingers crossed I can tidy up the over spray without over spraying
Oliver
Oliver Thank you
Russell,
Gas
Gaz Thank you Fingers crossed, but I reckon 2 weeks should be enough to overcome the hurdle of home schooling
eMan
#298
Posted: Sunday, August 23, 2020 - 12:50 AM UTC
Me262A-2A-2a/U2 Jet bomber finished.
Posted: Sunday, August 23, 2020 - 03:52 PM UTC
Lap Man,
Congratulations on successfully completing the campaign. Your Schwalbe looks fantastic!
Great job!
Gaz
Posted: Sunday, August 23, 2020 - 03:56 PM UTC
Carlos,
I must apologize for missing your completion post a few weeks ago!
Your schwalbe looks fantastic. I noticed it today in the gallery and realized I hadn't added it to the completed list. So, I went back to check. I'm very sorry.
Congratulations and well done! Your Schwalbe came out perfectly.
GAz
Posted: Sunday, August 23, 2020 - 10:39 PM UTC
Very nice clean build eMan, well done! I'm about to start assembly of the same kit as part of my dual build.
Posted: Friday, September 04, 2020 - 12:24 AM UTC
nice work eMan
Decals and Shiny coats are on Airfix's 1/72 offering..
next steps: pin wash; assembly; satin coats...
Estimated completion on the 13th
