Cars: Muscle Cars
60's & 70's Classics
Revell 1/24 1978 Trans Am
Posted: Wednesday, August 28, 2019 - 12:49 AM UTC
Russell,
Ain't that the truth.
KitMaker: 3,959 posts
AeroScale: 598 posts
Posted: Tuesday, August 27, 2019 - 09:45 AM UTC
Hi, Russ. Nice build so far!
I use the same silver method on aircraft builds, and yes, it pays off.
But this Revell plastic is just, well, weird! It's like it's got a hard skin on it that scratches really easily, but is resistant to fine sanding without effort. Then once you break through it's super tough inside... hence my reason for spraying the whole lot silver...
I've never come across anything like it in all my years building kits... granted I've never done a Revell car kit before only AMT and Ertl, but still...
Hmmm... I've met this kind of plastic on MPC kits, and I wonder if your Revell is original Revell at all... However, as you said, you need to use a rougher sandpaper (I used 600 grit hardware store one), then soak the surface in extra-thin, and only after fine sanded with 1000 grit and up. It worked for me.
Following the build,
Gabriel
Welcome aboard Gabriel! great to have you along for the ride
Definitely a Revell molding/packaging from 2011, even has Revell stamped on the inside of the body shell. Although according to Scalemates the tooling was from Monogram back in the 70's.
As for sandpaper, I had to start with 240 grit on the worst areas (mold seams) then 400 grit all over, followed by 600 to finish...
Russell,
The older plastics varied all over the place. it was a real crap shoot what you'd end up having to work with. But it's the end results that counts.
Indeed it is Joel, and proves the point: it's model making
Posted: Tuesday, August 27, 2019 - 05:10 AM UTC
Russell,
Szmann
Netherlands Antilles
KitMaker: 1,977 posts
AeroScale: 295 posts
Posted: Monday, August 26, 2019 - 06:35 PM UTC
Gabriel
Posted: Monday, August 26, 2019 - 10:10 AM UTC
Russell,
Way to much work for me as well. What I will do is hand paint with primer the seams for issues. I'll worry about body issues when I prime, and fix what I think needs fixing. The rest I let slide.
Couldn't agree more Joel
normally I'd just fill any seems, sand, then apply silver paint with a brush to detect any imperfections, fill, sand, paint and repeat until the seem has gone as you can see here
on one of my floaty builds...
Posted: Monday, August 26, 2019 - 12:52 AM UTC
Russell,
Posted: Sunday, August 25, 2019 - 06:29 PM UTC
Great choice of subject Russell. Nice sharp work so far. The metallic blue is my favorit color for the TA. The rest-mod looks awesome. I do believe Fujimi or Aoshima makes wheels almost identical to the ones on the resto-m, if you want to pursue the resto-mod look.
Thanks Jesper yep, the blue is my favorite too gonna stick with the stock gold insert wheels though as I like the look of them
Russell,
I follow a few auto builders on You Tube, two of which only speak Japanese, I don't know a single word of it. But somehow I manage to follow their builds without much difficulty. Both of them prime every shell/body is black primer, then sand the primer down that will show glue issues, sink marks, and missed mold seems. Then they continue to sand till the primer is completely gone, or if putty work is needed they go that route. Then prime those areas again, and repeat. Way to much work for me, so I use the old look and feel approach.
That sounds like way too much work for me too Joel
Posted: Thursday, August 22, 2019 - 01:20 AM UTC
Russell,
Hwa-Rang
KitMaker: 6,760 posts
Posted: Wednesday, August 21, 2019 - 11:29 PM UTC
Posted: Wednesday, August 21, 2019 - 12:23 PM UTC
Russ,
Glad you finally made it. The paint job on the Trans Am looks pretty cool so I will interested to see how you do that, especially with the big bird. Nice idea on the silver primer. You're right in that it shows perfections, though I only usually find those out when using it as the final coat.
Hi Michael
good to have you along for the ride
Well, for the big bird, I'm gonna cheat and use the supplied decal...
I'm hoping to replicate the wonderful panel fit of the 1:1 as well! Just look at how those headlights fit neatly into the bumper
Cosimodo
#335
Auckland, New Zealand
KitMaker: 1,808 posts
AeroScale: 195 posts
Posted: Wednesday, August 21, 2019 - 12:17 PM UTC
Russ,
Posted: Wednesday, August 21, 2019 - 09:47 AM UTC
Well look what the cat dragged in !!!
Wonderful to have you join us here on the shiny side with a cool build Russ! You've made a good start (however long ago) and it looks very clean so far.
Thanks for looking-hopefully this won't be a long build!
Why don't you enlist and drop it in the Garage Queens Group Build as well? You might as well get a little ribbon for such a nice build!
Looking forward to more progress reports mate.
Hi D!
It's taken me a while, but here I am on the shiny side
Let's just hope I can do the Trans Am justice. If I can come anywhere close to the standard you guys build to I'll be happy...
As for the group build, I'm gonna give it serious contemplation. Normally group builds and I don't mix too well, but I think I might just be able to do this one
Russell,
I'll 2nd Damian's suggestion about enlisting in the ongoing Garage Queen GB.
You're making some really nice progress now. If you're still thinking about what color to paint it, I vote for the Blue as on the real life car. Sure hope that's yours.
Interesting choice of Silver as a basic primer for body issues. Do you completely remove all of it before the painting process starts?
Hi Joel! Great to have you onboard!
The silver is a technique I use on ships and planes when filling seams. Normally I'd brush it on to detect any imperfections before sanding and then priming (if required by the presence of any brass photo etch) ready for top coating.
I thought I'd give it a try here also, but I sprayed it on this time. Being a "shiny" surface shows any imperfections really well. I'll probably give everything a good rub down with 600 grit wet/dry, but, because I work with enamels, I'll not worry about taking it all the way back as the coverage is pretty good.
Definitely going with the blue. Even have the paint ready on hand
Here's another car with a similar paint scheme-yes, I really wish it were mine as this one is a resto-mod with a modern 6.0L V8 and 6 spd Tremec, but alas, I cannot claim it to be so
and one of those lovely haunches
I'll be looking to try to replicate the tail lights as closely as possible too...
Watching with interest!
Welcome aboard Charlie Sure hope I can do a good job on her!
ChurchSTSV
KitMaker: 350 posts
Posted: Wednesday, August 21, 2019 - 03:20 AM UTC
Posted: Wednesday, August 21, 2019 - 03:17 AM UTC
Russell,
Posted: Tuesday, August 20, 2019 - 11:26 PM UTC
Posted: Tuesday, August 20, 2019 - 11:13 PM UTC
Ok, well, no reason everyone else should have all the fun with these car builds, hey?
This is a build I've had on the go for several years now, with on/off spurts of activity in between stretches of working on floaty type things
First up here's what I'm aiming for
Revell would have you build it in black as per the "smokey and the bandit" scheme
And this is how the kit has languished for the last few years
And lately I've dusted it off and started work again with the goal to finish it before I return to the KGV to finish her.
Can I tell you, the fit of the parts within the kit is as awful as the fit on the 1:1 originals?
anyways, here are the headlight lens backs sprayed chrome,
and after vigorous sanding of the main body components I've applied a thin coat of silver. Now, I use silver as opposed to conventional primer as I find it shows up imperfections so much better than primer.
I stripped the chrome from these parts using the old oven cleaner method ready to customize and actually make the tailights look a lot more like the real thing
So that's where it's at up to this point. Next up, more sanding before painting the interior of the body shell and other components black in preparation to apply the blue to the outside!
