Hi All,
I was hoping someone with much more knowledge than myself about wingy things can help me with pictures showing not only the wiring on the engines of said aircraft, but also with pictures / drawings of what the engine nacelles look like structurally with panels / engines missing.
I have only come across some pictures of damaged aircraft myself
Thanks in Advance
Catalina & Skyraider Help Please
Posted: Wednesday, July 31, 2019 - 05:12 PM UTC
CMOT
KitMaker: 10,954 posts
AeroScale: 290 posts
Posted: Wednesday, July 31, 2019 - 07:36 PM UTC
Here is one that I took of a Catalina.
GaryKato
Posted: Wednesday, July 31, 2019 - 07:37 PM UTC
Posted: Thursday, August 01, 2019 - 03:27 AM UTC
Good evening,
for information abut the Catalina you should check
http://www.seawings.co.uk/
especially the manuals section
Best regards
Christian
Best regards
Christian
Posted: Thursday, August 01, 2019 - 07:44 AM UTC
Here's a Wright 3350 which lives inside the Skyraider:
Here's a Skyraider cowl open:
The Catalina used Pratt & Whitney 1830s. Here's one on a Dakota. The Cat installation was similar, except that the exhausts were routed to the top of the engine rather than the side:
Posted: Thursday, August 01, 2019 - 10:44 AM UTC
Hi Ladies & Gents,
Darren thank you very much for that picture!!
Gary thank you for the Skyraider manual link, I will check that out & see if they maybe do a Catalina one too!! 🤞
Christian that looks like a very interesting site, thanks for the link, I will check it out this weekend!!
Jessie many many thanks for those pictures a great starting off point for sure!! Just a question though, would the moving of the exhausts from the side to the top of the motor changed it’s layout in anyway??
Posted: Thursday, August 01, 2019 - 12:11 PM UTC
Jessie many many thanks for those pictures a great starting off point for sure!! Just a question though, would the moving of the exhausts from the side to the top of the motor changed its layout in anyway??
It's difficult to describe. The Catalina has 2 exhaust pipes instead of the Dakota's one. I'm not quite certain whether there were 2 manifolds (one to each side of the engine) or whether there was one large ring with one pipe on each end, wrapped up in a loop behind the engine. These pictures tease, but the manifolds can't be seen.
Okay, they won't display even as links. Here's the article. There are some good pictures here, but the exhaust manifolds are hidden.
http://warbirdsnews.com/warbirds-news/warbird-collections/commemorative-air-force-news/cafs-consolidated-pby-6a-catalina-restoration-update.html
Posted: Tuesday, August 06, 2019 - 10:11 AM UTC
Hi Jessie,
Thanks very much for those links, I could only get the second one to open atm, but very interesting for sure!!
Thanks
Thanks
Posted: Tuesday, August 06, 2019 - 10:45 AM UTC
Hi Ladies & Gents,
Does anyone make the main part of the engine or is their something close I could use? As I need to show a few damaged / missing panels that are behind the big bank of pistons etc
Posted: Tuesday, August 06, 2019 - 01:31 PM UTC
What scale are you building in?
Here's an R 1830 in 1/72 for the Catalina, and here it is in 1/48.
The Skyraider's R-3350 is less well served. This one is 1/72 but the only 1/48 version I could find is the Turbo-Compound version which was used by the Lockheed Constellation and Canadair Argus from Engines and Things. You'd have to do some serious surgery to the exhaust area to put it in a Skyraider.
Posted: Tuesday, August 06, 2019 - 03:12 PM UTC
Hi Jessie,
The Cat is in 1.48th & I have the Aries update cylinders, I just didn’t know if the engine block so to speak is available?? I got the 1/72 link to open but not the 1/48th??
The Skyraider is 1/32
Thanks
Thanks
Posted: Tuesday, August 06, 2019 - 03:54 PM UTC
There was a typo in the link. This one ought to work better. The Vector engine has the engine block.
The only way I know to get a really good 1/32 3350 engine is to rob it out of the Zoukei Mura kit, which kind of defeats the purpose.
Posted: Wednesday, August 07, 2019 - 10:36 AM UTC
Hi Jessie,
Many thanks for the link to the Vector engines, they look really nice!!
So if I got those would I need anything else to make what I assume to be the rest of the motor that sits in the main engine nacelles behind the exhaust pipes on the Catalina??
As the reference picture I want to model has some of the panels missing on that part.
Posted: Wednesday, August 07, 2019 - 11:03 AM UTC
You'd need to fabricate the engine mountings, wiring, hoses, cables and the exhaust manifolds. I think that if you ask those people who are restoring their Cat nicely, they'd take some photos of the relevant areas for you.
