1/72 Hurricane Mk I from Arma Hobby
Posted: Friday, January 18, 2019 - 11:34 PM UTC
Truly, you are a master, Magnus!
Posted: Saturday, January 19, 2019 - 10:36 PM UTC
Beautiful paint and masking job, Magnus!
The explanation for painting the markings prior is exactly what I thought. Looks like it works - did you disover any build up edges though?
And finally the codes with a thin layer makes sense. They look flawless and the color modulation on the camo is nice and even better visible after the wash.
Th
Posted: Sunday, January 20, 2019 - 01:31 AM UTC
Really love how the camo turned out Magnus and the markings
The paints you are using appear to be very promising with the shades .
Terri
Terri
Posted: Sunday, January 20, 2019 - 04:57 AM UTC
Russell! Thanks!
Thomas! It worked well but the Hataka paints had a lot less coverage than I am used to so I got a bit of paint build-up from the camo instead and also had a bit of surprising difficulties to cover the overspray from the markings!
Terri! Colours are good but please see caveat about covering ability above! Over a solid, grey or white, primer they perform flawlessly though.
The dreaded decals are on...
...and to be honest the Techmod decals performed well!
It got a coat of satin varnish this morning, I will do some work with oils tonight to liven up things.
Magnus
Magnus
Posted: Sunday, January 20, 2019 - 08:42 AM UTC
That's some fine paint result as always, Magnus! Well done also on painting the insignias and codes.
Posted: Sunday, January 20, 2019 - 10:40 PM UTC
drooling!
Think I have to get one of these
Posted: Monday, January 21, 2019 - 03:25 AM UTC
Magnus,
I don't get over to the Aeroscale forums much these days, but this morning I did, and I found your brilliant 1/72 scale Arma Hobby Hurricane Mk I build. so I grabbed a cup of hot coffee as it's 7F degrees here on LI NY, and read through both pages.
You did your usual excellent build. But what still amazes me is your masking, both making and using. Well done my friend, as the finished process looks as the real deal certainly would have.
Posted: Monday, January 21, 2019 - 09:43 AM UTC
Torsten! Thanks!
Russell! You know you need one
Joel! Good to see you back, I'm quite close to the finish line now!
Wash, filter, some pigments...
...and a coat of matte varnish!
As usual lately, a view of my better me: I don't cheat on the lower surfaces anymore!
A final overview after I have peeled off all the masking, no colour seepage
Magnus
Magnus
Posted: Monday, January 21, 2019 - 10:39 AM UTC
Magnus,
another perfect build. The masking is absolutely perfect.
Posted: Saturday, January 26, 2019 - 11:04 PM UTC
Joel! Once again, Thanks!
This one is now as finished as they get around here (meaning that there might be some small further adjustments before bringing it to a show when it has had time to mature a bit in the display cabinet here...).
I really enjoyed this build and the final result is more than worth the effort, it really looks like a Hurricane to me!
Some small points to watch: both I and a friend had difficulties closing the fuselage due to the cockpit installation being a bit wide. We both cut one of the lower cross members in the cockpit, it can't be seen after assembly and will allow the cockpit "cage" to flex just the tiny amount needed.
Also, many other things fit very tight. Be prepared with a drill to open up things like the holes for the axles in the wheels and the fitting holes for the exhaust stubs. I do however prefer that to oversize holes and a sloppy fit!
Finally, there is a faint line along the left upper side of the nose. For some reason I didn't notice it during the build process. I presume it is due to a mark in the mould (hard to fix since it would mean adding material to the mould which is always a tricky operation). As long as one knows it is there it shouldn't be difficult to remove, since I saw it after I had painted the model I decided to leave it as i was.
Get one, build it, enjoy it! Mine has now moved on to the collection.
Magnus
Magnus
Posted: Sunday, January 27, 2019 - 02:56 AM UTC
Magnus,
I'm really quite impressed with your finished build. Overall it's nearly perfect both in build, paint, masking/decals, and weathering. All elements work perfectly together. I'm sure that when you do bring it to a contest, it will do you proud.
That missed mold line is so small, that in real life I highly doubt that anyone would see it.
Posted: Sunday, January 27, 2019 - 04:53 AM UTC
Brilliant, Magnus- cheers!
Posted: Sunday, January 27, 2019 - 05:38 PM UTC
Another superb build and a fine addition to the collection, Magnus!
Definitely will be adding this kit to the stash!
Now, are you heading back to the Lanc or has another kit stepped up?
Posted: Monday, January 28, 2019 - 08:32 AM UTC
Beautiful build. Waiting for mine to come but may have become lost in its transit to the US.
Posted: Tuesday, January 29, 2019 - 04:48 AM UTC
Very well done and a great final look!
It improves much from your marking works and the time you spent though you had a few issues.
But pobably it not really matters much on how your paint sequence is. Paint build up edges could appear in any way.
Again: still quite envious about your Cameo plotter...
... now on to yor next ...
Th
Posted: Tuesday, January 29, 2019 - 08:05 AM UTC
Friends! Thanks a lot for your kind comments and Bob, I really hope your's isn't lost in transit, it would be a pity! As for the Lanc, my heart isn't really in it for the time being but it will get finished one day!
Posted: Saturday, February 02, 2019 - 04:01 AM UTC
Magnus,
outstanding work. Looks like it will fly away in the next moment! I especially like the landing and position lights. They look like 1/48 scale. Great !
Oliver
Oliver
Posted: Saturday, February 02, 2019 - 03:04 PM UTC
Outstanding
Terri
Terri
Posted: Saturday, February 02, 2019 - 09:11 PM UTC
Oliver and Terri! Thanks a lot! It's a model that is very easy to get a good result from, get one if you're into 1/72!
Magnus
Magnus
