Hosted by Steve Joyce
RedDuster
KitMaker: 6,963 posts
Posted: Thursday, April 25, 2019 - 08:25 AM UTC
Si,
Either you are the king of PE or insane...LOL. Really nice work, she is going to look sweet when finished.
Mark
I don't know about the King of PE, but certainly "slightly" insane to say to least!
Insightful as usual Mate.
Si
surfsup
KitMaker: 1,230 posts
Posted: Thursday, April 25, 2019 - 11:32 PM UTC
Si,
Mark
Si
Insane..I know that feeling. A good Scotch helps with that.....
RedDuster
Posted: Friday, April 26, 2019 - 06:38 AM UTC
Si,
Mark
Si
Very good idea indeed, and I have just the single malt for the ship modeller, it is called "Old Pulteney" and bills itself as the maritime malt, distilled in the port town Wick.
RedDuster
Posted: Saturday, April 27, 2019 - 08:27 AM UTC
Work started on the funnels.
One weak point of the kit is the funnel tops.
A bit off centre, but fixed.
basic funnel assembly, test fitted to the base.
Both funnels test fitted in place.
Next jobs, sanding the raised details off the funnels and adding the etch, also building up the detail on the funnel bases.
More soon.
Si
d6mst0
#453
KitMaker: 1,796 posts
AeroScale: 10 posts
Posted: Saturday, April 27, 2019 - 12:51 PM UTC
Si,
It will be interesting to see how those funnels finish out.
Mark
RedDuster
Posted: Saturday, April 27, 2019 - 08:42 PM UTC
Si,
Mark
You aren't the only one mate, there is quite a lot to do.
Thanks for looking,
Si
rdt1953
KitMaker: 1,069 posts
AeroScale: 882 posts
Posted: Sunday, April 28, 2019 - 06:17 AM UTC
Hi Si -
I've been following your build here with much admiration- the larger scale seem to suit you . Do you only model warships? I ask because I am curious as to whether there may be a Trumpeter 1/200 Titanic in your future ?
Keep up the great work !
Cheers- Richard
RedDuster
Posted: Sunday, April 28, 2019 - 08:23 AM UTC
Hi Si -
Cheers- Richard
Hi Richard,
Thanks for looking in. I am enjoying this scale, there is a depth and a level of detail I cannot match in 1/350th.
There could be a /200th Titanic somewhere in my future, I would love to see more Merchant vessel in 1/200th, post war Liberty or Empire would be great, or wartime tankers like the Ohio or San Demetrio, Won't happen though.
Si
KitMaker: 3,773 posts
AeroScale: 532 posts
Posted: Sunday, April 28, 2019 - 04:49 PM UTC
I reckon you could make a good guess, will post a pic od some of the work with today's update. (likely to go on tomorrow).
Si
um, no, no I can't
The kit was on the importer's stand at Telford, and we were allowed to fondle the sprues.
The naysayers were moaning that "we don't need another one of these, and why haven't they done something different as they have already done one". Not usual wingy territory, but I thought "yes we do, and this is the one!"
Tamiya 1/48 Mk1 spitfire??
Got it in one Russ.
My aviation interests tend to Maritime related, but this was such a great kit I couldn't resist it, and it includes markings for an aircraft that covered the Dunkirk evacuation there is a maritime link.
Chees
Si
Ah... understand now
I've a bit of a similar weakness when it comes to anything 1/72 WW2 RAF with a prop out front in little red boxes and don't get me started on Typhoons
RedDuster
Posted: Sunday, April 28, 2019 - 06:17 PM UTC
Si
um, no, no I can't
Got it in one Russ.
Chees
Si
The thought never crossed my mind.
RedDuster
Posted: Monday, April 29, 2019 - 08:53 AM UTC
More on the funnels,
Rigging attachment points made from plastic strip and attached to the funnel bases.
Moulded detail removed from the funnels.
The etched rivet details and funnel caps on the frets.
Funnel caps built.
Fitting the rivet detail.
Done, and the caps on.
The funnels sprayed black, and the bases off white.
Next job, funnels glossed decaled and matted. they will then need rigging points made up and attached before fitting.
Si
KitMaker: 4,574 posts
AeroScale: 1,925 posts
Posted: Monday, April 29, 2019 - 09:01 AM UTC
Si,
The tops of those funnels is interesting for sure. Nice job drilling it out.
With the other quality parts on the kit, I'm surprised those holes weren't molded open.
Gaz
Posted: Monday, April 29, 2019 - 09:24 AM UTC
nice details on the funnels Si.
Agree with Gaz: surely could have been molded open, if not, then partially?
d6mst0
#453
AeroScale: 10 posts
Posted: Monday, April 29, 2019 - 11:48 PM UTC
Si,
Gaz
What Gaz said.
Mark
RedDuster
Posted: Tuesday, April 30, 2019 - 08:45 AM UTC
Si,
Gaz
Thanks Gaz,
It was an odd omission, may have been an oversight, but on the other hand a simple and quick fix.
Si
RedDuster
Posted: Tuesday, April 30, 2019 - 08:53 AM UTC
Agree Rus,
But then again had they, issues with short moulding, or mould tags on each pipe to clean up.
Drilling them out was a simple task, to be honest even more surprised that Pontos did not supply the parts, as the do for the external pipes on theBismarck's funnel in this scale.
Si
JJ1973
#345
Niedersachsen, Germany
KitMaker: 1,819 posts
Posted: Thursday, May 30, 2019 - 07:30 AM UTC
Si,
just catching up with matters here on MSW - sure and steady progress, fine work with the funnels and the etch!! Looks very good!
Jan
RedDuster
Posted: Monday, July 08, 2019 - 04:59 AM UTC
Si,
Jan
Well that's me caught up with replies on my blogs, now, not likely this weekend, (off to Duxford on Saturday)., but hopefully next weekend.
Si
RedDuster
Posted: Sunday, July 21, 2019 - 06:15 AM UTC
Finally managed to clear some space in the old workshop to do a bit, mostly tidying up the funnel sub assemblies.
The fwd funnel, with the platform and steam pipes fitted.
And the After funnel.
Both funnels fitted down.
What appears to be steam whistles added to the platform, whistles painted brass, which I would assume to be correct for the period.
The ladders added to the fore-funnel, platform & base.
A quick overview.
The next job, scratchbuilding 24 turnbuckles for funnel stays. That will be quite "fun".
Si
TimReynaga
KitMaker: 2,370 posts
AeroScale: 296 posts
Posted: Sunday, July 21, 2019 - 06:46 AM UTC
Si
Si, You can have fun scratchbuilding them, but North Star Models produces a set of etch turnbuckles in 1/350 that look pretty good.
I used them on my 1/230 scale Olympia, thought they worked well.
Posted: Sunday, July 21, 2019 - 09:53 AM UTC
Great to see you back on the boards Si
Hm, I'm surprised no-one has come to the party with a set of AM 1/200 turnbuckles yet...
d6mst0
#453
AeroScale: 10 posts
Posted: Sunday, July 21, 2019 - 10:49 AM UTC
Si,
Nice work on the funnels. She is really taking shape.
Mark
Black_sheep
Bayern, Germany
KitMaker: 765 posts
AeroScale: 44 posts
Posted: Monday, July 22, 2019 - 05:35 AM UTC
Si
Tim those items would be great if one just could find these #*+& turnbuckles somewhere but they seem nowhwere available these days. Northstar have them not available since ages
RedDuster
Posted: Monday, July 22, 2019 - 05:53 AM UTC
You and me both mate,
I will come up with something, it has look effective, and be easy to replicate.
Si
RedDuster
Posted: Monday, July 22, 2019 - 05:57 AM UTC
Si,
Mark
Thanks Mark,
Great to make some progress again.
Si
