Hosted by Steve Joyce
RedDuster
KitMaker: 6,870 posts
Posted: Tuesday, February 18, 2020 - 09:14 AM UTC
Hot diggity dawg! Looks great Si
Thanks Russ,
She is looking more and more like a battleship with every addition.
Si
RedDuster
Posted: Tuesday, February 25, 2020 - 08:16 AM UTC
Didn't get time to post this yesterday, last weekend's progress.
The ladders for the lower sections of the masts.
The kit derrick parts, well one of the two sets.
Fitted to the masts.
At this stage they can still swing, so they can be positioned to clear the funnels and their stays.
test fitting.
The booms have now been fixed, the painted, along with the ladders. The masts have been secured in place.
Making the stays.
because I am using a thicker wire, it is easier to make them in three sections.
the stay assembled.
Lower stays being fitted to the fore & main masts.
All done.
The stays may need thickening up with a little paint.
next, the searchlights for the bridge-wings and the upper mast platforms, and 47mm guns for the lower platforms.
Si
Black_sheep
Bayern, Germany
KitMaker: 748 posts
AeroScale: 41 posts
Posted: Tuesday, February 25, 2020 - 08:52 AM UTC
Wonderful work, the ship is looking very busy now
KitMaker: 4,487 posts
AeroScale: 1,892 posts
Posted: Tuesday, February 25, 2020 - 06:22 PM UTC
Excellent, Si!
KitMaker: 3,642 posts
AeroScale: 493 posts
Posted: Wednesday, February 26, 2020 - 09:40 AM UTC
your attention to detail on the stays is first class, Si
RedDuster
Posted: Thursday, February 27, 2020 - 06:08 AM UTC
Thank you Thomas,
She is coming together, the pre-dreadnoughts were very compact and quite cluttered ships.
Appreciate your looking in.
Si
RedDuster
Posted: Thursday, February 27, 2020 - 06:09 AM UTC
Excellent, Si!
Thanks Gaz,
Appreciate your kind comment.
Brgds
Si
RedDuster
Posted: Thursday, February 27, 2020 - 06:13 AM UTC
Thanks Russ,
It was "fun" working out to build the stays with the heavier wire. I am pleased with the result, and they are not as difficult as they might look.
There are another eight to go each mask on from just below the lower top.
Si
Si
RedDuster
Posted: Friday, March 06, 2020 - 08:16 AM UTC
Busy time, finally found some time to sit down post last weekend's small update.
Some time a go, when I was building the bridge, I put together and painted the Navigation lights, put them away and forget about them.
Found them when I was looking for something else.
Now fitted in place.
The next job, the searchlights, a total of six.
The etched and turned brass pedestals and the resin lamps.
etch going on the lamp.
the main assembly of the searchlight done.
The Pontos searchlight compared to the kit parts.
Test fitted on the Bridgewing.
Si
Posted: Friday, March 06, 2020 - 12:03 PM UTC
Nice searchlights, Si!
RedDuster
Posted: Friday, March 06, 2020 - 08:54 PM UTC
Thanks Gaz,
As usual with Pontos, they are not as tricky to get together as they look, they still have a lens and an etched rim for to to be fitted.
A single piece injection moulded component is always going to look a second rate compared to the finesse of brass & resin, but to fair they are ok with a bit of added detait from scrape tch.
Si
d6mst0
#453
KitMaker: 1,713 posts
AeroScale: 10 posts
Posted: Saturday, March 07, 2020 - 01:24 AM UTC
Si,
Those searchlights are really a improvement over the kit lights.
Mark
TimReynaga
KitMaker: 2,276 posts
AeroScale: 279 posts
Posted: Saturday, March 07, 2020 - 01:36 AM UTC
...A single piece injection moulded component is always going to look a second rate compared to the finesse of brass & resin, but to fair they are ok with a bit of added detait from scrape etch.
I agree, Si, the kit part doesn't look too bad on its own...but that Pontos assembly is really striking! It is well worth the extra effort, IMHO
JJ1973
#345
Niedersachsen, Germany
KitMaker: 1,798 posts
Posted: Sunday, March 08, 2020 - 02:29 AM UTC
Hi Si,
great work, she's coming along very nicely!! Splendid PE work and fantastic details on top - I second what Tim says, even if they are most probably pretty fiddly, those searchlight stand out! They're worth the effort!
Jan
Posted: Sunday, March 08, 2020 - 09:44 PM UTC
Those search lights look great, Si
RedDuster
Posted: Monday, March 09, 2020 - 09:39 AM UTC
Si,
Mark
They are very nice Mark,
they add that little bit more depth.
Thanks for looking in.
Si
RedDuster
Posted: Monday, March 09, 2020 - 09:46 AM UTC
Thanks Tim,
I rather like them, they will add another touch to the detail.
Appreciate you looking in.
Si.
RedDuster
Posted: Monday, March 09, 2020 - 10:10 AM UTC
Hi Si,
Jan
Hi Jan,
They went together with a lot less fuss than I thought they would, but larger scale, the smallest parts are easier to handle and the design meant no fussy curving of delicate parts.
Very well designed indeed.
Thanks for looking in Mate, always appreciated.
Si
I am really enjoying
RedDuster
Posted: Monday, March 09, 2020 - 10:11 AM UTC
Thanks Rus,
A bit more searchlight action to come.
Si
RedDuster
Posted: Saturday, March 14, 2020 - 07:33 AM UTC
As promised, a bit more searchlight action.
All six searchlights built, sans lens and its outer ring.
Basic paint job, the bridge wing lights are white, and the pair for the mast platforms are the dark yellow.
The insides painted citadel "Grey nights steel".
Lenses and front rings fitted.
Fitting in place.
Overview.
That was last weekend.
Got the 47mm built and fitted today, will get that posted soon.
Si
Posted: Saturday, March 14, 2020 - 09:26 AM UTC
Awesome work, Si!
surfsup
KitMaker: 1,225 posts
Posted: Saturday, March 14, 2020 - 08:59 PM UTC
Lovely work on the Searchlights Si......Cheers Mark
d6mst0
#453
AeroScale: 10 posts
Posted: Sunday, March 15, 2020 - 10:55 AM UTC
Si,
Those searchlights look sweet.
Mark
TimReynaga
Posted: Sunday, March 15, 2020 - 11:23 AM UTC
The light looks perfect!
Those ladder rungs on the mast add a lot as well. Layer by layer, you are putting together something special!
Posted: Sunday, March 15, 2020 - 08:05 PM UTC
what Tim said
