Ships by Class/Type: Frigates
This is for topics on modern Frigates. For the sailing variety they should still go under Sailing.
Hosted by Todd Michalak
Australian FFG (Oliver Hazard Perry Class)
Choowy
KitMaker: 122 posts
Posted: Wednesday, October 09, 2019 - 06:32 PM UTC
Thanks Rus, what do they say, its all about the journey??
That's tough Mark, sometimes it just doesn't work out and then you come back later and its all good.
Added the life-rafts, not technically the correct layout for the time period but getting a bit over it now so they are stacked as per the PE provided instead of single mount. They did change shape and colour over the years. Typically grey colour nowadays. The white from earlier times adds some contrast.
Had a go at putting these tiny antenna together provided in the PE kit. If they didn't fly off into the ether I would fit them.
The copper filament is .19mm dia (.007 of an inch) used to add a tiny drop of CA glue.
Adding some paint helps to keep it together.
There are 4 of these onboard, (WSC-5 Fleet broadcast transmit/receive antennas.) Removed later from ships.
2 above the bridge.
2 on the STIR director
d6mst0
#453
KitMaker: 1,650 posts
AeroScale: 10 posts
Posted: Monday, October 07, 2019 - 03:09 AM UTC
Most certainly walking away when things go wrong too. That's why its taken 4 years.
Ned,
I just had that experience last night after an hour of trying to install PE railings on a turret.
Your work look great, those railings are sitting really nice.
Mark
KitMaker: 3,497 posts
AeroScale: 433 posts
Posted: Sunday, October 06, 2019 - 10:21 PM UTC
Spot on Russ,
practicing all of those techniques especially the hand positioning. Taking a leaf out of the sign-writers book, definitely the way to get steady results with paint and positioning pieces.
I hear ya, Ned. My KGV has taken 5 years and is still going
Looking great by the way, nice to see you trying the PVA for the railings
Choowy
KitMaker: 122 posts
Posted: Sunday, October 06, 2019 - 09:00 PM UTC
Thanks Si
Well that's the last of the guardrails fitted finally. PVA glue really works well on those. Dries clear, gives you some working time and fills gaps. Needed to adjust the port side railing area to accommodate the extra whip antenna.
Added the SPRBOC launchers. This represents the early ship config. They ended up with 2 port and starboard later in their life along with other countermeasures.
Also fitted the STIR director and the SatCOM dishes.
Pretty nice PONTOS railing pieces, they include a nice plan view in the instructions that's 1:1 scale showing all the various railing runs as a guide.
Getting close now, Main mast, SPS-49 mast to fit, 4 whip antennas, 2 fwd antennas, the comms fans (hangs off the main mast), some life rafts and a few storage lockers.
Choowy
KitMaker: 122 posts
Posted: Sunday, October 06, 2019 - 08:49 PM UTC
Spot on Russ,
RedDuster
KitMaker: 6,817 posts
Posted: Sunday, September 29, 2019 - 06:14 AM UTC
Hi Ned,
Very tidy work with the railings, especially around the bridge roof area.
Great job.
Si
Posted: Saturday, September 28, 2019 - 10:59 PM UTC
Thanks Russ, I'm not sure about that.(the satisfaction part) but we'll see.
It is good to know there's not too many steps to go now and that I haven't screwed anything up beyond fixable. Each step forward makes the stakes that much higher when you handle it again as there's now more stuff to bend, break off and damage!!
I hear ya, Ned
It gets serious as you move in for the finish. I utilize a number of methods to ensure there's no collateral damage: always take my time; only work one area at a time; and provide if necessary, hand rests to lift my hands to working height
Of course, the most important part: If I get the least bit frustrated: take a break
Choowy
KitMaker: 122 posts
Posted: Wednesday, September 25, 2019 - 10:37 PM UTC
Hi Mark, yes agree they do bring a nice level of detail. The more I do the easier they seem to be getting and not as daunting as I first thought. I'm finding it easiest to cut each from the fret, test fit it and bend as necessary then spray and final fit off.
Can see an end in sight now as I cross each section off.
Stern rails and RAST carriage done now.
d6mst0
#453
AeroScale: 10 posts
Posted: Tuesday, September 24, 2019 - 11:40 PM UTC
Ned,
Railings are never fun but when finish they do bring a lot of satisfaction. I disagree with the comment about long railing runs. I found it easier to install railings that finish a section no matter the length. If the length was long I just glued it a different points along its length and once in place run glue along the whole length to finish. The less PE I had to handle the better.
Mark
Choowy
KitMaker: 122 posts
Posted: Tuesday, September 24, 2019 - 05:54 PM UTC
The flightdeck nets and some port-side guardrails around the bridge ready for spraying.
The nets were an issue as they were starting to disconnect along the top of the PE section and become separate segments (as they are in real life) and as much as I hear that long PE runs are hard and you should cut them into sections, I needed them to be straight and there wasn't any reference line or flat surface to glue to. They fix onto the hull. They also required a bend as they are not flat in real life on FFG's. This did help to make the section more rigid where it wasn't split up.
Happy with that, need a touch up with paint, also a couple of the net holes have filled with paint and need "unblocking"
Therapeutic.........this aint!!
Posted: Sunday, September 22, 2019 - 07:50 PM UTC
Ned, you're getting really close to the finish line now. Nothing like the satisfaction that comes from sticking it out
Choowy
KitMaker: 122 posts
Posted: Saturday, September 21, 2019 - 09:42 PM UTC
Nice recovery Ned,
Si
Cheers Si.
Slow going but managed to get the fwd guardrails on. Needed a trim off the end then another PE post adding, paint then fitted.
Added the kangaroo decals as well. All RAN ships carry this on their superstructure or funnel. NZ ships have a black Kiwi and Canadian a red maple leaf.
RedDuster
Posted: Thursday, September 19, 2019 - 03:43 AM UTC
Nice recovery Ned,
Si
Choowy
KitMaker: 122 posts
Posted: Wednesday, September 18, 2019 - 09:09 PM UTC
Wow, that's bad luck Russell, hope you're back on track now.
Thanks, touched up the number with a tiny brush and its pretty well fixed now.
This ones HMAS Adelaide, the fist ship that RAN purchased from Todd Seattle shipyards (US hull number 17 in the Perry build numbers)
Posted: Wednesday, September 18, 2019 - 12:09 PM UTC
After a bout of pneumonia and a stint in hospital I've finally recovered to the point of being able to catch up with all the goings on over here at the MSW dockyards!
Ned, HMAS Darwin is looking mighty fine! The repairs look great and are hardly divisible from the parent paint.
Hope to see more soon
d6mst0
#453
AeroScale: 10 posts
Posted: Sunday, September 15, 2019 - 04:03 AM UTC
Ned,
The repair looks great, can's see any difference.
Mark
Choowy
KitMaker: 122 posts
Posted: Saturday, September 14, 2019 - 07:09 PM UTC
Many thanks Thomas, Charlie and Mark, appreciate you looking in and supporting.
Finally got some more progress done with the repair on bow. Still needs another mask and spray of black and then fix up the black shadow on the number that peeled off during the first repair mask.
I think it will be OK, very hard to see any artifact now (and I know where to look!!)
surfsup
KitMaker: 1,205 posts
Posted: Friday, September 13, 2019 - 04:53 PM UTC
Lovely work Ned and a great fix on the Flat Clear problem.....Cheers mark
ChurchSTSV
KitMaker: 350 posts
Posted: Friday, September 06, 2019 - 04:03 AM UTC
You are doing excellent work, Ned. Working in this scale can be tough but you are doing amazing work.
trahe
Virginia, United States
KitMaker: 1,153 posts
AeroScale: 73 posts
Posted: Friday, September 06, 2019 - 02:14 AM UTC
Ned, great work on the frigate. Keep the posts coming!
Choowy
KitMaker: 122 posts
Posted: Wednesday, September 04, 2019 - 07:35 PM UTC
Thanks Rus, so far so good, I'm happy with the repaint. Just need to get another bottle of matt black to touch up the drop shadow on the number in one area and then respray part of the anti-foul.
Thanks Jan, well I can manage to complete it but as for another one I don't know.....could be all over after this one!!
JJ1973
#345
Niedersachsen, Germany
KitMaker: 1,761 posts
Posted: Thursday, August 29, 2019 - 05:29 PM UTC
Oh....what everyone said, that's really bad and hurts. I can feel your pain!
What you did sounds good, I hope you're achieving the desired effects. And I hope you don't loose your love for your model over this!
Jan
Posted: Thursday, August 29, 2019 - 09:27 AM UTC
Proceed with caution Ned.
Good luck! Hope it can be rescued!
d6mst0
#453
AeroScale: 10 posts
Posted: Wednesday, August 28, 2019 - 11:59 PM UTC
Ned,
Well that really sucks, I never seen that happen before. Glad to hear your solution is working, just to bad you had to rework the hull.
Mark
Choowy
KitMaker: 122 posts
Posted: Wednesday, August 28, 2019 - 09:53 PM UTC
Thanks Rus and Jan.
Alas all is not well however.
I sprayed both areas around the numbers on the bow with a thinned down acrylic matt and ended up with this artifact.
I put it back into its case and walked away from it for a week.
Back on it today and decided that the easiest way to try to remedy was to carefully mask just outside of the decal and hit it with the original hull colour. Most of the effect was outside of the decal area anyway.
Gave it 2 light coats and it looks pretty good although I will need to touch up a small area below the number but this paint brushes on well. The other issue was when peeling off the mask tore a small piece of the drop shadow line off the number which I will need to replace by hand with a tiny brush (very carefully)
Not sure what went wrong but I did use water to thin the acrylic matt and perhaps should have used the thinner which is part water and part isopropyl alcohol. Anyway I don't have any more decals to fix and I don't want to risk trying to apply a matt coat over the whole model just for protection.
Back on track I believe. Will post a pic once I'm happy with the finish.
