Ships by Class/Type: Carriers
Topics on all types of carriers from the early 20th century to today.
Enterprise CV 6 - 1942
Cosimodo
#335
Auckland, New Zealand
KitMaker: 1,808 posts
AeroScale: 195 posts
Posted: Tuesday, September 04, 2018 - 10:10 PM UTC
Michael,
That is one amazing assembly of PE you have there. It really will add the detail to the ship.
Mark
No kidding! Will there be any plastic left at all?
Hi Tim,
No plastic was harmed in the making of this superstructure
The only kit part required is the deck.
Cosimodo
#335
Posted: Tuesday, September 04, 2018 - 10:13 PM UTC
Michael,
eventually I'm joining in, too. I just went thru your build from the very beginning - you are joining an absolutely amazing job! I fully agree with all comments made, this is going to be beautiful. Your etch work is marvelous, and certainly raises my interest in Infiny as an aftermarket seller.
I'm in and following and looking forward to your progress!!
Jan
Hi Jan,
Glad to have you along. After going through a quiet patch I have momentum now. I'll see how long it lasts.
Cosimodo
#335
Posted: Tuesday, September 04, 2018 - 10:17 PM UTC
Continuing to excel at the PE origami Michael!
Very nice work indeed and, even if those walkways can't be seen, at least we'll know they're there
Thanks Russ, I used to have a rule for building planes that if you can't see it don't build it With this, I don't know where to stop since I can't test fit it without finishing the hangar deck which requires some paint. Anyway, it's a good challenge
Cosimodo
#335
Posted: Tuesday, September 04, 2018 - 10:19 PM UTC
That PE is simply gorgeous! I still can't believe you're contemplating painting it!!
Hi Tim,
That hadn't occurred to me but since I have bought the paint I will try it out. Next time maybe.
Cosimodo
#335
Posted: Tuesday, September 04, 2018 - 10:25 PM UTC
More progress. Some tedious work on putting the in the second tier beams, 56 of them, and the base to the main beams. (I need to learn the technical names for these things)
The forward and side gangways(?) and the proof there is some styrene required for this build. Not attached as I think this will be easier to paint in sections.
And where we are now with only the main supports to be built.
Thanks for all your support and comments.
d6mst0
#453
KitMaker: 1,925 posts
AeroScale: 15 posts
Posted: Wednesday, September 05, 2018 - 02:13 AM UTC
Michael,
Nice work on placing those new beams. I hope you don't have any fit issues when you laid down that flight deck.
Mark
KitMaker: 3,957 posts
AeroScale: 596 posts
Posted: Wednesday, September 05, 2018 - 09:25 AM UTC
Indeed it is Michael
you know I think it will all be worth it as once completed it will be visible (in glimpses) and create a point of interest when viewing her.
In other words: Have at it, Sir!
You're doing a great job!
RedDuster
KitMaker: 7,078 posts
Posted: Thursday, September 06, 2018 - 07:53 AM UTC
Hi Michael
That is first class etch work mate, makes Intrepid look simple.
Si
Cosimodo
#335
Posted: Thursday, September 06, 2018 - 07:33 PM UTC
Michael,
Mark
I hope you're right. This is all done trust in Infini though their fit for the island was very good. But till then fingers crossed.
Cosimodo
#335
Posted: Thursday, September 06, 2018 - 07:35 PM UTC
Thanks Russ
I will have it at though my deck blue arrived yesterday so once this fore deck piece is complete I may get back to painting.
Cosimodo
#335
Posted: Thursday, September 06, 2018 - 07:38 PM UTC
Hi Michael
Si
Cheers Si! The Infini set is certainly extensive and the PE is easy to work with but there is still a lot of plastic that I have to get on to once I finish the shiny bit.
Cosimodo
#335
Posted: Monday, September 10, 2018 - 06:15 PM UTC
The forward flight deck support is finished with the key supports installed.
No detail too small to be missed for Infini. Small hose reels on the back of the supports.
With that all done now time to turn my attention to the more complex superstructure, the rear flight deck support, which is a two layer affair.
The lower level underside has been started.
This is a form of avoidance i.e. not having to start the painting but the PE is good to do once you get into the rhythm.
Posted: Monday, September 10, 2018 - 11:02 PM UTC
hose reels! Wow!
Looking good Michael!
Namabiiru
Rhode Island, United States
KitMaker: 2,888 posts
AeroScale: 307 posts
Posted: Monday, September 10, 2018 - 11:36 PM UTC
That's amazing!
If it were me, there would be CA glue or solder everywhere. Extraordinary!
Cosimodo
#335
Posted: Monday, September 17, 2018 - 06:02 PM UTC
hose reels! Wow!
Minute and fiddly, another Infini piece that if you know where to look you'll see it.
Cosimodo
#335
Posted: Monday, September 17, 2018 - 06:05 PM UTC
That's amazing!
It use to be that way, but I learnt a little goes a long, long way when it comes to CA. I spot both sides of contact with the glue using the tip of an old #11 blade. It usually works
Cosimodo
#335
Posted: Monday, September 17, 2018 - 06:08 PM UTC
Finished the lower level. The main posts stressed my patience. I hope the top fits on.
Posted: Monday, September 17, 2018 - 09:53 PM UTC
Fingers crossed it does Michael!
Cosimodo
#335
Posted: Saturday, October 13, 2018 - 02:48 PM UTC
The top, or the base of the front flight deck, depending on how you look at it, is done.
The main structure
the rear gangways
front walkway linking the two forward gun tubs
front gun tubs
the front side gun tubs
So after a few months procrastinating by burying my self in brass I finally started experimenting with the Tru-color paints. After a few more attempts I finally settled on a mix that would spray which means I got some colour of the hangar deck.
The actual colour, Deck Blue 20B, is darker than photo. Once sprayed, the finish is very good.
Which all means I could start on the Hangar walls. Taking a lead from Si I thought I would have all the hangar doors opened. Merit sought of help in that regard as the make the doors separately, so the outer wall looks the part
but the interior wall has this
but hey, who cares when you have Infini PE. This is all that you use from the first picture of the outside wall
and with the upgrade
It's a long time since I had to glue any styrene together in this kit
RedDuster
Posted: Saturday, October 13, 2018 - 08:18 PM UTC
Great progress Michael,
The etch work is outstanding.
Si
d6mst0
#453
AeroScale: 15 posts
Posted: Saturday, October 13, 2018 - 11:01 PM UTC
Si
Ditto!
Mark
Cosimodo
#335
Posted: Sunday, October 14, 2018 - 08:53 PM UTC
Thanks guys.At the moment though it seems never ending
rolltide31
#377
KitMaker: 1,481 posts
AeroScale: 7 posts
Posted: Sunday, October 14, 2018 - 11:03 PM UTC
Michael,
Amazing work, really glad to see that your putting that Infini Set through its paces. It looks quite extensive.
Can wait to see more
Dave
Cosimodo
#335
Posted: Monday, October 15, 2018 - 09:09 PM UTC
Michael,
Dave
Thanks Dave. There is plenty more to come.
Posted: Monday, October 15, 2018 - 10:29 PM UTC
Exquisite work with that brass Michael!
Looks like you'll need to re-enforce the stand to cope with the weight of all that brass!
