Ships by Class/Type: Carriers
Topics on all types of carriers from the early 20th century to today.
Hosted by Todd Michalak
USS Intrepid CV11 1944 -1/350 Scale
RedDuster
KitMaker: 6,439 posts
Posted: Wednesday, May 09, 2018 - 11:04 PM UTC
Yorktown to Intrepid.
For what it's worth, this isn't a ship change as much as a time change. Both Yorktown and Intrepid had the single quad 40mm on the stern as launched and finished the war with the twin quad 40mm configuration by the end of the war. The Trumpeter CV-9 Essex kit contains the single tub pieces as it's more of an "as launched" configuration.
Thanks Tracy,
appreciate the tip, did think about using that kit and building Intrepid straight out of the yard, but I prefer the '44 camouflage.
Thanks for looking in.
Si
RedDuster
Posted: Monday, May 14, 2018 - 01:47 AM UTC
This weekend's progress.
The front of the hanger superstructure fitted, a bit more filler needed.
Single mk51 director tub made by cutting down part of the twin tub, adding plastic strip ribs and a plasticard gusset plate.
The 40mm tubs under structure has been given a finishing coat of citadel liquid green stuff, this is easy to way to get a nice smooth finish.
Boxes, for want of a better name, around the hanger deck edges.
Hanger deck given a base coat of Tamiya AS8 sea blue.
and a top coat of Lifecolor 20B deck blue.
Rub down decals on the forward elevator.
The forward elevator in the lowered position.
First shutter section removed.
Starboard side done.
Port side done, except for the deck edge elevator. It would appear that the shutter divides must also be removed if the elevator is in operation, but I have not found any decent photographs of the exact configuration.
finally, there will be quite a few aircraft in the hanger, the first Helldiver part built and ready for paint.
More soon
Si
d6mst0
#453
KitMaker: 1,339 posts
AeroScale: 5 posts
Posted: Monday, May 14, 2018 - 02:51 AM UTC
Si,
Nice progress. Removing those shutters will really show off the hangers.
Having open hangers really prevented many aircraft carriers from fatal damage after a bomb hit. That is one lesson the Japanese never learned and pay dearly at Midway.
Mark
RedDuster
Posted: Monday, May 14, 2018 - 11:05 PM UTC
Si,
Mark
Thanks Mark,
I am surprised how well that process went.
Some of the drawings in the AOTS will allow me add a little exta detail, but a crowd of aircraft will fill most of it.
Thanks for looking in mate.
Si
KitMaker: 3,008 posts
AeroScale: 308 posts
Posted: Tuesday, May 15, 2018 - 02:15 AM UTC
looks like quite a lot of paint required to cover that hangar deck Si
RedDuster
Posted: Wednesday, May 16, 2018 - 12:59 AM UTC
It was a lot of paint Russ,
worth the base coat, gave the 20B a bit more depth. There is a lot more paint to go on this lady yet, (Might be worth buying some shares in Tamiya & lifecolor )
Si
Cadeus
KitMaker: 144 posts
Posted: Wednesday, May 16, 2018 - 04:06 AM UTC
I have been using modelmaster 20B deck blue 2159, good March and itís enamel. Lays down great when thinned. Slow drying though. I also use the AK interactive naval series sets AK 5000 and AK 5020. They have just about every naval color used in WW 2. My favorite are the 20B deck blue AK 5001, flight deck blue 21 AK 5024, haze gray 5H AK 5003, and the dark gray 5D AK 5021. With the life color though itís tough to clean up, soap and water works and isopropyl works but still takes time to get out of an airbrush, also it doesnít dry hard like tamiya and not as scratch resistant and sometimes doesnít like to stick to the primer, itís finicky but lays decent and levels ok. Great for camp coats where you donít need to attach masking tape over it, if you do, make sure it has a clear coat or you risk the paint lifting when you remove the tape. I would recommend the paint sets though even with what Iíve noted. Worth a look. Worst downside is price, I hope truecolor produces naval paint sets, Iíve heard wonderful things about them.
RedDuster
Posted: Wednesday, May 16, 2018 - 11:19 PM UTC
Hi Norman,
Wouldn't mind using model master but they are not easily available in the UK, . The lifecolor deck blue I had left over from the Independence build a few years back. The AK range I am not familiar with, might have a look for them as I will need to pick up the hull colours. I have always sprayed over a primer of basecoat, and have never had any problems masking over lifecolor paints.
Might have a look for the AK range and have a try. on the other hand I can match the light grey, ocean grey and dull black well enough with Tamiya colours.
Si
Cadeus
KitMaker: 144 posts
Posted: Thursday, May 17, 2018 - 12:47 AM UTC
If you want international shipping from the US on paints I recommend megahobby. They shipped to me in combat zones while deployed, maybe they can ship to the UK. They have a great selection of anything model building related. You can probably source model master from them.
RedDuster
Posted: Thursday, May 17, 2018 - 11:30 PM UTC
Thanks Norman
appreciate that mate, I will look into it.
Si
RedDuster
Posted: Sunday, May 20, 2018 - 12:49 AM UTC
This weekend's progress, which has revolved around the external hanger bulkheads.
The funnel trunkings, and other structure on the starboard side is somewhat bland. I have added a little detail, but as I am not adding any lighting even this is likely not to be visible.
The forward section.
The after section.
Having found a photo of an Essex using the deck edge lift, I have removed all shutters, trimmed out the divides and stacked them at the forward end.
The after bulkhead and port aft section with the sponson for 5" guns
All bulkheads test fitted.
I have no actual reference for this, with the elevators working I would assume there would be safety rail around the pit, as only one is provided in the Pontos etch I am saving that to go around the forward elevator on the flight deck.
The inner walls of the 40mm tubs and the boxes moulded onto the hanger deck given a coat of paint.
Following Trumpy's instructions the big lumps went down first.
All the bulkheads in place, I don't know whether it is me or the kit, but I am getting another tube of filler when I go the LHS on Saturday.
A few more aircraft ready for paint.
The forward section of the flight decks test fitted, a helldiver on the elevator.
I have test fitted the all three sections, but still have a little fettling to do on those.
More soon.
Si
d6mst0
#453
AeroScale: 5 posts
Posted: Sunday, May 20, 2018 - 06:42 AM UTC
Wow Si you are really making progress with the hanger and adding the little details.
It not you but the kit needing more putty. I go through a lot when dealing with ship kits. There is always a gap where the deck meets the hull let along having all of the superstructures sitting flush on the deck...In my dreams.
Anyway nice work, enjoying your posts.
Mark
Cosimodo
#335
Auckland, New Zealand
KitMaker: 1,274 posts
AeroScale: 184 posts
Posted: Sunday, May 20, 2018 - 11:58 AM UTC
Amazing progress Si and nice touches on the interior. I like the way you removed most of the doors but then you have plenty of planes to show off. I think when I get started I will have to be more judicious in that area.
I am interested, did your photo etch ste have any details for the interior because I note that mine has none. Given some of the detail they go to it seems an area overlooked for carriers.
Keep up the good work.
RedDuster
Posted: Sunday, May 20, 2018 - 11:30 PM UTC
Mark
Thanks Mark,
I do wonder sometimes, but the design of this kit with all those butt joins around the side of the hull is asking for trouble on the filling and filing front. On the other hand I cannot see how they could give that open hanger.
I do hope some of the added detail shows when the hanger is loaded with aircraft and the flight deck fixed down.
thanks for looking in.
Si
RedDuster
Posted: Sunday, May 20, 2018 - 11:37 PM UTC
Hi Michael,
My upgrade has nothing for the hanger either, which is slightly disappointing, but opening it was too tempting, I am banking on the aircraft drawing the eye from any lack of detail.
Meantime looking forward to your kick off mate.
Si
RedDuster
Posted: Sunday, May 27, 2018 - 02:16 AM UTC
Small update.
Recent trip to the LHS, picked up another 12 Corsairs and these Starfighter decals, the generic late war USN sheet(s)
Aircraft for the hanger, a bit of a production line.
With these projects a do jump around a bit, the paravane gear on the front end, the brass to reshape the front end of the hanger.
Fitted in place.
The structure for the paravane towing rails.
I haven't worked how they fit Ö yet, the instructions aren't clear.
The kit details down on the fo'c's'le head, neither the kit, not the upgrade makes any allowance for anchor cables, I know there is a lot of structure around the area, but I am not convinced the lack of cable will be unnoticeable.
More soon.
Si
Posted: Sunday, May 27, 2018 - 04:37 AM UTC
Ah the joys of aircraft carriers: repetition. And those decal sheets are no exception
Cosimodo
#335
Posted: Sunday, May 27, 2018 - 11:57 AM UTC
Hi Simon,
Looking good. Why did you need to re-shape the hangar end? Is that a kit flaw or a 1944 mod for Intrepid?
RedDuster
Posted: Sunday, May 27, 2018 - 01:04 PM UTC
You said it Mate, and decaling is not my favourite sport, but with these little aircraft it is really worth the effort.
I do bring this on myself.
Thnaks for looking in
Si
RedDuster
Posted: Sunday, May 27, 2018 - 01:22 PM UTC
Hi Simon,
Hi Micheal
The reshaping is to take rails for towing paravanes, it seems to be a refit made to a number of Essex class carriers. It is not included in the kit, but it is clear in the drawings in the AOTS on Intrepid.
I would guess, as the original release of this kit was the Essex straight out of the yard, unlikely she would have had the paravane gear. Just never got added to the kit.
To be fair a lot of this will be lost in the structure under the forward end of the flight deck.
Si
RedDuster
Posted: Tuesday, May 29, 2018 - 12:55 AM UTC
A bit of progress yesterday.
Port and starboard sections of the paravane gear in place, I an going to leave those alone to ensure they are solid before fitting the centre section.
On with filling on the hanger sides.
With the shutters open, I cannot use the supports in the kit for the after elevator, so some support at flight deck level is required.
And the elevator in place with some of the under deck parts.
More soon.
Si
Posted: Tuesday, May 29, 2018 - 02:47 AM UTC
Looking good Si.
The paravane gear looks very delicate.
JJ1973
#345
Niedersachsen, Germany
KitMaker: 1,665 posts
Posted: Tuesday, May 29, 2018 - 02:30 PM UTC
On here and following as well, Si! Or better, catching up with your work so far!
Very nice work as usual, and she looks excellent, with you corrections, the open hangar doors and the lowered elevator!
Jan
RedDuster
Posted: Thursday, May 31, 2018 - 07:19 AM UTC
Looking good Si.
Very delicate, unlike my language when I was trying to get it fitted straight.
Si
RedDuster
Posted: Thursday, May 31, 2018 - 07:22 AM UTC
Jan
Thanks Jan,
Always liked to Essex class with the hanger shutters open. The side elevator will be in the lowered position with another aircraft on it.
always glad to have you along mate.
Si
