OFFICIAL: 3rd Generation Combat Jets Campaign
Nito74
KitMaker: 5,386 posts
AeroScale: 635 posts
Posted: Monday, August 13, 2018 - 10:30 PM UTC
@Carlos
Very nice work on that Mirage, I like the camo.
@Pasi
Too bad about the Foxbat.
You will do a great job with that Eduard kit.
I like the Finnish camo.
@Mr.K
That Mig-23 is a very poor kit.
Go for the Saab.
@Michael
Good work on the AMK.
I've been having some back pain for the last weeks, so hard for me to sit, sleep,and being at the bench is very painful
Great to see all these cool kits getting build !!!
Posted: Monday, August 13, 2018 - 10:55 PM UTC
John,
Sorry to hear about your back, hope you're better soon!
Buckeye198
Ohio, United States
KitMaker: 596 posts
AeroScale: 197 posts
Posted: Monday, August 13, 2018 - 11:16 PM UTC
I'm only two months behind schedule for posting these pics, but that's okay I'll be building Airfix's 1/72 AV-8A Harrier, my first Airfix kit actually.
Cockpit tub and control panel have decal details. Fine for this scale, but unfortunately the decals aren't sized correctly.
Fuselage halves clamp the engine and tub in place, though again the fit is a little off. Mostly pretty good, but it takes some extra fiddling to get it all together just right.
Control surfaces were molded as a single piece that got clamped into the tail section. A little loose, but freely positionable. Nice compromise, I guess.
Engine cowilngs didn't sit flush with the fuselage without a fair deal of sanding.
I added details to the gun pods with a pin vise. I drilled out exhaust holes, barrels, and the opening for spent casings. Pin vise was easily the best $20 I spent
Dangeroo
#023
Zurich, Switzerland
KitMaker: 2,058 posts
AeroScale: 67 posts
Posted: Sunday, August 19, 2018 - 07:57 AM UTC
Good evening Gentlemen!
Some fine work so far! Really like those 3rd gen jets!
I have only two jets in my stash, one being an F-14, the other being a Phantom II. And as it seems you haven't got a Phantom yet, mind if I join you?
As disclaimer, this will be my first jet in 1/72 since I was a young lad, so bear with me here...
Starting Photo:
As you can see, I'm using an Aires Cockpit, also a first. It's not really for this version, but I'm hoping the difference will not be too noticeable once everything is fitted...
So for now, the pit is ready and started with the major components. Took quite some effort to make this fit into the Hasegawa kit (it was meant for a Revell kit), bit I finally made it.
Cheers!
Stefan
Posted: Sunday, August 19, 2018 - 10:22 AM UTC
Some progress on the AMK 1/48 Kfir this weekend:
Not bad so far, but some effort required. Fit of the intakes isn't stellar, especially underneath; and the instructions are lacking. They don't tell you to open the holes for the pylons nor to add that big keel panel towards the rear. But hey, we're modelers, right?
PasiAhopelto
Uusimaa, Finland
KitMaker: 514 posts
AeroScale: 239 posts
Posted: Sunday, August 26, 2018 - 04:11 AM UTC
Started MiG-21Bis by building and painting exhaust:
I think the tube right before exhaust nozzle is bit simplified: it should have lengthwise ribs and be divided into rings, and edge of the nozzle is too flat. Eduard's Brassin set seems to get it right, but I'm building this almost OOB.
iflytb20
#501
Kerala, India / भारत
KitMaker: 292 posts
AeroScale: 194 posts
Posted: Thursday, August 30, 2018 - 12:15 AM UTC
Would a Vietnam era MiG-21 be eligible for this GB? I have the Eduard Vietnam special edition in my stash. Even though the box doesn’t say so, I think it’s either a PF or a PFM. Thanks
PasiAhopelto
Uusimaa, Finland
KitMaker: 514 posts
Posted: Sunday, September 09, 2018 - 12:05 AM UTC
Getting ready to glue fuselage halves:
Nito74
Posted: Sunday, September 09, 2018 - 09:59 PM UTC
Yes, no problem.
SHAKY962
Buenos Aires, Argentina
KitMaker: 765 posts
AeroScale: 316 posts
Posted: Monday, September 10, 2018 - 10:16 AM UTC
@Michael,
I see a beatiful Delta!!!!!
LowFiveJoe_2
Virginia, United States
KitMaker: 47 posts
AeroScale: 43 posts
Posted: Tuesday, September 11, 2018 - 12:05 AM UTC
Pasi, I'm following your MiG-21 since I have the 1/72 MF from Eduard. Did yours come with the pre-colored instrument panels? If so, how did you go about matching the interior color?
PasiAhopelto
Uusimaa, Finland
KitMaker: 514 posts
Posted: Tuesday, September 11, 2018 - 05:46 AM UTC
Joe, I'm using Akan's Emerald Green (faded) for the cockpit, and it's close match but not perfect. Non-faded could be closer. Took a photo to illustrate this:
iflytb20
#501
KitMaker: 292 posts
Posted: Sunday, October 07, 2018 - 09:53 AM UTC
Yes, no problem.
Thanks for the green light John. I finally managed to get the time to post here as I was swamped at work
The Kit
My build is the Eduard Vietnam special edition
The contents of the box
The AM that I'll be using for the build.
The Marking
I plan to paint the kit as "5015" of the VPAF's 921st Fighter Regiment. This particular aircraft was allegedly flown by Nguyen Van Coc, the highest scorer of the VPAF in the Vietnam War. There are some debate whether the camo was green on NMF or green top with dark green mottles with an NMF underside. As it's not easy to distinguish the same from the B&W photo, I'm going to use a bit of an artistic liberty and make it green on green with an NMF underside. It looks way too cooler (IMHO )
Using the same liberty, I plan to paint the rudder NMF with just the dark green mottles
The Build
I started with the cockpit working in various sub assemblies. Unfortunately I was enjoying the build so much, I forgot to take enough pictures.
The KM-1 seat assembled....
...and painted. The pre-painted PE seatbelts made life so much easier.
Painted the exhaust tube.
Test fit of the various interior sub assemblies
I painted the mach cone before closing up the fuselage.
I sealed the fuselage....
...and painted the exhaust.
I wanted to improve the kit landing lights.
So I bought one of these...
....glued it to the back of the lens using clear part cement...
...and this was the final result.
The main gear leg assembly almost made me rage quit
Dryfitting the wings...
...which were soon glued to the fuselage. I also masked the canopy clear parts in preparation for the painting stage.
Painting
I used AK Interactive Xtreme Metal paints and boy am I in love with them
Masked the NMF in preparation for the green top coat
Base coat in on, time for.....
...the mottle camo.
Next up is the decals. The kit comes with "5017" markings, but I wanted to make it "5015" as per the photo.
Thankfully the decal sheet has enough spares for "5". Looks like some minor surgery will be needed to make the markings. All that in the next update.
Thanks for watching
KitMaker: 4,950 posts
AeroScale: 3,192 posts
Posted: Sunday, October 07, 2018 - 12:22 PM UTC
Due to a change in the Carpet Monster's diet, it ate the DECALS!!??!!. I'm changing my entry tot he Hasegawa 1/72 F-20 Tigershark. With a month and a half to go, it's going to be tight. Fortunately a couple of detail parts are already painted, so that'll speed things up.
Here it goes.
Posted: Monday, October 08, 2018 - 02:40 AM UTC
Here it goes.
You actually have until the end of December, Mark. You can do it!
Posted: Saturday, October 13, 2018 - 11:53 AM UTC
Looking good so far everyone!
Some progress on the AMK 1/48 Kfir. Bottom is now the correct shade of gray for the C7 courtesy of Vallejo:
Posted: Monday, October 15, 2018 - 05:17 AM UTC
Wow, disaster almost struck twice on this one campaign. I've been staring at the instructions for a couple of days, disbelieving that I need to paint both the headrest and the padding on the bang seat gloss red. Internet picture search turned up almost nothing except one artist's cutaway with both pads red. Well, OK, I'm going with a green pad and a red headrest. But wait.... Where's the seat? It's no longer on the sprue, nowhere in the box, ah crap another hanger queen on the same campaign?
A mad scrounge among all of the stray bits of collected parts is turning up nothing. Finally in a canister of parts marked F-105G, there's a lone bang seat already painted with a green pad and a red headrest. But wait, the Thud is already closed up waiting on the paint shop for an SEA camo. This can't be the seat for that plane, it must be the missing F-20 one. Hmm, I guess I already dealt with the color question. Oh well a couple of lost days and I just need to paint the one handed pilot to finish the cockpit.
Buckeye198
Ohio, United States
KitMaker: 596 posts
Posted: Friday, October 19, 2018 - 01:56 AM UTC
As usual, it's been a while since I've given an update, so this is gonna be a long one...kinda like Raj's update, but WAY less impressive than his build!
This is my goal for the build. I'm aiming for a dio of the Harrier landing on an LHA/LHD. I'm planning out the deck now, the deck crew is complete, and I think I have a good strategy for suspending the Harrier mid-air.
I took clear acrylic rod, softened it over a flame, then bent it around a Testors paint jar. Given the Harrier's unique exhaust ports, there wasn't really a central option to install the rod. Instead I planned to stick the rod through the rear exhausts, which ideally will be concealed pretty well by the pylons and armament. To add some structural support, I dug through the spares box for a thick missile which I trimmed to fit between the exhausts internally.
Initially I wasn't sure if I'd need one or two support rods, but it actually seemed very stable with just the one! That should make the display a bit more impressive
I found some good reviews for this, "Canopy Survival Kit". Basically it's like a free-form Eduard mask set...three sheets of precut shapes that you can modify to fit pretty much any canopy shape you come across. They come in that familiar yellow tape material as well as a clear vinyl. I got the latter for a better price, but I'm not sure it adheres as well as the yellow tape. I guess we'll see in a bit... At any rate, I masked with the Survival Kit and MicroMask.
I also splurged on a good primer. Stynylrez...stupid name, great paint. This time around I'm trying the black-basing technique. Basically, instead of priming light and darkening panel lines, you prime dark and lighten the panels between the lines. I think in 1/72 scale, it's easier to mottle solid panels rather than trace the panel lines. I didn't get the best picture, but I think it still gets the point across.
And finally we get to the problems...painting the underside. USMC Harriers in the '80s wore the RAF's camo pattern, which used an anti-flash white on the underside. In order to maintain the preshading, I treated the paint almost as a blending/dusting: highly thinned, super-thin layers, stop painting just before you really think you should stop. However, the coverage isn't going down so smooth. I have four theories, take a look at the pictures (not the best quality, sorry) and see what you think.
1. I sprayed too heavy-handed -- I know this is a tendency of mine that I really tried to resist this time around, but I'm sure that some of you would not be pleased with my technique
2. Paint isn't uniformly smooth (Iwata Com-Art...most convenient paint at my local art supplies store), though I did mix thoroughly with a paint mixer beforehand
3. Wrong air pressure -- I tried low pressure at first (15-20psi), then tried high pressure (30-40psi), but no noticeable difference in coverage
4. I didn't cover the model while it dried
Dangeroo
#023
Zurich, Switzerland
AeroScale: 67 posts
Posted: Monday, October 22, 2018 - 08:45 AM UTC
Some impressive work here guys! Pasi and Raj, your MiGs look great!
Well, here's my Progress. Unfortunately I forgot to take pics before primer, but here's the painting process:
And current state: Details painted, final Assembly (almost) done and Ready for decals:
Cheers!
Stefan
RhinoSpit
Bas-Rhin, France
KitMaker: 224 posts
AeroScale: 191 posts
Posted: Sunday, November 04, 2018 - 03:45 AM UTC
After 6 week in China, time to start this campaign !
iflytb20
#501
KitMaker: 292 posts
Posted: Monday, November 05, 2018 - 12:19 AM UTC
@Robby
Your scratch built display stand is way awesomer (See I had a make a new word to describe it)
I got some bench time and decalled the monster.
That's a lot of decals
The surgery went well
End in sight...
...and done. Next up, I attached all the fiddly bits. This was followed by another gloss coat and a matt top coat. And the end result is....... (drumroll)......
Thankyou for letting me be a part of the GB. This was my first ever post WW2 aircraft and I enjoyed building it. I might even build a few more in the future.
Thanks for looking
PasiAhopelto
Uusimaa, Finland
KitMaker: 514 posts
Posted: Monday, November 05, 2018 - 04:47 AM UTC
Nice work with the 21, Raj. I like how it turned out.
Meanwhile I've checked what would be proper missile combination for FAF MiG-21 Bis. All five pylons are almost always attached, quite often inner pylons have rails for R-13 missiles and often outer pylons are "clean". I think this is safe combination:
Not sure if I'll attach extra tanks and missiles, both should be valid options.
Dangeroo
#023
Zurich, Switzerland
AeroScale: 67 posts
Posted: Saturday, November 10, 2018 - 09:12 PM UTC
So, all those great MiGs Need some adversaries. Here's my F-4 finished, first ever jet since my "serious" modelling days:
Been a great Campaign, thanks!
Cheers!
Stefan
Posted: Monday, November 19, 2018 - 10:58 AM UTC
Great work all!
My initial go-round with paint on the 1/48 AMK Kfir C7. This is my first time using Vallejo for the whole paint job as I have their IAF set. Not too bad, though for some reason I had some trouble with the brown. User error, I'm guessing.
Will need touch up with the sand and the light gray, but getting there!
PasiAhopelto
Uusimaa, Finland
KitMaker: 514 posts
Posted: Tuesday, November 20, 2018 - 07:13 AM UTC
More colour:
Have to touch up some areas, and there will be small NMF area around exhaust and black green fairings, but so far trouble free build.
