World War II: Great Britain
1/72 Airfix Lancaster B.II
magnusf
KitMaker: 1,953 posts
AeroScale: 1,902 posts
Posted: Thursday, April 19, 2018 - 12:06 AM UTC
I have built models for more than 35 years by know but I have NEVER attempted a four-engined one, not until now at least!
So why this quite odd bird? A friend of mine commented when I told him that I had bought a radial Lanc that it was too odd for him. The opposite is true for me: odd enough to appeal to me ! I've always liked the Lancaster with radials. And then the perfect excuse for building it turned up in the shape of the Bombers campaign.
I've invested in a moderate amount of after market stuff (there is enough etched metal out there to drive anyone to bankruptcy or into the asylum or possibly both!), I picked the stuff that seems to me to be the most useful: wheels, gun barrels, interior stuff and canopy masks.
I got myself the Xtradecal sheet for the Mk II. The choice stands between one of the marking options from the kit (a + for the nose art) and one from the sheet (a + for the yellow bars on the fins). Difficult and important choices...
So, now it's officially on!
Magnus
KelticKnot
KitMaker: 768 posts
AeroScale: 656 posts
Posted: Thursday, April 19, 2018 - 01:34 AM UTC
Looks like an interesting alternative to the 'standard' Lanc, looking forward to seeing what you do with this
KitMaker: 3,959 posts
AeroScale: 598 posts
Posted: Sunday, April 22, 2018 - 03:32 PM UTC
All seated and buckled up for the ride Magnus!
Posted: Tuesday, April 24, 2018 - 07:52 PM UTC
Magnus
I'm signing up for the full run. As usual, I'm looking forward to watching you work your magic on this build.
magnusf
Posted: Wednesday, April 25, 2018 - 01:01 PM UTC
Friends! Thanks for keeping me company !
I'm working on the interior right now, takes a lot of time for very little result... I'll keep to what can be seen through the canopies and the turrets but it is still a bit of work to do, I might be able to present some photos later this week!
Magnus
Posted: Thursday, April 26, 2018 - 04:40 AM UTC
Looking forward to this one Magnus.
Do you have enough sticks?
KitMaker: 4,728 posts
AeroScale: 1,351 posts
Posted: Thursday, April 26, 2018 - 09:38 AM UTC
Magnus, signed up and following along on this build. Like others have said I'm interested to see what you do with this.
Now to sit back and watch
Bjreg3
#482
KitMaker: 83 posts
AeroScale: 14 posts
Posted: Thursday, April 26, 2018 - 10:39 PM UTC
Count me in! I’m looking forward to seeing what you do with this.
magnusf
Posted: Saturday, May 05, 2018 - 12:35 AM UTC
Damian! I've recently replenished my stock of sticks, stay tuned!
Friends! Thanks for your encouragement, it will probably come in handy during the process...
Sticks in action! I'm not used to this amount of bits and pieces... Interior has been improved using a moderate amount of photo-etch, probably leaving the majority of the parts off since it will likely not be seen at all! Another MAJOR IRRITAION: there were no seat belts included in the "interior set" so one of these were sourced on the open market (ebay...) and arrived here a few days ago...
Fuselage halves with most of the kit interior parts installed into them, enhanced once again with the most prominent pe-parts.
And now for something rather unpleasant (that I really knew beforehand after my Lightnings...)
The surfaces really are a bit rough. It is up to the individual modeller, many would probably be perfectly happy (and still get a good result!) building the well-fitting model as it is, but I have decided to raise the bar at least a bit. So I have sanded and polished the outer surfaces, primed them using Games Workshop's "Chaos Black" and then polished them again (I did that on the NMF Lightning with good results, in this case I am even doing it in the right order - before the model has been assembled !). Another thing I hoped for was that the primer should fill in the rather prominent panel lines a bit but I doubt it helped much and I don't feel like filling them (with what I don't know anyway!), sanding them down and rescribing all of them. Enough is enough, at least this time !
And now for something even more unpleasant...
...rivets... I've been thinking about this for the last few weeks, if I start it I know I must pull it through. When I found some drawings on-line showing the rivet lines I decided to give it a go. Rivet tools are a 0,4 mm "Rosie" and a Magnus "Signature edition" 0,2 mm, made by Zoltan in Hungary. The Stradivarius of rivet tools ! I'll probably start tonight. Ouch...
Of course I knew before starting this that it isn't a single engined fighter (can be seen on the box art if looking sharply) but I still didn't really get how much bigger the volume of work is. Well, I've got the rest of the year to finish it...
Magnus
rochaped
KitMaker: 679 posts
AeroScale: 669 posts
Posted: Saturday, May 05, 2018 - 04:13 AM UTC
Magnus, good luck with the riveting you brave man!
Posted: Saturday, May 05, 2018 - 04:20 AM UTC
Never a dull moment in your build logs Magnus, and as always good honest critique of the kits to inform us all of potential issues.
Looking good so far, and I am also very interested in seeing how the riveting turns out.
Posted: Saturday, May 05, 2018 - 05:38 AM UTC
Magnus,
sure looks like the riveting is going to be a major investment in time, but with your skills, I'm more then sure the end results will be well worth your effort.
Posted: Saturday, May 05, 2018 - 04:12 PM UTC
Magnus! Wow! Rivets, what can I say?
You are a brave man!
Good luck!
magnusf
Posted: Friday, November 16, 2018 - 07:39 PM UTC
Friends! Finally back to this project, I put it away over summer but now I actually feel quite inspired!
I finally made it through the riveting, more tedious than difficult, and have now closed the fuselage.
Interior looks quite fine even if it is far from the original's tremendous amount of levers, cabling and tubing.
The best part of the Eduard sets were the printed placards replacing various control panels. Out of laziness I left much of the rest of the etch out, the plastic will be perfectly OK seen through the canopy.
With out further ado it was glued shut, taped and set aside for hardening over the night!
And now for some putty...
Wings on is the next step. I wish the kit had been designed so that the wings could be slid over the spars as the last tempo in assembly (it will be a quite hefty piece of plastic to handle when fully assembled) but now the wings sandwich over the protruding wing spars / landing gear anchor structures. I'll also have to start working on the turrets soon, I will treat them as small kits in themselves.
I've also realised that I lied in my first post: I have actually done two four-engined kits before, both Italeri Hercules kits! Sorry for that one !
Magnus
KitMaker: 1,732 posts
AeroScale: 1,336 posts
Posted: Friday, November 16, 2018 - 10:59 PM UTC
Work on the interior with all that tiny PE parts looks fine, Magnus! Of course I'll keep an eye on your progress as always.
Btw: Same here concerning four engined aircraft. Never built one yet, though I have B-17, B-24 and Fw 200 in my stash, all in 1/48 ....
But the day will come ....
Posted: Saturday, November 17, 2018 - 02:52 AM UTC
Magnus,
Ready glad to see that you're making progress once again on the Lancaster. Excellent decision on just how much added detail the interior really needs.
About the biggest multi I've ever built in 1/48 scale is the B-25B and the P-61A, both big twins. Huge models that took a huge amount of time, and forever more a huge amount of display space.
chris1
Auckland, New Zealand
KitMaker: 949 posts
AeroScale: 493 posts
Posted: Saturday, November 17, 2018 - 05:10 PM UTC
Hi Magnus,
I'm following along.
Chris
Posted: Saturday, November 17, 2018 - 09:56 PM UTC
great to see this one back on the bench Magnus!
Magnificent work!
magnusf
Posted: Monday, November 19, 2018 - 08:18 AM UTC
Torsten and Joel! 1/72 is bad enough when it comes to both size and amount of work...
Chris and Russell! As ever, I'll try to keep you entertained !
I realise that the Lanc looked like a true putty monster in my previous post, that's a bit unfair and more due to my sloppy work than any real fit problems. Most of it disappeared after a quick and simple sanding!
A close-up of the fuselage, I've painted the parts of the wing spars that will be seen through the landing gear wells and the deployed flaps.
Top wings fixed in place.
And this is how it looks like butter side up! With a bit of luck the lower wing halves will be glued later on tonight.
Magnus
Posted: Monday, November 19, 2018 - 11:29 AM UTC
Magnus,
Looking real good. How come you're adding the bottom of the wings separately?
Posted: Monday, November 19, 2018 - 09:34 PM UTC
amazing Magnus
goodn8
Berlin, Germany
KitMaker: 709 posts
AeroScale: 651 posts
Posted: Tuesday, November 20, 2018 - 02:20 AM UTC
Glad to see you back with it, Magnus!
And what a fine work you did meanwhile!
I have that Airfix Lanc in my stash waiting to someone gets a hand on. Struggeling with the space I need as it's still huge even in 1/72.
Awaiting your progress with much interest,
Th mas
Antilles
KitMaker: 671 posts
AeroScale: 614 posts
Posted: Monday, November 26, 2018 - 03:22 AM UTC
Magnus,
outstanding work with the interior. I especially like those little things like the maps on the table. Great!
Oliver
magnusf
Posted: Monday, November 26, 2018 - 07:48 AM UTC
Friends! Thanks for your encouragement, I wish I could post more frequently but since many things are x4 it takes much more time to get to the photogenic milestones !
Regarding the wings, the kit is simply designed this way. It is not possible to glue the top and lower half together in the traditional way, they have to be sandwiched around the wing spars. It makes for a strong and self-aligning model so I can live with it ! And that map was supplied by Airfix as a decal, really thoughtful of them I would say !
Bits and pieces! Many parts have sink marks or ejector pin blemishes, none of them are especially difficult to deal with but it has to be done and it takes time. One thing I regret now is that I glued the struts into the engine cowlings, I should have waited with them until I had filled and sanded the collector rings that are integrated with the cowling halves. Fit isn't perfect and it is tricky to sand here when the struts are in place. Another operation that took some time was thinning the cowl flaps.
Som more airframe work with the cowling around the upper turret and the loose rear end of the fuselage in place. The tailplanes were a tight fit, once more very cleverly designed but they needed some adjustment to snap in place.
Magnus
Posted: Monday, November 26, 2018 - 08:41 AM UTC
Good progress on your Lanc, Magnus! It's annoying when those sink marks and ejector pin marks are on the visible side of the kit. Take your time, in the end it will be worth it. Our great hobby is a slow and time consuming hobby but it learns us to be patient in a world full of impatience. I'm surprised to hear that the fitting isn't perfect. Isn't it a new Airfix kit?
I hear your when you say many parts are x4, that does take some extra time. I have all parts x2 with both Gripens on the bench. They still go side by side though the fitting is lousy ....
