Armor/AFV: AA/AT/Artillery
Scammel Thunder Model + Resicast 1/35
ctreize
Nord, France
KitMaker: 92 posts
Posted: Monday, April 02, 2018 - 06:09 PM UTC
Hello!
This is the beginning of my Scammell Heavy Artillery Tractor from Thunder Models and some aftermarket from Resicast.
First, the workable steering by Resicast :
DSC_0125 by Christophe Nachtergael, sur Flickr
DSC_0124 by Christophe Nachtergael, sur Flickr
DSC_0123 by Christophe Nachtergael, sur Flickr
DSC_0122 by Christophe Nachtergael, sur Flickr
Next, the engine...
A little bit updated with some 0.3mm wire.
DSC_0119 by Christophe Nachtergael, sur Flickr
DSC_0117 by Christophe Nachtergael, sur Flickr
DSC_0115 by Christophe Nachtergael, sur Flickr
And some paint and Ak products after...
DSC_0121 by Christophe Nachtergael, sur Flickr
DSC_0127 by Christophe Nachtergael, sur Flickr
DSC_0126 by Christophe Nachtergael, sur Flickr
More dust are coming on the engine...
RobinNilsson
Staff MemberTOS Moderator
KitMaker: 6,651 posts
AeroScale: 21 posts
Posted: Monday, April 02, 2018 - 06:15 PM UTC
Impressive work as usual
ctreize
Nord, France
KitMaker: 92 posts
Posted: Tuesday, April 03, 2018 - 11:48 AM UTC
Thanks Robin!
GTDeath13
Attica, Greece / Ελλάδα
KitMaker: 921 posts
Posted: Tuesday, April 03, 2018 - 12:26 PM UTC
The engine is a work of art!!! Will be following this.
petbat
KitMaker: 3,337 posts
AeroScale: 91 posts
Posted: Tuesday, April 03, 2018 - 01:34 PM UTC
Excellent work Christophe. Fantastic paint work on the engine.
gloucesternige
KitMaker: 307 posts
Posted: Tuesday, April 03, 2018 - 02:25 PM UTC
Nice work Christophe.. that engine is stunning!!
I have to ask though, why go to Resicast for steering parts? It's easy to drill them yourself and make it all work.
http://www.armorama.co.uk/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=263985&page=1
I will shortly be starting a double build of the R100 and the SV2S from Thundermodel and will show how I did this. I have also found a couple of small changes to the build process to make life easier which I will show.
All in all, these are great kits though eh?
ctreize
Nord, France
KitMaker: 92 posts
Posted: Wednesday, April 04, 2018 - 01:40 PM UTC
Thanks all!
@ Nigel : Why buy commercial products rather than doing it yourself?
Because I'm worth it!
bat-213
Canada
KitMaker: 902 posts
AeroScale: 19 posts
Posted: Thursday, April 05, 2018 - 03:12 AM UTC
great work I will wachk this post .
gloucesternige
KitMaker: 307 posts
Posted: Thursday, April 05, 2018 - 10:25 PM UTC
If I may give you a tip Christophe.. before you paint the front bulkhead of the cab check the clearance over the engine. On my transporter i had to remove plastic from the top of the "tunnel" to clear the engine.
I also fitted B31 to the top of the engine before painting because the thin tube that goes up from the vacuum pump needs to be moved to fit B31.
