Armor/AFV: AA/AT/Artillery
Soviet 45mm AT / 76 mm regimental.
b2nhvi
Nevada, United States
KitMaker: 1,124 posts
AeroScale: 40 posts
Posted: Saturday, December 09, 2017 - 03:13 AM UTC
Anybody have a photo of one of these in tow configuration? I am building an M-1943 76mm in tow mode. All the photos I've found are in firing positions or are too dark/ wrong angle to see details. I am most interested in how were the trails secured. The kit does not show any sort of latch. Each trail has a "tow ring" that overlaps the other. Was the tow hook through the ring the only thing securing them?
Das_Abteilung
KitMaker: 365 posts
Posted: Saturday, December 09, 2017 - 06:20 AM UTC
Wasn't the carriage on those very similar if not identical to the German 3.7cm Pak? If so, it would be logical that it had the same method.
b2nhvi
AeroScale: 40 posts
Posted: Saturday, December 09, 2017 - 07:25 AM UTC
I know the earlier ones were based on the 37mm Pak, but not sure on the carriage. As the war went on the Russians simplified everything to speed production and save material. (look at the 42-43 production T-34s . Reportedly some were not even painted.)
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 1,432 posts
AeroScale: 13 posts
Posted: Saturday, December 09, 2017 - 09:45 AM UTC
Timothy,
If I understood your question right, this drawing from Zis-5 Manual should give you the answer:
Traveling mode locking lever is #36.
The gun had a separate combat mode locking lever.
Hope this helps!
KurtLaughlin
KitMaker: 2,401 posts
Posted: Saturday, December 09, 2017 - 06:02 PM UTC
The trails did have a latch at their ends. Look around the interweb for walkarounds of preserved examples, there are quite a few, particularly on Russian sites.
Also, there were differences between the M1943 76mm and the M1937 and M1942 45mm gun carriages. Not everything from the earlier carriages was carried over to the regimental gun.
KL
