OFFICIAL: Flying Boats Campaign
Posted: Sunday, June 25, 2017 - 06:50 AM UTC
I have been researching to see if this model PBY had the black deicer boots on the wing, but I have found no concrete info. Some 3 views show the boot some do not.
Antilles
KitMaker: 671 posts
AeroScale: 614 posts
Posted: Tuesday, June 27, 2017 - 01:03 AM UTC
Paul: This one is really a flawless boaty! Congrats to this one. I especially like the red finish. I find it very hard to make a flawless gloss coat. Everytime I start one, I find some spots onto the surface. But Yours looks really great!
Tim: Outstanding! This one is really cute! The frame painting of the side blisters in this scale is awesome. Not braille scale, even nano scale. Congrats!
Bob: Nice progress on Your Catalina. Concerning the deicer boots I will check my reference.
Oliver
ludwig113
KitMaker: 1,381 posts
AeroScale: 1,110 posts
Posted: Tuesday, June 27, 2017 - 07:41 PM UTC
thanks for the kind words on my build.
Posted: Tuesday, June 27, 2017 - 09:14 PM UTC
Oliver, thanks for the help.
Ive finally painted the tips on the props and now need to repaint the hubs silver.
SHAKY962
Buenos Aires, Argentina
KitMaker: 765 posts
AeroScale: 316 posts
Posted: Tuesday, June 27, 2017 - 09:39 PM UTC
Bob I see your Catalina and I discover wich I have two on my stash...
Posted: Wednesday, June 28, 2017 - 01:28 AM UTC
The Revell kit that I have was probably done on old molds, so it has warps, flash, and fit problems
SHAKY962
KitMaker: 765 posts
Posted: Wednesday, June 28, 2017 - 03:32 AM UTC
Bob, I buy the Academy kit, its more better than the Revell
Posted: Wednesday, June 28, 2017 - 04:56 AM UTC
Jose, I thank that you are correct about the Academy, maybe next time for me
Posted: Friday, June 30, 2017 - 12:48 AM UTC
I will repost the last few photos since photobucket has an issue:
Thomas,thanks for the help.
Removed by original poster on 06/30/17 - 20:05:32 (GMT).
Posted: Friday, June 30, 2017 - 02:16 AM UTC
After much research Ive come to the conclusion that I will not paint the deicer boot. I could not find definite info stating that all PBY's had them.
So! onto to future application and decals.
Antilles
KitMaker: 671 posts
Posted: Friday, June 30, 2017 - 03:14 AM UTC
Hello Bob,
just checked my reference. I think it depends on the serial number. I found this quotation:
"On PBY-5 airplanes prior to serial number. 08349, a rubber boot de-icer system was in- stalled. In these planes , detach Arens control from lever arm of distributing valve by remov- ing clevis bolt from arm at leading edge."
This will be useful, too. Look at page 19 at the note:
http://www.usaf-sig.org/index.php/references/downloads/category/42-pby-catalina?download=163:an-01-5ma-2-pby-5-pby-5a
I am no expert concerning Catalinas. Can anybody confirm this?
Oliver
Posted: Friday, June 30, 2017 - 04:06 AM UTC
Oliver, thanks for the data book. I read the page and will look at the s/n on the decals when they arrive.
Posted: Saturday, July 01, 2017 - 03:54 AM UTC
At last, I have started on my project, the Air Craft Models 1/144 US Navy Martin Mars
oh yes, its a vacuform -
all the parts separated
brand new sheet of 100 grit Sandblaster
first part ready
more tomorrow
Posted: Saturday, July 01, 2017 - 04:32 AM UTC
This Mars I have got to see.
Antilles
KitMaker: 671 posts
Posted: Saturday, July 01, 2017 - 07:43 PM UTC
Jonathan,
I never build a Vac-kit. So I wil exitedly follow your build.
My Wal now has a redone motor compartment. The structure of HUMA is not bad, but the ventilation openings are too small and the opening on the top is missing. Wing has been attached, too.
Now for the smaller parts.
Oliver
PasiAhopelto
Uusimaa, Finland
KitMaker: 513 posts
AeroScale: 239 posts
Posted: Saturday, July 01, 2017 - 09:30 PM UTC
I'd like to join the campaign with Hasegawa's H6K5:
It's old Hasegawa kit from 1969 repackaged with new decals and PE radar antennae. 1/72, fine raised panel lines, and looks like I need to add little rigging line.
Posted: Saturday, July 01, 2017 - 09:48 PM UTC
Hallo Pasi Ahopelto ,
Splendid to see another campaigner!
Posted: Saturday, July 01, 2017 - 11:03 PM UTC
@Jonathan: I will send my cutout vac parts for you to sand then send back for me to assemble .
@Oliver: the WAL is looking good.
@Pasi: nice kit, I will enjoy watching your build progress.
Posted: Sunday, July 02, 2017 - 12:39 AM UTC
OK, Bob, I will send you my rate sheet.
Here are the wing and fuselage assemblies all welded together.
I am not going to cut out the cockpit windows, Ill do something with decals after the painting is done, but i did drill out and counterbore every one of those little portholes. you cant see any light in there, but i think they will look good filled with Krystal clear.
also, for size comparison, a Catalina has arrived.
The instructions recommend a wing spar, that is what that piece of square tubing is for.
Posted: Sunday, July 02, 2017 - 02:00 AM UTC
WOW! that a/c was big.
Posted: Sunday, July 02, 2017 - 04:23 AM UTC
The Mars was the largest flying boat ever to enter regular production.
The wingspar in place
the wings mounted. Starting to look like an airplane.
unfortunatley the spar geometry wasnt perfect and the wing sits a tiny bit high, so there will be a little work fairing the joins.
Thats all for now. I might get a few hours to play on tuesday.
Kevlar06
KitMaker: 3,670 posts
AeroScale: 833 posts
Posted: Sunday, July 02, 2017 - 10:21 AM UTC
Hello Bob,
Oliver
Bob & Oliver,
I can't vouch for the PBY1-5, which looks like what you are building there, due to the lack of landing gear, but I can state the PBY5A does have the de-icer boots. I just photographed a PBY5A over at the McChord field Air Park for a feature I wrote over on LSP. That aircraft from the 4th ARS has boots between the engines and the length of the wings. But it's a -5A, and it looks like yours does not have the retractable gear, which makes it likely a 3,4 or 5.
VR, Russ
Kevlar06
Posted: Sunday, July 02, 2017 - 10:24 AM UTC
The Mars was the largest flying boat every to enter regular production.
Jonathan, super quick work on a super aircraft-- is that PBY also in 1/144 scale? If so what kit is that?
VR, Russ
Posted: Sunday, July 02, 2017 - 12:50 PM UTC
Yes it is 1/144, its a slightly modified Minicraft PBY-5 amphibian (turrets removed) which I built for the 2014 sea Planes campaign
One of Minicraft's nicest 1/144 offerings
