Armor/AFV: Large Scale
Building the 1/16th. Jagdtiger from Trumpeter
OldWarloke
KitMaker: 2,663 posts
Posted: Friday, December 30, 2016 - 05:14 PM UTC
Donald, I don't get this. You ask about the colour of a specific part, but really don't want input on accuracy? Now, I'm not an expert (I prefer to stick to English when I'm writing, rather than a corrupted German), but I do have the Tiger II kit in progress, and I totally get why you won't bother with correcting everything. Because apparently, just about everything needs correcting. But guess what, I'm not correcting it all myself either.
I know from previous builds that you do more or less strictly OOB, but I took the liberty of pointing out the shock absorber as the painting suggested it works differently than the real thing, and it is an easy fix. Assuming you have an interest in how the real thing works, that is.
But, as you will surely point out, it is your build, and you do with whatever you please. I really could not care less.
Enjoy the big cat!
Arild
Hi Arlid
It's not that I don't care about accuracy as stated by a previous poster, I'm just not that important that every nut, bolt and wire is in the exact position as designated by the Experten. As for the part I asked about I was pretty sure that it was a fire extinguisher. from what I have seen the Germans at that time painted the various parts with what paint they had at hand at that time. As for the interior colors, there were a limited number of these vehicles produced, and I doubt that anyone has a record as to how each one was painted. This is why I'm painting the lower part of the hull with the red oxide, the upper will be white.
Good luck with the Tiger II , there is a lot of issues there.
Regards.
Donald
Ps. thanks for the info on the shock absorber I have corrected it, the instructions had it silver there and everyone should know that you can't always trust the instructions.
sam_dwyer
KitMaker: 294 posts
Posted: Friday, December 30, 2016 - 05:29 PM UTC
Name calling aside (Samantha - surely you can come up with something a bit more original than that) - lower hull in red primer, upper in elfenbein, which was an off white/cream colour, not pure white.
All the best with your build.
OldWarloke
Posted: Friday, December 30, 2016 - 07:15 PM UTC
Na I'm not to original, the white will get durtied up so off white / bright white , not much difference there.
OldWarloke
Posted: Friday, December 30, 2016 - 07:20 PM UTC
OK enough of that.
Now back to the build.
I am trying something a little different with this tiger, I'm assembling the Engine Compartment apart from the hull. There are a lot of push pin marks that may be visible after completion .
I assembled the Radiator Grill Boxes after filling the spots on the fins , then installed them on the side walls and filled the inside spots shown.
OldWarloke
Posted: Friday, December 30, 2016 - 07:28 PM UTC
I used the rear inner panel to spread the rear of the hull, this was a really tight fit. Test fitted the assembly.
OldWarloke
Posted: Friday, December 30, 2016 - 07:34 PM UTC
Now for some more painting.
Hey does anyone know where the Battery boxes go. The idiotic instructions have them going under the rear ammo box, that can't be right, how would you ever service them?
Regards.
Donald
Thirian24
Oklahoma, United States
KitMaker: 2,493 posts
Posted: Friday, December 30, 2016 - 08:05 PM UTC
Looking good Donald.
panamadan
Minnesota, United States
KitMaker: 1,513 posts
Posted: Friday, December 30, 2016 - 08:39 PM UTC
there is always drama on this website.
If a guy wants to paint or build a certain way, what do I care?
I'm enjoying this build.
Dan
Armorsmith
KitMaker: 1,063 posts
Posted: Friday, December 30, 2016 - 09:35 PM UTC
Not that I would ever aspire to build so large a beast as this but I always enjoy your "build reviews." I especially like the photos of the SBS build as this helps immensely in visualizing the commentary you provide via the text.
OldWarloke
Posted: Sunday, January 01, 2017 - 06:28 PM UTC
Continuing on.
Note how nice and square the rear hull is.
The rear panel is suppose to fit inside the two side panels that were added.
Well that will be corrected later, now it's the Radiator assemblies
You have to be careful witch way you position the Raditor tops
as the mounting point on the bottom connector is two different distances from the edge. I couldn't get every thing else to fit any other way.
OldWarloke
Posted: Sunday, January 01, 2017 - 06:38 PM UTC
I drilled out the lifting points.
I don't think it Maters which way you place the drive for the fan, that is unless you are doing a build with everything opened up.
Once everything is assembled you aren't going to see anything here.
Man this build is really turning into a pain in the backside.
Donald
crossracer
Delaware, United States
KitMaker: 117 posts
Posted: Monday, January 02, 2017 - 03:03 AM UTC
Looking good, that is a huge build.
OldWarloke
Posted: Tuesday, January 03, 2017 - 06:08 PM UTC
I've been working on the Transmission and Drive gear box, this is just out of the box.
For a really detailed build check out Sam Dwyers build his facebook info. is posted somewhere above.
There's a lot of wasted detail here, that would have been better used making the visible parts more accurate.
This is the same that Trumpeter used in their Tiger II Once the Hull is closed up you'r not going to see much of it.
I'm going to work on the Engine next, just a lot of small subassemblies.
That's all for now.
Donald
OldWarloke
Posted: Friday, January 06, 2017 - 02:21 AM UTC
I have been working on the Engine, painting and assembling as I go.
The colors are probably not correct, but you aren't going to be able to see mast of it.
OldWarloke
Posted: Friday, January 06, 2017 - 02:25 AM UTC
I assembled the 4 Carbs, and fastened them to the upper airconnector
then added the fuel line. It's a lot easier this way than doing it on the engine.
OldWarloke
Posted: Friday, January 06, 2017 - 02:35 AM UTC
Here is a Pic. of the Engine compartment from my King Tiger build,for more on that check the Large Scale section of the Forems here.
As you can see a lot of the engine and other parts are going to be hard to see. I'm not going to install the fuel tanks that go under the radiators.
Well it's back to finishing the Engine.
Donald
OldWarloke
Posted: Wednesday, January 11, 2017 - 08:37 PM UTC
I've finally finished the Engine, I know the colors probably aren't correct but I think it looks good.
Here the Carbs and their Fuel Lines are installed.
You aren't going to see much of this.
Now more of the plumbings installed.
OldWarloke
Posted: Wednesday, January 11, 2017 - 08:50 PM UTC
There are issues with the Air Cleaners for this kit.
When Trumpeter designed this kit they made the center square of the Air Cleaners too small.
The Tiger II parts are app. 26mm by 26mm . The ones in this kit are 25mm by 26mm. Unfortunately the short side has the notches where the end covers go. You should add about 1mm shim to each side.
This is the Tiger II Air Cleaner.
Here is the Jagdtiger Air Cleaner.
I'll have more on this later.
Pic. #59 & #60 show the Oil Tank installed wrong, I have corrected it.
OldWarloke
Posted: Wednesday, January 11, 2017 - 08:57 PM UTC
OldWarloke
Posted: Wednesday, January 11, 2017 - 09:03 PM UTC
Now back to the Air Cleaner fit.
I think that this should be even on both sides.
Oh well I don't think this will be that visible, so I'll live with it.
That's all for now.
Donald
OldWarloke
Posted: Friday, January 13, 2017 - 01:56 AM UTC
I am gluing the front of the Engine to the Firewall before installing it all in the hull. This is an experiment, will it work ? Hey who knows, it seems more logical this way than trying to do it with the Firewall allready installed in the Hull.
The scoops that come off the Exhaust shroud, the tops curve the wrong way. I'm pretty shure that I installed the right curved parts on the right sides. Well maby I screwed up there. It might be better to install the curved parts after every thing is installed.
Here the Engine is glued to the Firewall, if you do it this way besure the rear of the Engine is level with the bottom of the Firewall.
OldWarloke
Posted: Friday, January 13, 2017 - 02:00 AM UTC
I started sliding the assembly down while prying the rear of the Hull open wider.
Almost there.
Now glue it all down.
That went better than I thought it would.
Top view, still a lot to add.
OldWarloke
Posted: Friday, January 13, 2017 - 02:06 AM UTC
The other side of the Firewall.
Here's a little of the front interior.
Now it's back to the Engine area.
Donald
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
AeroScale: 79 posts
Posted: Friday, January 13, 2017 - 02:38 AM UTC
Your work is astonishing. Any advice on where I can pick one up, on the cheap?
OldWarloke
Posted: Saturday, January 14, 2017 - 08:52 PM UTC
I've no Idea now mat, I got this one during the holidays when Squadron Shop had a sale.
Donald
Here I have the two Ducts that run from the floor to the side walls installed, I'm not shure of their color so I painted the so.
The inner rear plate is being used to hold the rear of the hull in position. There is some warpage in the rear hull.
The 2 ducts are a soft plastic but go together with liquid glue, you'r not going to remove the seams but they won't be seen anyway.
Here I installed the plates that go under the radiator units, I didn't install the fuel tanks that go under them (not seen)
