Armor/AFV
Rivets
CMOT
Staff MemberEditor-in-Chief
KitMaker: 10,951 posts
AeroScale: 290 posts
Posted: Saturday, November 26, 2016 - 06:09 PM UTC
The Czech company Plusmodel has released several sets of rivets that will certainly see some use among detailers. These resin pins are molded in sets of fifty, and sold in packages of 250. I received two sets for review.
Taeuss
Manitoba, Canada
KitMaker: 3,701 posts
Posted: Sunday, November 27, 2016 - 08:47 AM UTC
These will prove very useful in an upcoming project that I've been planning on building involving a heck of a lot of Evergreen sprue!
BillieJean
KitMaker: 32 posts
Posted: Thursday, December 01, 2016 - 10:44 AM UTC
What Material Resin, Plastic, Printed???
CMOT
Posted: Thursday, December 01, 2016 - 03:30 PM UTC
These are resin.
tankmodeler
#417
KitMaker: 3,123 posts
Posted: Monday, December 05, 2016 - 01:45 AM UTC
While these look perfectly well formed, the fact that you can get about 150 Grandt Line or Tichy Trains rivets, in styrene, for $2.50-$3.50 makes resin rivets a bit expensive for larger projects.
That these are resin also means that you _must_ use either CA or epoxy to secure them to all models, whereas the styrene Grandt or Tichy rivets can be attached to styrene kits or scratchbuilt components with your favourite liquid cement. Frankly that's more than enough reason to not use resin rivets or bolts without the monetary inducement.
If you like resin rivets, I'm sure these are a fine product, but there are other rivets out there that have significantly more utility and are cheaper to boot.
Paul
RobinNilsson
Staff MemberTOS Moderator
KitMaker: 6,653 posts
AeroScale: 21 posts
Posted: Monday, December 05, 2016 - 02:01 AM UTC
Paul
Many of the Grandt-line bolts and rivets I bought years ago had the heads off-centered from the shaft but maybe they have improved since then .....
It's a riveting topic though ....
Grand Line has rivets in three sizes:
0.032, 0.043 & 0.063 inches (that's 0.81, 1.09 and 1.6 mm for you fans of the metric system out there)
Plus Models have sizes 0.5, 0.6, 0,7, 0.8, 0.9, 1.0, 1.2 and 1.4 mm.
Tichy Trains have the inch-sizes: 0.020, 0.025, 0.030, 0.035, 0.04, 0.05, 0.06, 0.07 and 0.08 (multiply with 25.4 to get the mm sizes)
Depending on the size you need you may need to choose the approriate manufacturer ...
/ Robin
Headhunter506
KitMaker: 1,572 posts
AeroScale: 45 posts
Posted: Monday, December 05, 2016 - 02:57 AM UTC
Paul
/ Robin
Masterclub has spherical, spherical flat, flat and two types of conical rivets ranging in size from 0.4 to 1.8 mm in 0.1 mm increments. Depending on size, you get 100-200+ for a paltry $2.35 per pack. That's a whole lotta rivets, man.
Oh, they're resin, btw.
