World War II: USA
B-24H Libra 1/48 Scale
berndm
Niedersachsen, Germany
KitMaker: 844 posts
AeroScale: 630 posts
Posted: Tuesday, February 28, 2017 - 12:26 PM UTC
Superdetailing ! The turret is a model in its own right.
thathaway3
Michigan, United States
KitMaker: 1,610 posts
AeroScale: 85 posts
Posted: Tuesday, February 28, 2017 - 10:10 AM UTC
OK, so I'm using Eduard's masks for the first time on one of the turrets, and I'm a bit confused about the directions. I've applied the masking on the outside of the turret to what is obviously the part which is to remain clear. No problem. At this point, I'm thinking that I'd apply the body color (in this case OD), and then remove the masking. However the instructions have a graphic of an airbrush which says, "Interior color" then it appears to show the entire turret shaded with a corresponding block of the same color which says "Liquid Mask", and then finally there's another graphic of an airbrush which says, "Camouflage Color".
So what is all this telling me to do, because it SEEMS like all I need to do is paint OD and remove the masking.
skyhawk
KitMaker: 1,095 posts
AeroScale: 52 posts
Posted: Monday, February 27, 2017 - 08:19 PM UTC
your issue with the color is white balance.
I also use a Cannon Powershot (G5), and have found that I can take great photos with no post processing (editing).
Lighting type has a lot to do with it too. I use the Compact fluorescents, but am choosy as some have a yellowish hue. I tend to get the ones that are bright white, then use the "tungsten" setting on my camera for whitebalance. So far, no yellow cast, and reds/blues come out looking like they should.
Also, with those "lower" end function cameras, more light the better! I use at least 3 bulbs, with a 4th bouncing off my white ceiling. all are "100W equivalent" (so I think that is about 26W in the Compact fluorescent world)
thathaway3
AeroScale: 85 posts
Posted: Tuesday, January 31, 2017 - 03:44 AM UTC
It has been a very busy month, but I HAVE made some progress. Martin top turret is pretty much done except for gluing on the canopy. The resin seat didn't appear to be as deep as the one over at Willow Run, so I wound up scratch building my own.
Posted: Monday, December 26, 2016 - 11:05 PM UTC
Tom,
The resin details for the turret look fantastic.
Redhand
#522
KitMaker: 1,459 posts
AeroScale: 1,442 posts
Posted: Monday, December 26, 2016 - 07:40 AM UTC
Yes, this is coming along extremely well!
KitMaker: 17,581 posts
AeroScale: 12,794 posts
Posted: Sunday, December 25, 2016 - 11:57 PM UTC
Hi Tom
Great work on the turret. I've loved Bill's kits and accessories ever since tackling his vacuform A-20G many, many moons ago. It was a real jump into the deep end and by far the most complex project I'd ever tackled at that point, but I enjoyed every part of the challenge it presented.
thathaway3
AeroScale: 85 posts
Posted: Sunday, December 25, 2016 - 11:50 PM UTC
Here's the latest update on the top turret. I haven't gotten as much done as I'd like, but now that Christmas is over I should be able to get some more time in.
Posted: Friday, December 09, 2016 - 02:14 AM UTC
Tom,
That resin is most impressive looking.
Don't even think about Photoshop as an editor. It's the most expensive one out there by far. I use Adobe Lightroom 6, it's little brother, but it still costs $150 or so. There are a few open source ones you can use.
Redhand
#522
Posted: Friday, December 09, 2016 - 12:04 AM UTC
Looking pretty good! I'm sure it will look far better under the naked eye and under the "Plexiglas dome." Carry on as they say.
thathaway3
AeroScale: 85 posts
Posted: Thursday, December 08, 2016 - 10:43 PM UTC
I just bought a large grey sheet of cardboard to use instead of the old blue paper background which was causing the camera to compensate.
This seems to be a better solution and only cost $9.00.
thathaway3
AeroScale: 85 posts
Posted: Thursday, December 08, 2016 - 09:30 PM UTC
These are still not "true" as the resin is actually more of a grey color, but they are better. Guess I'm gong to need to get an editor program to fix the color. Any suggestions on an inexpensive program? Maybe photoshop? I already have WAY too many hobbies to get back into serious photography!
thathaway3
AeroScale: 85 posts
Posted: Thursday, December 08, 2016 - 09:07 PM UTC
That's another part of the problem. I'm not really using any editing program, which I probably should. My camera is not a professional one, it's a Canon Powershot, so it is better than using my phone!
It's ironic, because my daughter is a professional photographer, but I can't really ask her to stop by every time I want to take WIP photos.
I took a lot of photos when I did my M-88 build and they were fine, but I took them against the plain blue paper background, so I'll go back to that and see if it's an improvement.
Posted: Thursday, December 08, 2016 - 08:55 PM UTC
I'll have to fool around with it. I'm using regular photo flood lights which I think are 3200 Kelvin. I think the problem is that I'm putting the items inside the same box I use as a spray booth, and I think it's picking up color from that. I'm going to go back and pull out my standard blue photo background paper and set stuff on that.
Tom,
sounds like you're shooting with more then a point and shoot which is a good thing. What editing program are you using?
From what you said about using 3200K floods, that's the issue. You can easily compensate for that both in camera and in editing.
thathaway3
AeroScale: 85 posts
Posted: Thursday, December 08, 2016 - 04:54 AM UTC
Posted: Thursday, December 08, 2016 - 04:02 AM UTC
Tom,
The turret detailing looks really good.
the issue with your photos is your White Balance setting based on your lighting.
thathaway3
AeroScale: 85 posts
Posted: Thursday, December 08, 2016 - 03:51 AM UTC
Time for an update. I haven't done too much, as I have been waiting for the Koster Conversion Kit which came yesterday. And to my delight, this kit ALSO contains the identical content as the turret kit, so I have some extra parts to work with.
I'm a bit concerned with the yellowish color shift with the photos. I think I know what the problem is, and I'll see if I can correct it with the next batch.
Removed by original poster on 12/08/16 - 22:47:14 (GMT).
KPHB17FE
Illinois, United States
KitMaker: 292 posts
AeroScale: 292 posts
Posted: Wednesday, November 23, 2016 - 06:28 AM UTC
Looking forward to this one. The Liberator is an often overlooked airplane. And I say this as a dedicated B-17 nut !!!
Posted: Wednesday, November 23, 2016 - 06:11 AM UTC
Tom,
Sounds like another great build. I'll be following right along till you cross the finish line.
thathaway3
AeroScale: 85 posts
Posted: Wednesday, November 23, 2016 - 05:37 AM UTC
Now that I've decided that I'm going to build a Ford Willow Run built B-24H the "Libra", I've started a new post to track how the build is going.
I spent some time at the Yankee Air Museum today and was able to take some great photos of the top turret they have on display there as well as the cockpit.
I'm starting with that top turret which is from the Koster set. It's a good start, but I've decided to add some additional detail based on what I saw on the actual turret. Attached are the initial photos of the parts as they are after I removed them from the molds and the initial clean up I have done.
