Armor/AFV
Bradley vs. BMP
staff_Jim
Staff MemberPublisher
New Hampshire, United States
KitMaker: 12,497 posts
AeroScale: 507 posts
Posted: Wednesday, August 24, 2016 - 03:16 AM UTC
A comparison of these two iconic AFVs by author Mike Guardia from Osprey Publishing. 80 page, color and B&W photos/illustrations.
ULIX-VM
Puerto Rico
KitMaker: 834 posts
AeroScale: 183 posts
Posted: Thursday, August 25, 2016 - 02:23 AM UTC
the soviet/russian combat vehicle "bmp-1" have some advantages over the bradley. the bmp-1 is amphibious the bradley not. in firepower bmp have 76mm smoothbore gun, four anti-tank missiles, gunports. the bradley have one 25/30 mm chain-gun, two tow anti-tank missiles. and gun-ports.
Spades
KitMaker: 775 posts
AeroScale: 30 posts
Posted: Thursday, August 25, 2016 - 03:03 AM UTC
I didnt see any of those advantages during the 1st Gulf War. All I saw were burning BMP's.
Removed by original poster on 08/25/16 - 23:08:21 (GMT).
Epi
KitMaker: 3,586 posts
AeroScale: 55 posts
Posted: Thursday, August 25, 2016 - 04:14 AM UTC
AMEN Lou!
Ulises, it's a 25mm Bushmaster gun. British Warrior's have 30mm guns.
And at one point in time, the Bradley did have a swim barrier attached around the top of the turret for amphibious operations.
ReluctantRenegade
Wien, Austria
KitMaker: 2,403 posts
AeroScale: 105 posts
Posted: Thursday, August 25, 2016 - 07:11 PM UTC
It's a 73 mm ineffective gun which can not be fired (effectively) while moving - how does that translate to an advantage over the 25 mm Bushmaster which can be fired with great accuracy also while moving ?
ReluctantRenegade
Wien, Austria
Posted: Thursday, August 25, 2016 - 07:50 PM UTC
Hardly an advantage in the main operational areas of the BMP-1 used in anger: Africa and the Middle East.
Spades
KitMaker: 775 posts
AeroScale: 30 posts
Posted: Friday, August 26, 2016 - 03:12 AM UTC
If you hit the BMP along the bottom side just behind the road wheels with a 50.cal. It would chew it up like swiss cheese. Tried it the first night of the ground war. BMP's would leak like sump. Very cramped inside. Just a horrible machine.
elevenbravo87
Georgia, United States
KitMaker: 63 posts
Posted: Friday, August 26, 2016 - 08:27 AM UTC
I killed them easily enough during Desert Storm. 10-15 rounds of M791 APDS and you had a dead BIMP. TOWs (which we had 7) was a waste on BMP, and my M2A1 could "swim" if needed...not a whole lot of use for it in the desert though.
Bradley Gunner, C co. 3/15 Inf. 24th ID(M)
exgrunt
KitMaker: 301 posts
Posted: Friday, August 26, 2016 - 06:29 PM UTC
Keep in mind - at the time the BMP-1 was introduced, the US was using M113's. Which of those two vehicles do you think was superior?
The Brad was the US response to the BMP and it came along nearly a decade later. By that time, the Russians had started deploying the BMP-2.
ReluctantRenegade
Wien, Austria
Posted: Saturday, August 27, 2016 - 02:30 PM UTC
True, but irrelevant.The comparison is between the BMP-1 and the Bradley, not the M113. How FAIR is that? You might have a point there...
