Armor/AFV: Large Scale
Up Detailing the 1/16th. Hobby Boss Tiger I
OldWarloke
KitMaker: 2,552 posts
Posted: Thursday, July 28, 2016 - 11:13 PM UTC
Just announcing my latest project.
Yes I know it's an old radio control kit.
I have the Attack Zimmerit and the Voyager Pe.
This is just to see what I can do with it.
I'm not sure how accurate the kit is, but it looks like fun.
Donald
OldWarloke
Posted: Friday, July 29, 2016 - 07:33 PM UTC
Well it's started.
I removed the bumps on the lower front hull, they aren't supposed to be there. They are just for clearance for the motorizing gear.
I filled in the openings for the RC gear mounts.
Filled in all the joints.
OldWarloke
Posted: Friday, July 29, 2016 - 07:39 PM UTC
Then I covered the lower front end with some thin sheet stock.
This will be covered with Zimmerit eventually .
The inside front.
That's all for now.
Donald
Mecsweden
Västra Götaland, Sweden
KitMaker: 137 posts
Posted: Friday, July 29, 2016 - 11:56 PM UTC
Looking good so far Donald , have this kit also. Waiting for your magic on this tiger
OldWarloke
Posted: Sunday, July 31, 2016 - 02:09 AM UTC
I have added the small plates with their Nuts to the lower front end.
These are not included in the kit.
I don't know how accurate they are, My pics. that I have show a couple of different ones. Hey it's better than none.
Donald
Byrden
Wien, Austria
KitMaker: 2,216 posts
Posted: Sunday, July 31, 2016 - 12:57 PM UTC
You seem to be serious about this? Post the upper deck and I'll talk about it.
David
OldWarloke
Posted: Sunday, July 31, 2016 - 03:43 PM UTC
Hi David.
I'm building this just to see what I can do with it, I think that I have read that there are a lot of accuracy issues with it.
Still I'm not a rivet counter, and I think it looks a lot like a tiger I .
Donald
OldWarloke
Posted: Monday, August 01, 2016 - 07:42 PM UTC
I super glued the Nylon bushings in place to keep them from falling out.
The final drive housings are handed so you can't switch them around.
I used only 1 screw on each one, then glued them in place.
OldWarloke
Posted: Monday, August 01, 2016 - 07:48 PM UTC
The Idler arms needed some clean up on the flat areas.
I glued the torsion arm mounts to the sides without the springs, be sure to get them flush with the sides.
The small parts that fit through the openings should be as shown or the arms will be crooked .
The springs go here.
OldWarloke
Posted: Monday, August 01, 2016 - 07:56 PM UTC
I used some thin super glue to hold the nuts in place, they kept on falling out.
This is how the arms look after instalation.
You should install the left one first and work your way to the right.
Here is how the inside parts look after assembly .
That's all for now.
Donald
Byrden
Wien, Austria
Posted: Monday, August 01, 2016 - 08:58 PM UTC
And yet the real ones were not handed. Hmmm.
David
OldWarloke
Posted: Tuesday, August 02, 2016 - 03:55 AM UTC
Hi David, here is what I meant about them being handed.
The right side has a cut out in it to clear the torsion arm.
The left Side doesn't have it.
Someone screwed up here.
OldWarloke
Posted: Tuesday, August 02, 2016 - 04:01 AM UTC
Here's what is next, another correction removing the speaker mounts that show through the large right rear grill.
tatbaqui
Staff MemberNews Reporter
Metro Manila, Philippines
KitMaker: 2,707 posts
AeroScale: 65 posts
Posted: Tuesday, August 02, 2016 - 06:30 AM UTC
Speaker mounts
Byrden
Wien, Austria
Posted: Tuesday, August 02, 2016 - 12:00 PM UTC
That's not what I meant. They both had a single cutout. It was useful on the right side because of the torsion bar, but on the left side it ended up near the top of the drive unit.
David
OldWarloke
Posted: Tuesday, August 02, 2016 - 06:36 PM UTC
Speaker mounts
Here is the inside, there was a volume control slot on the bottom rear. This kit was a radio control model at one time.
I can't imagine what else this was fore.
Donald
OldWarloke
Posted: Wednesday, August 03, 2016 - 12:41 AM UTC
I removed part of the internal ring, as shown.
It looks a lot better from the outside, I still have to add the mesh screens .
OldWarloke
Posted: Wednesday, August 03, 2016 - 12:45 AM UTC
Here I started installing the Zimmerit on the rear Hull.
I used the parts as shown to aid in its placement.
That's all for now.
Donald
KitMaker: 4,535 posts
AeroScale: 1,908 posts
Posted: Wednesday, August 03, 2016 - 02:24 AM UTC
Don,
Nice job on removing the extra grill. Great add-ons, too.
Watching with interest,
Gaz
tatbaqui
AeroScale: 65 posts
Posted: Wednesday, August 03, 2016 - 07:11 AM UTC
Speaker mounts
Donald
Thanks Donald. I didn't know it had an RC option. Nice work, looking forward to see more. Cheers, Tat
KitMaker: 9,989 posts
AeroScale: 3,767 posts
Posted: Wednesday, August 03, 2016 - 11:03 AM UTC
Nice progress so far.
Looking forward to see more.
OldWarloke
Posted: Wednesday, August 03, 2016 - 08:42 PM UTC
I've been working on the front upper Zimmerit.
It all fits better if the front part is installed first.
Remember all parts need to be trimmed to fit.
Be sure to leave the area on the front edge, it covers the top edges of the lower front.
Working on the side Zimmerit next.
Donald
OldWarloke
Posted: Thursday, August 04, 2016 - 09:18 PM UTC
I have the side Zimmerit installed.
There's even Zimmerit under the side skirts.
OldWarloke
Posted: Thursday, August 04, 2016 - 09:23 PM UTC
I have some work on the Turret started.
Mecsweden
KitMaker: 137 posts
Posted: Thursday, August 04, 2016 - 09:24 PM UTC
Looking great so far,keep up the good work
