OFFICIAL: Fighter-Bomber Campaign
RedDuster
KitMaker: 7,078 posts
Posted: Saturday, August 01, 2015 - 12:44 AM UTC
A bit more progress on the Seahawk.
Glossed ready for decals.
And decals on.
Cheers.
Si
RedDuster
Posted: Sunday, August 02, 2015 - 12:46 AM UTC
Matt coat on and masking off the canopy.
Undercart and flaps and other bits & pieces base coated on the sprue.
Si
TankSGT
KitMaker: 1,139 posts
AeroScale: 53 posts
Posted: Sunday, August 02, 2015 - 02:21 AM UTC
Nice job Si. I'm still sanding wing to fuselage seams.
Tom
RedDuster
Posted: Monday, August 03, 2015 - 12:05 AM UTC
Thanks Tom,
Looks like you are having fun with the Fury, good luck with that.
Cheers.
Si
TankSGT
AeroScale: 53 posts
Posted: Monday, August 03, 2015 - 02:02 AM UTC
The review I read said the fit was good. Sanding seams was one of the reasons I shelved model planes for years.
I just added another project to my list as well. I'm a volunteer at the NJ National Guard Museum. We have several neglected tanks that need some TLC. So some of my Saturdays will be back to working on the real thing. I'll tell you Simon it felt good climbing back on a tank on a tank. I'm wearing the green hat.
Tom
TankSGT
AeroScale: 53 posts
Posted: Friday, August 07, 2015 - 12:29 PM UTC
My Fury is moving along most of the sanding is done. the cockpit is taped over to protect it. I also filled in the inner pylon holes the F4J only had 4 pylons the F4J-B had 6.I really like the lines of this jet.
Tom
RedDuster
Posted: Saturday, August 08, 2015 - 01:42 AM UTC
Fury coming on good Tom,
A bit more progress on the Seahawk. The undercarriage going on.
And the doors in place.
Stores next.
Si
KitMaker: 696 posts
AeroScale: 608 posts
Posted: Saturday, August 08, 2015 - 02:18 AM UTC
Hi mates,
at last I started my kit two days ago, here are the first pictures:
It will be an aircraft of the Hellenic Air Force, OOB with a resin bangseat and metal pitot tube.
KitMaker: 696 posts
Posted: Saturday, August 08, 2015 - 02:23 AM UTC
Building goes straightforward, not so many parts, fitting looks promising yet. Have to check my spares box for an Exocet missile or hang some Durandals under the wings
Enjoy your weekend!
TankSGT
AeroScale: 53 posts
Posted: Sunday, August 09, 2015 - 12:00 AM UTC
Stores next.
Si
Si how noticeable is the counter shading of the panel lines in person. I can't detect much difference in the pictures. I wanted to try it on my Fury. Is it worth the effort?
I'm working on fitting the gear doors. My research showed that the most of the gear doors were closed while the jet is on the ground, lots of sanding and dry fitting.
Tom
RedDuster
Posted: Sunday, August 09, 2015 - 11:42 PM UTC
Hi Tom,
It is more visible on the real thing, I think on the pictures taken inside the workshop the flash may be overpowering the effect.
Good luck with your filling and filing.
Small update from Sunday, started work on the stores.
The bombs and rocked assembled.
and the basic paint job.
Si
scribbles101
KitMaker: 137 posts
Posted: Monday, August 10, 2015 - 09:15 PM UTC
@Simon.H - that sea fury is looking amazing!
@Tom - If you are interested there is a short-cut you can take with pre-shading, it is something I do a lot because I'm a bit rubbish with an airbrush, and it works pretty well, especially under light colours and bare metal finishes, but can be pretty difficult to notice under a darker shade, and that is to use a permanent marker to draw along the panel lines instead of an airbrush. I used that on my F-84 earlier in this campaign if you want some example pics.
TankSGT
AeroScale: 53 posts
Posted: Monday, August 10, 2015 - 10:10 PM UTC
Simon that would be great. I have heard of that before but really have not seen it done. The Fury is in the gull gray over white so that should work well. I guess fine tip would be best.I'm not to bad with an air brush but I hate cleaning it, so I only use it for major painting.
Tom
Northern_Lad
KitMaker: 462 posts
Posted: Sunday, August 16, 2015 - 09:40 PM UTC
Photo of the unstarted kit I will build...
Does it matter that it does not have any bombs under the wings?
Matthew
North4003
KitMaker: 960 posts
AeroScale: 391 posts
Posted: Sunday, August 16, 2015 - 11:01 PM UTC
I'm impressed with the workmanship I'm seeing in this campaign.
Northern_Lad
KitMaker: 462 posts
Posted: Monday, August 17, 2015 - 02:07 AM UTC
so the revel mig 21 does come with a bombs under wings option...
Matthew
mrockhill
KitMaker: 566 posts
AeroScale: 507 posts
Posted: Wednesday, August 19, 2015 - 10:48 AM UTC
I didnt have a kit in the stash that I was interested in building for this campaign... till I picked this 1/72 Tamiya F-51d up. I have other projects to do but I'm feeling like some more mustang is in order, so let it be done!
I have this CMK korean war mustang interior set for korean war mustangs but I fail to see whats so korean war specific. The radio and seat look like better detailed versions of what the kit parts depict so I can only conclude that its in the instrument panel. Im a bit underwhelmed but WTH, Ill use it.
I like the shark mouth looks of the 28th FBW, but the world doesnt need yet another "Was that too fast" so unable to find other korean war mustang decals yet Im currently planning to build "Buckeye Blitz VI/ Red Eraser" I'll probably get some nicer wheels and possibly a vac canopy, I'll have to see what I can do with the tamiya canopy setup. Definitely looking foward to having a bit more leeway in dirtying this bird up!!
Posted: Wednesday, August 19, 2015 - 06:11 PM UTC
Mike, nice choice with the Korean conflict F-51.
Posted: Wednesday, August 19, 2015 - 06:14 PM UTC
Matthew
http://aeroscale.kitmaker.net/modules.php?op=modload&name=Campaigns&file=index&req=showcontent&id=754
Well! the campaign page does not state bombs must be shown only that the a/c was used in that role.
ZAPanzer
North-West, South Africa
KitMaker: 88 posts
AeroScale: 39 posts
Posted: Thursday, August 20, 2015 - 02:23 PM UTC
Morning
My start pictures for the campaign. Was a choice between the F-15E and the F-14, decided on the F-14 with the Aires resin seats
RedDuster
Posted: Saturday, August 22, 2015 - 12:26 AM UTC
Small amount of progress.
Rockets painted.
Bombs on.
and fully armed.
Not far to go.
Cheers.
Si
TankSGT
AeroScale: 53 posts
Posted: Saturday, August 22, 2015 - 01:44 AM UTC
It's coming along quite nicely Si. F51 great choice. A Bombcat another good choice, goes nicely with a Mig 21.
I'm sorting through armament options. I was searching for pictures of Furys carrying bombs to get an idea of what kind of under wing rack they used. I have some from a Sabre and was wondering if the Navy would use USAF pylons.
Is it Advanced Modelers Syndrome that I'm even worried about it. I already filled the under wing holes for the B since mine is a straight F4J. I think I have a problem.
That I've even gone that far.
Any way ready to prime.
Tom
KitMaker: 696 posts
Posted: Saturday, August 22, 2015 - 10:13 PM UTC
Hi there,
some progress with my Hellenic Mirage 2000:
Starting with decals tomorrow I hope
Northern_Lad
KitMaker: 462 posts
Posted: Tuesday, August 25, 2015 - 12:29 PM UTC
Hello fellow campaigners,
I have a bit of progress to report on the Revell Mig 21 F. It’s a very nice kit with lovely panel lines and subtle rivets.
This is the instrument panel... There looks to be a nasty seem where the two fuselage halves join at the nose, but this is sanded so smooth with a lady's ultra fine cosmetic emery board.... I think it's something to do with the plastic, in some light it looks silver, in others it takes on a more metallic grey tone.
Seat and straps...
Where I’m at now (the instructions underneath are actually for the Airfix Mig 21, which I'm building at the same time)...
Matthew
HStamp97
KitMaker: 2 posts
Posted: Saturday, August 29, 2015 - 01:06 AM UTC
Hello all, little late to start but better late than never! I have recently gotten back into modelling and this is my first campaign. Anyway onto to the model. I have chosen the Republic P47N (Revell) for my build. I am going for a full load of 10 HVAR 10X27mm rockets and 2 500lb Bombs. I started this yesterday and here are some build photos below (sorry for the poorish quality).
Many thanks and I hope you enjoy!!!
https://drive.google.com/file/d/0B3nvkLBATPtKaUNWWGxuS21Md2c/view?usp=sharing
https://drive.google.com/file/d/0B3nvkLBATPtKcG8wXzBqQ1NmTzQ/view?usp=sharing
https://drive.google.com/file/d/0B3nvkLBATPtKZ29KRFZjTTlzdkE/view?usp=sharing
https://drive.google.com/file/d/0B3nvkLBATPtKS0pCVDhITmZkbms/view?usp=sharing
https://drive.google.com/file/d/0B3nvkLBATPtKZ091VkdmTlNIa28/view?usp=sharing
https://drive.google.com/file/d/0B3nvkLBATPtKVjNPeS1Od2Q5QnM/view?usp=sharing
