Armor/AFV: Techniques
Cutting fine plastic piece from sprue
SingaporeModeller
Singapore / 新加坡
KitMaker: 13 posts
Posted: Sunday, April 19, 2015 - 02:45 PM UTC
Wow... I didn't know that the precision spruce cutter is SO expensive...
I believe I use it to actually remove moustaches stubs off my face...
Biggles2
KitMaker: 7,600 posts
AeroScale: 121 posts
Posted: Saturday, April 18, 2015 - 08:05 PM UTC
Slice along the parting line a few times with shallow cuts with a fresh razor blade on both sides. If you use too much pressure trying to cut it off in one pass the piece will most likely break. The piece will eventually just drop off - hopefully onto the workbench.
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
AeroScale: 79 posts
Posted: Saturday, April 18, 2015 - 05:47 AM UTC
You can remove the sprue stub, using wire cutters. This will allow you more freedom, with more delicate tools to remove the part from the stub.
djohannsen
Virginia, United States
KitMaker: 364 posts
Posted: Saturday, April 18, 2015 - 05:14 AM UTC
I recently found something that works for me... I hit the sprue attachment point with Tamiya extra thin cement and give it just a bit of time to soften the plastic. I was able to get headlight guards and grab handles off the sprue without any damage.
Dave
mpeplinski
Michigan, United States
KitMaker: 487 posts
Posted: Saturday, April 18, 2015 - 04:50 AM UTC
Damon
Great review,first time I saw it,and everything you say is absolutely bang on.Like you,I also love the razor sw kit I bought with it.John sells a great assortment of tools .
didgeboy
KitMaker: 1,846 posts
Posted: Saturday, April 18, 2015 - 04:13 AM UTC
Pepinski has it right. That UMM fine parts remover is the real deal. Never had anything break with those, even fine resin detail items like .50cal links and M249 Barrels. Get one. Best $12 you'll ever spend. Check out the review here in case you are not already convinced:
http://www.armorama.com/modules.php?op=modload&name=Reviews&file=index&req=showcontent&id=8983
Gotrek58
KitMaker: 673 posts
Posted: Saturday, April 18, 2015 - 03:50 AM UTC
I have the same kit and the same problems. Too much attaching points from parts to sprues ( 8 points on the brake pedal part!). The next problem is to clean the parts. My carpet monster is very happy...
It's very hard to repair this little broken parts - next I will try the blue tac method!
justsendit
KitMaker: 3,033 posts
AeroScale: 60 posts
Posted: Saturday, April 18, 2015 - 03:33 AM UTC
... also acts to hold the piece and prevent it flying off into the wild blue yonder
So that's where those parts went!!!
mpeplinski
KitMaker: 487 posts
Posted: Saturday, April 18, 2015 - 03:29 AM UTC
This is my weapon of choice
r_e_lafleur
KitMaker: 3 posts
Posted: Saturday, April 18, 2015 - 03:27 AM UTC
Thanks to one and all for all your great suggestions
Ron Lafleur
pod3105
Waterford, Ireland
KitMaker: 466 posts
Posted: Saturday, April 18, 2015 - 03:15 AM UTC
Use a single edged razor blade and support the piece being cut on a block. I've been doing it this way now for quite some time and have had no mishaps yet. The blade is incredibly sharp, thin and stiff, you need very little pressure to get a clean cut. Its also great for removing "nodes" from Dragon parts and general purpose use. It cuts, slices, dices and juliennes!
Kimmo
I use a small wad of blu-tac behind the pices for support, works perfectly with just enough give and also acts to hold the piece and prevent it flying off into the wild blue yonder
varanusk
KitMaker: 1,288 posts
Posted: Saturday, April 18, 2015 - 03:14 AM UTC
I use the sharpest blade I have, which is a razor blade. Needs also a hard surface and having the part as fixed as possible
Thudius
Uusimaa, Finland
KitMaker: 1,194 posts
AeroScale: 19 posts
Posted: Saturday, April 18, 2015 - 02:35 AM UTC
Kimmo
SgtRam
Staff MemberEditor-at-Large
KitMaker: 3,971 posts
AeroScale: 511 posts
Posted: Saturday, April 18, 2015 - 02:33 AM UTC
Maybe the plastic has something to do with this .. The plastic seems too hard and shatters when you cut it ? And I just got that kit in mail .
When using a razor saw, let it do the work for you, do not press hard at all, just the lightest pressure and saw back and forth. I have used the same technique for the smallest and brittlest resin parts in the past too, and no issue.
edmund
KitMaker: 668 posts
Posted: Saturday, April 18, 2015 - 02:29 AM UTC
SgtRam
Posted: Saturday, April 18, 2015 - 02:00 AM UTC
I have the photo-etched razor saw from RB Models and I have no issue getting the smallest and finest parts off a sprue. Get the ultra-fine or fine, they work the best.
mother
KitMaker: 3,836 posts
AeroScale: 1,036 posts
Posted: Saturday, April 18, 2015 - 01:00 AM UTC
There were time that I had to heat up my hobby blade with a lighter followed by slicing through the sprue and part. Todays kits parts are getting harder to remove without damage.
Just save your dull blades for just such purpose.
Happy Modeling,
Joe
FarmerDave
KitMaker: 63 posts
Posted: Saturday, April 18, 2015 - 12:58 AM UTC
I use a fine toothed circular saw in a Dremel mini-drill for the finest parts on a sprue. A good quality set of side cutters is another good method.
CMOT
Staff MemberEditor-in-Chief
KitMaker: 10,954 posts
AeroScale: 290 posts
Posted: Saturday, April 18, 2015 - 12:53 AM UTC
When you say a fine saw are you referring to a razor saw, which is what I suggest trying.
r_e_lafleur
KitMaker: 3 posts
Posted: Saturday, April 18, 2015 - 12:43 AM UTC
Just purchased my Second Miniart U.S. Tractor D7. How does one cut those very fine pieces from the sprue. Those pieces from sprue C 1-2-3-4, I tried a knife, a fine saw. Yet each one shattered.
Any suggestions would be greatly appreciated, other than that the kit make a fine Tractor.
