Armor/AFV: Softskins
Softskins group discussions.
Building A Kraz Tank Transporter
OldWarloke
KitMaker: 2,662 posts
Posted: Wednesday, March 25, 2015 - 08:52 PM UTC
Repeat the previous steps with H26, H31, H28, & G8.
Above shows the assembly installed.
The instructions aren't verry clear on how the G8 parts go, this is how.
OldWarloke
Posted: Wednesday, March 25, 2015 - 08:27 PM UTC
Here is the start of the actual build.
First off the instructions aren't clear on a lot of the assembly steps, (how & exactly where the parts go)
This build is how I built it, you may choose a different way.
I mean I an not an expert, I just like to build these.
Starting.
Glue the 2 G18 & G19 parts together & fill the seams.Then Glue them to part F2 , filling & sanding the square openings on the back of F2. Then glue F2 to the lower trailer frame using the top frame to assure the correct position.
Glue the end of H27 to H30 as shown then glue H30 to H25 don't glue H27 to H25 yet. then glue G8 to H25 keeping the angled end pointed toward H30 .
You can glue F13 to F1 now or later.
There are 2 large Pushpin marks on F1 that should be sanded down.
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:26 PM UTC
Well that's the Sprue from this kit.
I'll have some Pics. when I get some of it built.
Donald
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:23 PM UTC
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:16 PM UTC
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:15 PM UTC
OldWarloke
Posted: Tuesday, March 24, 2015 - 10:08 PM UTC
I just finished the double Abrams build and decided on something different.
This will be mostly straight out of the box.
Here are the Sprue from the TAKOM kit #2019
Ukraine Tractor KRAZ 6446 with ChMZAP-5247G SEMITRAILER
