P-40/1S12 Project 1:35
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Sunday, February 01, 2015 - 03:35 PM UTC
bevore I'm too old - I intend to build a RC-Modell of the Radar-Station P-40/1S12/1RL128D "Long Track" in Scale 1/35 with RadioControll.
It is possible that I fail - It is here the right place to report about the progress of my project?
The basic of this model will be the Kit from PanzerShop with some additions from other Kits and some scratching.
In the times of the cold war I served a few years on this radar-station in the sam-4/sam-6 (Krug/Kub) system.
Greetings from Germany.
RobinNilsson
Staff MemberTOS Moderator
KitMaker: 6,687 posts
AeroScale: 21 posts
Posted: Sunday, February 01, 2015 - 04:16 PM UTC
That will be a challenge ;-) Getting the tracks to function reliably with RC will be a challenge. Friulmodel tracks might work for a time but I think they will break after some time. A working suspension will also be tricky ...
Please post reports on the progress with this ambitious project
/ Robin
juge75
Jasz-Nagkyun-Szolnok, Hungary
KitMaker: 843 posts
Posted: Sunday, February 01, 2015 - 06:50 PM UTC
http://s1183.photobucket.com/user/juge75/slideshow/1s12soc
thompyt
KitMaker: 106 posts
Posted: Sunday, February 01, 2015 - 10:34 PM UTC
Andreas,
Tu es doch!! I hab mit dem "Long Track" ins Alaska und Texas gearbeitet . Hier ist den richtigen platz das alles zu zeigen.
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Sunday, February 01, 2015 - 10:42 PM UTC
@juge75
Great! - I have seen your excellent model some times bevor I registered at this forum. Thanks for the slide-show-link!
Greetings
Andreas.
juge75
KitMaker: 843 posts
Posted: Sunday, February 01, 2015 - 11:10 PM UTC
Thank you !
Well , it's your own.
I had to add a couple of things : 1.5 set T -62 kit ( Trumpeter ) running on the wheel & pinion .
2 sets of Friul T-72 track .
Give me an e -mail address because the plans are still there , sent over there .
Mine Hungary , Keszthely seventh anti-aircraft missile regiment , 1S12 Soc . ( Krug anti-aircraft missile regiment was ever ... )
JimboHUN
Budapest, Hungary
KitMaker: 461 posts
Posted: Monday, February 02, 2015 - 03:12 PM UTC
Good luck! Although I would not bother with RC, you will have enough to do anyway
Some details hots:
http://mhrfweb.makett.org/MHRF/index.php?option=com_phocagallery&view=category&id=389%3Ap40zs2011res&Itemid=11&lang=en
Adam
Armored76
Bayern, Germany
KitMaker: 1,615 posts
AeroScale: 51 posts
Posted: Monday, February 02, 2015 - 03:21 PM UTC
That's a crazyly-good-looking vehicle! Pretty please let this happen!
Cristian
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Monday, February 02, 2015 - 11:12 PM UTC
@Juge75
I have allready two Kits of T-62 (Trumpeter), for RC a T-34 RC-Kit (Tamiya) ...
For the suspension I intent to use a suspension-kit from RBModel for the Abrams M1A1.
At this time I check the measurment (and some details) of the kits with my knowledge, pictures etc. F.e. the suspension-arms from the T-62 seems to me too short for a AT-T-chassis.
Greeetings,
Andreas.
Removed by original poster on 02/15/15 - 15:41:18 (GMT).
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Saturday, February 14, 2015 - 08:43 PM UTC
I started with little work - change a drive-part from tank T-62 (Trumpeter) to 426U (basis-vehicle of 1S12/1RL128D):
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Friday, February 20, 2015 - 02:16 AM UTC
I prepared some parts of the lower hull:
tnmn28g35
KitMaker: 13 posts
Posted: Friday, February 20, 2015 - 03:26 AM UTC
This site has some products and ideas for your RC conversion.
http://35rctank.com/html/diy_projects.html
Good luck to you.
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Monday, February 23, 2015 - 01:40 AM UTC
Here is the first phase of the assembled lower hull (yet rough) - assembled lower hull at foreground, original panzershop in the background:
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Wednesday, February 25, 2015 - 03:19 PM UTC
between some works I'm looking for the right color of the vehicle - I like the color of the late 70th from the soviet army. It was a uni-color between oliv-green and olive-brown ...
Exist somewhere a online-shop to buy this color for painting a model-vehicle?
Greetings,
bronja78
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Friday, March 06, 2015 - 02:39 PM UTC
I worked a while for the suspension-arms:
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Sunday, April 05, 2015 - 05:45 PM UTC
Hallo all,
the build of the lower hull failed and I start to build a new one:
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Sunday, April 26, 2015 - 01:35 AM UTC
... continue ...
I used the wheels from Trumpeter T-62
... colored and assembled with some axis with a 2x5x2.5mm ball-bearing
... mounted with the suspension from 'RB-Model' and placed in the lower hull
The lower hull is set on a board with a track-gauge-profile
Greetings,
Bronja
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Thursday, April 30, 2015 - 11:09 PM UTC
... as track-chain spanner I use an excenter on an worm-gear to spann with a four-side-socket-wrench on the upper backside of the lower hull as in the reality:
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Saturday, August 22, 2015 - 09:56 PM UTC
... now the upper-hull with motors:
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Saturday, September 19, 2015 - 09:41 PM UTC
Hello all,
now the first video - the 1st test of the tracks:
https://youtu.be/APKfWQau9lc
Jacques
Minnesota, United States
KitMaker: 4,630 posts
Posted: Monday, September 21, 2015 - 06:33 AM UTC
Nicely done. Or in more dramatic fashion: "It's ALIVE!"
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Saturday, October 03, 2015 - 09:10 PM UTC
... and now a little re-construction of the drive-wheels
and re-construction of the lower-hull-front
and than the 2nd test of the workable tracks of my 426u-vehicle:
https://youtu.be/f8EZRhEfYKQ
guni-kid
KitMaker: 521 posts
Posted: Sunday, October 04, 2015 - 12:03 PM UTC
Very nice! Even though it at times seems so, it never actually throws the tracks... great!
One thing I noticed though: the two last wheels on the right side don't really wanna roll...
Keep at it and show us the beast working
bronja78
Sachsen, Germany
KitMaker: 28 posts
Posted: Saturday, March 12, 2016 - 08:24 PM UTC
... no, I don't stoped - I only breaked.
Now I have made the hood-front. The original part of the hoddd-front from panzershop has a too oversimplyfied hood-grill and I removed it and maked a new one (the subpart of the hood-front that I maked is to push and remove it from the lower-part of the vehicle):
Than I maked a hod-front-panel to place at front of the hood:
I assembled the hood-front and the hood-front-grill
and for a better photo I pushed it on the base:
Greetings - I hope the next came soon ...
