Cold War (1950-1974)
Hosted by Tim Hatton
F-80C Shooting Star
CMOT
Staff MemberEditor-in-Chief
KitMaker: 10,954 posts
AeroScale: 290 posts
Posted: Monday, October 27, 2014 - 07:39 AM UTC
Brian O''Donoghue takes a look at the Hobby Boss F-80C Shooting Star by Hobby Boss.
Posted: Tuesday, October 28, 2014 - 03:51 AM UTC
Brian,
Thank you for a well written and detailed review. I've been thinking about purchasing and building the F-80C, as the era is a personal favorite of mine.
One thing that does concern me, is the once again split fuselage halves, so that the engine can displayed. 9 out of 10 times this leads to a alignment issue for those of use that will not be showing the engine. I guess that I'll tackle this issue by gluing the fore and aft sections together on a glass plate.
brian638
KitMaker: 318 posts
Posted: Thursday, October 30, 2014 - 08:49 AM UTC
Hi Joel,
Thank you for your kind words, generally I'm an armour guy so I found this to a pleasant change to review this kit. I hadn't considered the alignment issue but I will look at this when I build it. If the fuselage sections will fit without using the engine then conceivably the modeller could cut the end of the jet pipe off and simply omit the engine.
I also think that this kit is very suitable for the novice.
Regards
Brian
Posted: Thursday, October 30, 2014 - 09:41 AM UTC
If it's anything like the old Monogram kit, the engine will be a necessary part to stabilise the fuselage sections and keep everything alligned. Of course if you glue the front and rear sections together before assembly that problem goes away.
Posted: Friday, October 31, 2014 - 03:13 AM UTC
Jessica,
That would be my plan of attack. I would rather have to deal with the usual centerline seam issues (if there is any), then have to deal with a cross section issue.
