OFFICIAL: Big Bad Bombers Campaign
ljames0874
KitMaker: 408 posts
AeroScale: 365 posts
Posted: Saturday, August 09, 2014 - 10:30 PM UTC
So, the underside is sprayed white, the topside is medium sea grey, and I've just finished masking the camouflage pattern. This has to be the smallest scale pattern I have ever masked. The blu tack snakes are tiny!
Cheers Everybody!
Posted: Monday, August 11, 2014 - 05:38 AM UTC
Hello, Here is my contribution to the Big Bad Bombers campaign. I tend to like Italian AC and I have had this kit for quite a long time and just never got around to building it. I have also just started to try my hand at some home-made photo etch and will use some on this AC.(I know there is already PE sets for it, But I am cheap and like to try a bunch of different things ) I did by the decals though to use on the multiple Italian AC kits I have.
North4003
KitMaker: 960 posts
AeroScale: 391 posts
Posted: Monday, August 11, 2014 - 10:42 AM UTC
Hello, my entry for the Big Bad Bombers Campaign is a Tamiya 1/100 IL28 Beagle. I've had this one on the shelf for a while and the Beagle, though understated possesses a certain Cold War cool factor. The Beagle was long lived and it was used by several air forces and though never used in the role it could go "loud" if the mission required.
North4003
KitMaker: 960 posts
Posted: Monday, August 11, 2014 - 11:36 AM UTC
I could hardly keep my hands off this hound and I glued a good part of it together during our thunder storms. I'm still debating what air force to do; presently the Air Force of the USSR is the leading contender.
Dragon164
#226
KitMaker: 1,909 posts
AeroScale: 508 posts
Posted: Saturday, August 16, 2014 - 06:11 PM UTC
Here is the kit I am doing and what I am trying on the raised panel lines.
Cheers Rob.
ljames0874
KitMaker: 408 posts
Posted: Sunday, August 17, 2014 - 03:47 AM UTC
...and I'm done! This was a quick but fun little project - masking camouflage in this scale was a challenge, but I'm quite happy with the result. Here she is:
Comments welcome as always - cheers everyone!
Berwickboy
KitMaker: 450 posts
AeroScale: 387 posts
Posted: Sunday, August 17, 2014 - 07:54 AM UTC
Nice job on the Vulcan
Berwickboy
KitMaker: 450 posts
Posted: Tuesday, August 19, 2014 - 09:43 AM UTC
I have actually managed to put on the first primer coat, Humbrol Matt White primer from a rattle can. It has shown up a few blemishes but considering the fit of parts that is expected.
not brilliant but I only had my ancient mobile handy
Posted: Wednesday, August 20, 2014 - 02:07 PM UTC
Here are some of the first pics of my build.
I have added framing to the inside of fuselage and inside the wheel wells. The interior is started with some home made PE and styrene parts.
The PE is modeled after some Eduard and CRC 1/72 & 1/48 and specifically scaled to this 1/72 AC.
Rimfireroscoe
KitMaker: 51 posts
AeroScale: 11 posts
Posted: Saturday, August 23, 2014 - 01:30 AM UTC
Hi All, here is my submission - sorry for late start.
as you can see its the Airfix blenny - not sure about there new styrene though seems a but soft and grannie with the man texture. but this is aircraft is the only resion I would ever think of getting one of there kits.
Berwickboy
KitMaker: 450 posts
Posted: Saturday, August 23, 2014 - 09:22 AM UTC
For reference purposes there is a build going on elsewhere in these forums. There are a few errors with the Airfix Blenheim, the most obvious being the projections in the lower front of the engines which only come later in the series. It appears in the Word war II section. It looks a great kit and I have one in my stash.
Me? I am at the painting stage with the Vulcan, a couple of rattle can coats already, one more should be sufficient before a coat of gloss, decalling, semi-gloss coat and weathering before mounting on a suitable base.
KitMaker: 3,959 posts
AeroScale: 598 posts
Posted: Saturday, August 23, 2014 - 11:49 PM UTC
Hi Chris! hopefully this kit changes your opinion of the new tool kits from Airfix
ltb073
KitMaker: 3,662 posts
AeroScale: 174 posts
Posted: Sunday, August 24, 2014 - 04:49 AM UTC
Thought I was going to be able to get a start on my kit so I took this start up picture 2 weeks ago but thats about as far as I got
Dragon164
#226
Posted: Sunday, August 24, 2014 - 10:06 PM UTC
Slowly making some progress on the B-24, I like how the Eduard instrument panel looks the same can not be said of how it fits. that will take some work. I have trimmed down one of the control columns they are quite thick.
Cheers Rob.
nico37
Indre-et-Loire, France
KitMaker: 651 posts
AeroScale: 181 posts
Posted: Monday, August 25, 2014 - 07:19 PM UTC
there are good jobs around here and some pretty oldies and well done Lee James for your one !
Here are my progress with some scratch builds of the interior :
And after Tamiya Primer (sorry for the first photo low quality)
nico
Berwickboy
KitMaker: 450 posts
Posted: Tuesday, August 26, 2014 - 11:17 AM UTC
Progress with ye Vulcan
Once again taken with my ancient Nokia
Next step, gloss varnishing, and building a display base
Posted: Tuesday, August 26, 2014 - 11:54 AM UTC
Alright I finished up the main area of the cockpit and most of the interior. (You ever wonder why we work on interiors just to button it all up and see maybe 1/10th of what you have done?)
Anyway.
Here is Cockpit section and the Drop gunner space. The gun is not complete for that. If I put sites and stuff on it I'll just break before needed anyway.
Berwickboy
KitMaker: 450 posts
Posted: Friday, August 29, 2014 - 11:52 AM UTC
Reminder to self, chunky fingers do not help with 1/200 scale models.
Every kit I build I feel is an exploration into better techniques, with the Vulcan i am trying a new (to me) method. I wanted to enhance the panel lines but not use a dark wash so, as the overall aircraft is White then I used a 2H pencil in the panel lines which thankfully are well defined.
To my eye this looks a bit on the heavy side but I shall persevere. It's never over till it's over
PeeJay74
#363
KitMaker: 425 posts
AeroScale: 401 posts
Posted: Sunday, August 31, 2014 - 07:52 AM UTC
1/48 Accurate Miniatures PBJ-1D conversion, VMB-611
I finished all of the painting / weathering for both sides of the fuselage and all of the interior sub-assemblies. I need to trim and fit the vac canopies next so I can button her up.
I spent extra time on the front offices which should be visible through the thin vac canopy.
ljames0874
KitMaker: 408 posts
Posted: Monday, September 01, 2014 - 06:53 PM UTC
Mike - the pencil panel lines look great, especially on that all white anti-flash scheme.
Here's a little something for ya (and all the other bomber fans!). I have just got back after an excellent weekend at the Shoreham Air Show. Bombers were well represented, a B-25, B-17, and the BBMF (naturally). Unfortunately, the Canadian Lanc didn't make it down as it was stuck at Durham Tees Airport, having an engine swap, but this gorgeous lady more than made up for that disapointment:
Cheers Everyone!
Posted: Wednesday, September 03, 2014 - 08:54 AM UTC
Good thing Angelo from SPECTRE was flying this day
It may have ended up in the Bahamas................
KitMaker: 4,950 posts
AeroScale: 3,192 posts
Posted: Wednesday, September 03, 2014 - 09:43 AM UTC
Great work folks! You've intimidated me, I may just leave the B-1A in the box till next time.
Nicolas, tell us more. I assume the yellowish circles are disks that you used to fill ejector pins. Are the ribs and stringers just plain old styrene strips? How did you align them so well? What sort of wires dis you use for the 'plumbing'?
shorty53
#330
KitMaker: 175 posts
Posted: Saturday, September 06, 2014 - 02:22 PM UTC
I have just about completed the cockpit of the Ju 88. Fuselage halves are together with tail plane glued on. Wings have just been test fitted to fuselage, fit looks good. The only thing I’ve found so far that might need a bit of work is the engine to wing fit.
nico37
KitMaker: 651 posts
Posted: Tuesday, September 09, 2014 - 02:56 AM UTC
Mark: Sorry for the lack of information.
You're right, the yellowish circles fill the ejector pins, i used Mr Hobby putty (white/light grey but i guess the photo light makes it looks like yellow...)
For the ribs and stringers i sliced thin rods from 0.5mm styren sheets and i made marks with pencil on the plane sides before to glue them, not a really difficult task, just a long long one...
And for the plumbings, i just used wires from an old electrical cable (the one with several thin copper wires in it) and fusible (or fuse ? not sure of the english word).
For the scratched panels on the right side i used styren sheets (i forgot if it was 0.5 or 1 mm wide) and a little bit of food aluminium for parts of the maps/documents wallet.
Hope i was clear enough
nico
Berwickboy
KitMaker: 450 posts
Posted: Sunday, September 14, 2014 - 09:17 AM UTC
I have just spent a frustrating couple of hours applying decals (in my youth we called them transfers). Being a 1/200 scale model they ain't exactly suitable for my clunky fingers but, I did it.
You may be able to see that something is missing, the serials, bit of a disaster there, they were on my bench and got wet due to some careless action by me and consequently one of them folded in on itself and try as I might I couldn't rectify the situation. Ah well, all experience.
Next stage is the final varnish coat and a suitable base.
