I'm trying to start my own little business with the machine (making masters and patterns). But while the paperwork is floating around I figured I'd try and make something cool.
I picked FT turret since it's not an entire vehicle (not as overwhelming); it's mainly flat pieces of metal bolted together (easier to make); and I like WWI equipment (even if it's in WWII).
I found some blueprints and drew up some plans in SketchUp. They aren't finished, just the gun/mantlet, the back hinges, and some connecting pieces need to be done.
And my first successful cut into aluminum! Wasted two endmills and some aluminum stock before I finally got to this.
It's the left side turret panel seen here,
I also made a master of the top part of the turret (still need to do the bottom part since it will be a two part mold). I'm planning on casting it in white metal to go with the overall aluminum construction. Ruler shown alongside to give you an idea of the size.
Not even an hour ago I was trying to mill out another panel when the stock slipped. Ended up destroying another endmill, good thing I order them in two's.
Ideally I'd like to make a part a day, but who knows what other snags I'll hit. But I'll try to keep you guys posted.
