Dioramas
FEATURE
Forest floor step by step
Mario_HR
Croatia Hrvatska
KitMaker: 376 posts
AeroScale: 21 posts
Posted: Tuesday, August 20, 2013 - 10:29 PM UTC
Jan Willem bring us a simple and very effective way to creating perfect forest floors, just what you need to create your diorama in no-time!
1stjaeger
Wien, Austria
KitMaker: 1,744 posts
Posted: Wednesday, August 21, 2013 - 01:43 AM UTC
Yes! Absolutely superb...and so easy!!
Just one tiny bit of info:
dry leaves can be collected from birch catkins (or "aments") in autumn. Just pluck them, roll them between your fingers and they crumple into nice single leaves (and a great number of tiny bugs to make your wives happy ).
Apart from a little bit of work, they are of course free of charge!
Romain
easyco69
KitMaker: 2,275 posts
Posted: Wednesday, August 21, 2013 - 02:15 AM UTC
awesome!!
Tailor
KitMaker: 1,168 posts
AeroScale: 199 posts
Posted: Wednesday, August 21, 2013 - 06:44 AM UTC
Excellent! I really need to practise groundwork...
Blackstoat
KitMaker: 567 posts
Posted: Wednesday, August 21, 2013 - 07:27 AM UTC
Top job
Could you show us how you made the trees?
KitMaker: 7,745 posts
AeroScale: 3,164 posts
Posted: Wednesday, August 21, 2013 - 04:54 PM UTC
Jan-Willem,
Superb! You just inspired me to return to an ongoing diorama! Your work is great!
Dangeroo
#023
Zurich, Switzerland
KitMaker: 2,058 posts
AeroScale: 67 posts
Posted: Wednesday, August 21, 2013 - 06:28 PM UTC
Thank you for a great How-to!
Cheers!
Stefan
janwillem
Groningen, Netherlands
KitMaker: 1,236 posts
AeroScale: 43 posts
Posted: Thursday, August 22, 2013 - 05:08 AM UTC
Thank you guys
@JPTRR
A greater compliment you couldn't have given me.
JW
Removed by original poster on 08/22/13 - 17:09:33 (GMT).
Trisaw
KitMaker: 4,105 posts
AeroScale: 27 posts
Posted: Thursday, August 22, 2013 - 10:08 AM UTC
Great article with nice photos!
Question: When spraying with diluted white glue, how do you prevent the scene from not looking all wet, soppy, and damp? The thing with wetting dry groundwork is that the colors change and the water may turn all dryness into mush. This is a problem I've experienced when spraying diluted white glue to hold all the leaves onto the grass.
The flipside is NOT spraying white glue runs the risk of the leaves blowing away with the slightest breeze because no glue holds them down.
Thanks for the feedback.
GregCloseCombat
KitMaker: 2,408 posts
Posted: Thursday, August 22, 2013 - 06:15 PM UTC
This is very helpful and awesome. I too wonder how did you do the trees?
janwillem
AeroScale: 43 posts
Posted: Thursday, August 22, 2013 - 08:05 PM UTC
@ GregCloseCombat and Blackstoat
The tree are just the classic Seafoam trees with just an application of a special putty for the bark. The leaves are parsley and the tops given a bit more green colour by airbrushing them with some bright green. Nothing really special but I'll see if I can whip up a small how-to.
@ Trisaw
I make a mix of 1 part white glue to 4 parts water. The key is to use a spray bottle that creates a mist and not a stream (I use a hair product spray bottle I confiscated from my wife). Just a misting between each layer should be enough to hold the scatter material down you should never apply so much that you start to see large droplets form or puddles collect. If that does happen you can remove some of the excess with a piece of tissue paper. If at the end of forming your forest floor you find you still have some lose material you can always apply some additional glue mix to those areas.
marcjac
KitMaker: 32 posts
Posted: Sunday, August 25, 2013 - 11:05 PM UTC
Hi Jan, well done! It looks very realistic. Hope you wil write a small how-to for building the tree's. I'am interessted in it.
janwillem
AeroScale: 43 posts
Posted: Thursday, August 29, 2013 - 10:00 PM UTC
He Guys,
As soon as I find the time to do it I'll do one on making the trees.
Belg1960
KitMaker: 41 posts
Posted: Saturday, November 15, 2014 - 05:30 AM UTC
Jan, is the powder ,plaster of paris or a sheetrock spackle?
janwillem
AeroScale: 43 posts
Posted: Saturday, November 15, 2014 - 11:30 PM UTC
He Belg1960,
It is more like sheetrock spackle (it is soled here in the Netherlands as large hole filler). it has a grainy texture that it keeps after drying.
JW
AlanL
KitMaker: 14,499 posts
Posted: Sunday, November 16, 2014 - 01:02 AM UTC
Nice work Jan,
Al
pushka
KitMaker: 13 posts
Posted: Thursday, June 08, 2017 - 03:25 AM UTC
I use E-Z water in my dioramas. I think if you seal the ends of riverbeds or whatever with DAP kitchen and bath sealer, let it dry, then pour your E-Z water it will solve the curling problem you encounter using plastic card. once the E-Z water hardens, simply strip the DAP borders off your diorama!
