OFFICIAL: Douglas Parade of Propeller Power
Posted: Sunday, August 11, 2013 - 05:52 AM UTC
Hi Jessica.
I have contacted Mike at Vintage Flyer Decals and he can send me a set of window decals for $5 + postage so I will order two sets.
Now for some filler for the openings!.
Posted: Sunday, August 11, 2013 - 12:20 PM UTC
If you haven't glued the fuselage together yet, either Milliput or Superglue applied from the inside works best.
Posted: Sunday, August 11, 2013 - 12:34 PM UTC
Good idea.
Thanks
mrockhill
KitMaker: 566 posts
AeroScale: 507 posts
Posted: Wednesday, August 14, 2013 - 10:41 AM UTC
Being as I was going to be build an SBD-3 anyway, I decided to join this very appropriate and timely campaign. I was really psyched to do a Coral Sea or Midway plane. Unfortunately that was delayed a few days when upon inspecting my accurate minatures kit I discovered that what I had was an SBD-1 kit with -3 box, instructions and decals. So ive checked around and made sure I have everything figured out and now I will be building an SBD-1. Probably in USMC prewar scheme featuring the yellow wings and aluminum lacquered everything else. I like color but this is taking a step out of my comfort zone. The idea has grown on me over the last couple days. Ill be ordering decals in the next day or so but in the mean time let the festivities begin...with some parts washing
Posted: Wednesday, August 14, 2013 - 11:10 AM UTC
Hi Mike
Looking forward to your build.
Posted: Wednesday, August 14, 2013 - 11:30 AM UTC
Mike, Looking forward to following your SBD build, as I'm currently building a detailed 1/48 scale SBD-3/4 by Hasegawa.
Posted: Wednesday, August 14, 2013 - 11:36 AM UTC
Hi.
My next entry into this campaign:-
This has been in my stash for a long time (mold date 1992).
Decal have gone missing so I will order new ones from Vintage Flyer Decals( thank you Jessica for Mikes link).
cinzano
KitMaker: 419 posts
AeroScale: 378 posts
Posted: Sunday, August 18, 2013 - 01:29 AM UTC
Just got a little envelope from Australia. Want to try something new with this build, so I ordered Montex masks. I've never used their product before but I would like to paint insignias on rather than resort to decals. We'll see how it goes. The results I've seen from others are stunning so I'm hopeful.
Fred
Posted: Sunday, August 18, 2013 - 03:21 AM UTC
Hi Fred.
I my self am looking to change more to masks, more position control and not having to deal with poor decal film.
Fred
Posted: Sunday, August 18, 2013 - 04:15 AM UTC
Fredrick, Looking forward to see how they come out.
I was thinking of using the masks from my GWH Devastator for this campaign on my Dauntless, since the insignia's for blue circles and stars are the same dia.
mykroft
KitMaker: 270 posts
AeroScale: 264 posts
Posted: Sunday, August 18, 2013 - 06:06 AM UTC
Well I'm in with the RoG/MPM Boston V
Revell of Germany Douglas Boston V 1/72 by mawz_models, on Flickr
Posted: Saturday, August 24, 2013 - 03:05 PM UTC
After giving the DC-1 a good sanding down, I'm trying something new. Vallejo's silver. I think that I still need airbrushing practise, because it's gone a bit orange peel. That's still better than how it looked last week.
The DC-2 fared a bit worse
There's a nasty drip under the right wing which needs cleaning ip.
I think that if I polish these with very fine sandpaper and apply some Rub 'n Buff they might just begin to look good.
Posted: Saturday, August 24, 2013 - 03:25 PM UTC
Silver paint takes several days to really cure. The DC-1 you should be able to produce a very acceptable NMF using a polishing set. Grits: 4,000, 6,000, 8,000, & 12,000 applied wet. The DC-2 really has a lot of Orange peel. Certainly won't be an easy fix. You might consider striping it once again, then priming with Tamiya gray primer. Once dry, use the polishing set, then a coat of Alcad black primer. Then Alcad 11 Aluminum as your base color. Once dry, buff out.
Take a look at Peter's 1/32 scale Tamiya's Big Beautiful Doll P51-D, it was done that way.
Posted: Sunday, August 25, 2013 - 01:30 PM UTC
Adventures with Rub 'n Buff
Posted: Sunday, August 25, 2013 - 05:44 PM UTC
And now some decals
Posted: Sunday, August 25, 2013 - 07:27 PM UTC
Decals for the DC-2
RedwingNev
KitMaker: 911 posts
AeroScale: 415 posts
Posted: Sunday, August 25, 2013 - 09:15 PM UTC
Really interesting scheme jessie - but just how many campaigns are you building for atm? Every campaign thread I open has a model from you in it! I am in awe of your productivity!.
Posted: Monday, August 26, 2013 - 04:09 AM UTC
Jessica, Nice save on both aircraft. On the DC-2, the left wing there is a discoloration by the outer yellow bands that show in both pictures. Is that in the paint, or just something created in the digital photography process?
Decaling came out really nice on both aircraft. Looking forward to your next update.
Posted: Monday, August 26, 2013 - 05:04 AM UTC
I think it's a combination of some surface roughness that didn't completely polish out, silvering (the decals were still wet when I took those pictures) and reflection from the flash. I've very carefully put some fresh Rub 'n Buff on and we'll see whether that improves the look.
Posted: Monday, August 26, 2013 - 05:55 AM UTC
They both look fabulous
Posted: Tuesday, August 27, 2013 - 05:57 PM UTC
The DC-1 would be done by now if my brilliant idea to use punched circles of painted trim film to do the wheel hubs had worked the way it was supposed to. As it stands, I need to redo them, probably with paint.
DC-2 to follow...
Posted: Tuesday, August 27, 2013 - 10:31 PM UTC
Nice work Jessica.
I wish I had a $ for every bright idea i had that did not work out as planed!
Did you paint decal film for the wheel hubs?
Still the plane looks good.
Posted: Wednesday, August 28, 2013 - 01:39 AM UTC
Yes. I thought that since the hubs are circular a little disk of painted decal would work nicely. I ran into trouble because the film I used likes to roll itself up under the influence of setting solutions. Perhaps I'll try the boiling water trick instead.
Posted: Wednesday, August 28, 2013 - 05:58 AM UTC
Okay, that's done with. Here's the DC-1 and DC-2 nose to nose. I'll get some better pictures later this afternoon once I have a new sheet of faithful blue background paper.
Posted: Wednesday, August 28, 2013 - 11:58 AM UTC
The better pictures as promised. First, the DC-1 in the colours of TWA as it was on delivery.
Then the DC-2 wearing PANAGRA scheme
