Time to build the track runs.
Son of Sherman says 79 a side, so I will start there. These act like "dead" track, no bushings to cause a curl, so I will use enough,and idler positioning, to remove excessive top run "sag".
These are the steps I use to assemble them. I triple checked, to make sure the track blocks were oriented correctly. The gripper pins on the blocks MIGHT survive having to be unassembeled a few times, but, the less stress the better.
First, gather the correct parts together,remembering, the extended end connector goes to the outside.
Then I click on the eec to the first set of pins:
Then add the block,connecting this side first:
Then add the opposite connector, gently aligning it by "feel" and push in evenly.
I had a few leftovers,as you know, there is an issue with short shots.I can make a mold from the extras, so that I will have enough for the spare track holders.
