Mack NO6 - 7 1/2 ton artillery tractor
Posted: Sunday, January 25, 2015 - 06:50 PM UTC
Beautiful inside cover photo on David Doyle's/Ampersand's new book on military Mack's:
Posted: Saturday, January 24, 2015 - 10:00 PM UTC
Mack NO on display at the Overloon / Marshal Museum, the Netherlands.
_____________________________________________________________________________________________
Very informative video on the Overloon Museum at: (They have EVERYTHING!)
https://www.youtube.com/watch?v=czc9g5g2qdw
Posted: Wednesday, January 21, 2015 - 03:15 AM UTC
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
AeroScale: 79 posts
Posted: Tuesday, January 20, 2015 - 01:28 PM UTC
I have this problem, using a pin vise, as well.
Posted: Tuesday, January 20, 2015 - 09:36 AM UTC
No matter how slow you run your small electric drill you will never feel the drill start to tear the material in time to stop before the piece is ruined.
Hand drilling is the only way.
If your problem has been the drill bit walking around on you and not starting the hole where you went it to be: Try taking a new sharp ex-acto knife with a very pointed #11 blade, put the tip exactly where you want the center of the hole in the plastic and slowly spin the knife one rotation. That will make a small dent/starting depression to keep your drill bit in place.
retiredyank
AeroScale: 79 posts
Posted: Tuesday, January 20, 2015 - 07:20 AM UTC
It must be how sharp the bits are and the application they are intended for.
Posted: Tuesday, January 20, 2015 - 06:48 AM UTC
Hand powered pin drill vice - no electrics here.
I usually keep two drills on my bench, one each with drill bits that match the two most common sizes of small plastic rod that I am using on a particular build.
If necessary I will drill a guide hole with the smaller drill bit and then go back with the larger one. Sometimes with even larger bits I will hold them with my fingers and do the drilling.
Note: I keep a bag of dog worn bits to do general work around the house. Only using my best and sharpest bits for my model work.
retiredyank
AeroScale: 79 posts
Posted: Tuesday, January 20, 2015 - 05:44 AM UTC
Just found this one. Amazing work! Extremely well done! When building the front bumper and winch assembly
How did you keep the drill from deforming the thin edge of the brace? I have tried using a pin vice and slow speed drill. Both tore the plastic out.
Posted: Tuesday, January 20, 2015 - 05:31 AM UTC
A beautifully restored Mack as captured by Hermen Goud in 2012
Photo by Rene Boot
Posted: Tuesday, January 20, 2015 - 05:19 AM UTC
My favorite photo of the Mack towing the big guns:
Posted: Monday, January 19, 2015 - 10:01 AM UTC
Found recently on the internet:
Note civilian tires on the gun and military pattern on the limber!
Posted: Sunday, January 18, 2015 - 09:03 PM UTC
Yes, I know this looks like I am totally bragging BUT, actually my motivation is to relaunch this subject and to state again that this is a kit that the hobby manufactures really need to be offering in plastic. With so many interesting small and medium prime movers being offered of late, I just do not understand why the Mack NO continues to be overlooked.
With the 155mm and 8 inch guns having been on the market FOR YEARS there really is a need (If I may use that expression) for something other than a High Speed Tractor to pull them . . . . neither the new 4 ton Mack from Mirror nor the similarly sized White truck from HobbyBoss are up to the task of pulling these big guns.
OK back to the bragging:
In the scratch built & conversions category -
In the 2010-2011 competition season the Mack NO captured a gold metal at the AMPS competition in Auburn:
+ First Place, Best Armor AND Best of Show in Indianapolis:
+ First Place and Best Armor at Cincinnati:
+ First Place in Louisville:
Posted: Wednesday, June 11, 2014 - 07:44 AM UTC
Chris (Tiger 213)
I would love to see the M19; 12 ton sitting next to my Mack NO; 7 1/2 ton on the display shelf at home.
One day soon perhaps. Working right now on the Diamond T Wrecker model. (Based on the 4 ton Diamond T chassis) and also doing a serious conversion of the MAZ 537G into the F/A variant.
Regards
Mike K.
Posted: Friday, May 30, 2014 - 12:32 AM UTC
Coming in June from Ampersand Publishing:
"The Big Macks"
http://www.dragonmodelsusa.com/dmlusa/prodd.asp?pid=AMPVHTBM
Tiger_213
KitMaker: 1,510 posts
AeroScale: 20 posts
Posted: Friday, January 10, 2014 - 08:49 AM UTC
It looks great.
Just yesterdayI saw that Turmpeter (I think) is coming out with a M19 and trailer this year.
Merit (somehow connected to Trumpeter) already has one available. It was just released. You can see it here.
Maybe that's what I was thinking of? I was looking at Trumpteter's and Merit's 2014 catalogs and that's where I remember seeing it.
HeavyArty
KitMaker: 17,694 posts
AeroScale: 1,728 posts
Posted: Friday, January 10, 2014 - 08:23 AM UTC
It looks great.
Tiger_213
AeroScale: 20 posts
Posted: Friday, January 10, 2014 - 08:18 AM UTC
It looks great.
Posted: Friday, January 10, 2014 - 07:29 AM UTC
Now I like the looks of this one. I truly do!
Well now that I have my Mack everything else is available in plastic. I might have to build this lash up in the not too distant future!
__________________________________________________________________________________________________
While I was definitely inspired by the above photo, in the end I went a slightly different way. I modified the HobbyBoss White/Corbit 666 into a semi-tractor. Picked up a resin 20 ton flatbed trailer from Scale-Link and used the Cat D7 from Mirror Models to form the load.
This lashup took "Best Armor" at the 2016 Louisville IPMS competition.
Posted: Sunday, January 05, 2014 - 06:09 AM UTC
Cannot help but think the Mack NO will be coming in the not too distant future given all the Diamond T's and Corbit 666's being offered.
Tiger_213
AeroScale: 20 posts
Posted: Saturday, January 04, 2014 - 02:02 PM UTC
Ah I didn't realize that was yours, Michael. I usually just skim larger articles. I am enjoying all your reserch photos and build all the same.
Posted: Saturday, January 04, 2014 - 01:35 PM UTC
Chris check out page 1, photo 1 of this thread for a picture of the finished model, Thank you for your comments.
Tiger_213
AeroScale: 20 posts
Posted: Saturday, January 04, 2014 - 12:39 PM UTC
Love your model
Really love how the Mack towing the Tom shows no sag in the suspension.
When are we going to see a decent kit of this subject?!?
Probably when another start-up platic company hits the scene. Or HobbyBoss and or Mirror Models gets to it, they seem most likely.
Michael, fantastic work. Looking forward to seeing your finished build.
corsair924
New Hampshire, United States
KitMaker: 403 posts
Posted: Saturday, January 04, 2014 - 12:00 PM UTC
Love your model
Posted: Saturday, January 04, 2014 - 11:19 AM UTC
Here is a reposting of a much better version of a wartime photo of the Mack that was shown earlier:
Posted: Saturday, January 04, 2014 - 11:17 AM UTC
Another beauty shot of the Mack NO prototype: Note Classic Mack "C" cab and top mounted winch with twin windlass drums.
The above image comes from the collection of EASY 1 Productions - From the disc entitled "TM 10-1679; 7 1/2 ton 6x6 Prime Mover Mack NO"
Follow them on Facebook at:
https://www.facebook.com/Easy1CD/
