Early Aviation
EOW Nivelles 1918
JackFlash
KitMaker: 11,669 posts
AeroScale: 11,011 posts
Posted: Saturday, August 11, 2012 - 09:14 AM UTC
Detailing kits with spare parts is one of the methods that sets one build apart from another.
The PE frets are left overs from DML / Dragon, Eduard and a fret of German detais from Tom's Modelworks. Off to the left one of my parts bins contains 2 Part of Poland sets for the 1:48 Fokker D.VII.
Wheels are DML / Dragon, Jager and resin copies of both.
Propellers are from Roden & Eduard kits.
When you begin to mix different manufacturers kits with each other in a diorama they need to look similar. Built strickly out of the box its easy to tell the differences between Roden, Jager, DML / Dragon & Eduard molds. The individual build reviews here at Aeroscale give you most of that information. But its the side by side comparisons that give you the best choices for displays. For instance the DML / Dragon fuselage is too short ih profile height and .040 thou needs to be added from the rear of the lower wing cut out to the rear king post. Also the rudder needs to be enlarged in height by .040 thou and about .030 thou in width. Roden's engine exhaust louvres are not as pronounced as any of the others but dimensionally the fuselage is good. Eduard, Jager louvres are highly pronounced and the fuselages are good.
JackFlash
Posted: Saturday, August 11, 2012 - 01:11 PM UTC
Now to start showing the builds I have chosen for this diorama. Note as I have mentioned earlier I will use aircraft from the units that surrendered at Nivelles but in some cases we don't know if a specifically marked machine was there or had been previously captured and was sent there.
Even with recent studies of Jasta Boelcke machines, the identity of this machine's pilot is shrouded in mystery. All we have is an image where this machine or one like it was photographed after having nosed over in a landing or a stalled take off.
Kit review here.
JackFlash
Posted: Saturday, August 11, 2012 - 01:15 PM UTC
In June 1918, Jasta 43 had a mixture of Fokker D.VII and Albatros D.V & D.va types. In an attempt to consolidate the equipment into one type, when Jasta 18 moved from the 6th to the 19th Armee area, their older Fokker D.VII (Alb.) types were supplied to Jasta 46. These aircraft bear the original Jasta 18 markings, including the raven on the fuselage. This aircraft depicted as being from the D. 528 - 926/18 production batch was flown by Leutnant der Reserve (Ltn des Res.) Josef Keller. He joined Jasta 43 on 5 June, 1918. His only victory came on 8 August 1918 when he brought down an SE5a near Bray-sur-Somme. His combat career ended on October 11, 1918, he was seriously wounded when he crashed during test flight a Jasta 43 Fokker D.VII.
The stripes for the Jasta 43 machine of Ltn Keller are a bit thin in the clear area between the red stripes and care should be exercised when applying these two sections ( for the left and right side.) Always use warm water and keep the decal on the paper backing until ready to slide it off into place on the model. Carefully spread the decal out to the right location. Do one side at a time and using set first then sol and you will have very good results.
Feature here.
JackFlash
Posted: Saturday, August 11, 2012 - 01:20 PM UTC
While flying Fokker D.VII types, Jasta 46 was commanded by Ltn Otto Creutzmann (8 victories) as a part of Jagdgruppe 2. The pilot of this aircraft is unknown but it was photographed in British hands post war. The lower wing crosses should be further out by one half of a rib space. There is evidence that The unit may have had red or black forward fuselages. The top wing is in 5 colour lozenge while the bottom wing is in four colour. When you work with models like this and you follow the directions without some other references you can get in trouble. Eduard recommends the early fuselage for the following scheme. But here is what you need to know about the problems you will face. Remember folks you saw it here first. Eduard implied in their artwork, but they did not include it in their instructions. To do this scheme / profile as photo-evidence provides:
A. Instead of using the early production fuselage you could use the late production and cut off select louvres and add the photoetch metal louvres to match the profile. ( Also don't forget That even though Eduard shows the capped exhaust port - in the known images you can not see this. A new side panel may have been fabricated in the field) or...
B. If you use the early production fuselage you have to cap off the the side exhaust exit and carve out the rim on the upper cowling to allow for the high exit exhaust . Then add the Eduard photoetch louvres.
Anthology 2 has some very interesting images of this bird in British captivity (with 84 RAF 1918 -1919.) The altered side panels are a strong indication that this early Albatros built Fokker D.VII had not only both of the side and one upper panel altered BUT had its exhaust changed out from the "early side exit " type to the "later high exit" type. There is not enough evidence to prove that the engine was changed out and exhausts were a fairly common item. The engine we do see present is a Mercedes 180hp D.IIIaü type.
Feature here.
JackFlash
Posted: Saturday, August 11, 2012 - 01:24 PM UTC
This build represents The Early series Schwerin built Fokker D.VII flown by Hauptmann sur zee Gottard Sachsenberg Cmdr of Marine Feld Jasta I. From the ex-Aeromaster series of decals titled " Those incredible Fokkers Pt.II 48-612." The kit is Roden's kit #415. This will be my second build using this same kit and decals.
JackFlash
Posted: Saturday, August 11, 2012 - 01:27 PM UTC
Another Marine Feld Jasta (Jasta III) Fokker D.VII 4499/18 flown by Vzflgmstr. Mayer who left on 6 Sept. 1918 to SeeFosta II. The personal & unit markings decals are from the ex-Eagle Strike series. The kit is an Eduard first issue of their OAW kit. the original machine probably stayed with the MFJ and was assigned to another pilot at the EOW.
Feature here.
JackFlash
Posted: Saturday, August 11, 2012 - 01:35 PM UTC
This kit represents a late production Fokker D.VII (OAW) flown by an unknown pilot of Jasta 36. It is well documented that this unit used variations of light and medium blue as a unit marking. This pilot has added a white and medium blue banding around the empennage. The photo image of this machine was probably taken while Jasta 36 was in the field during the war but I include it as it may have been turned in at Nivelles. From the Fokker D.VII Anthology volume 2. The lozenge decals are the excellent the 4 colour version from the Microsculpt discussed here on Aeroscale on a modified DML / Dragon kit.
Kit Review here.
JackFlash
Posted: Saturday, August 11, 2012 - 01:38 PM UTC
I am taking the artisitic license to include aircraft that belonged to the surrendering German units. But no photo image exists of this machine at Nivelles in the public domain. There maybe some written knowlege by the specific pilot that he had a machine but little or nothing is noted about its markings or type designation. As an example I provide the following;
"This kit represents a Fokker D.VII from a late Albatros production batch in the markings of an earlier machine flown by Ltn. Des Res. Raesch of Jasta 43. His earlier machine was destroyed in combat on 25 July 1918. He parachuted to safety and was eventually given another machine. I duplicated the markings from his early Albatros production bird as it was a common practice for a German pilot that lost a machine to reproduce the same markings on his new aircraft to one extent or another.
It is generally known that Jasta 43 received its initial Fokker D.VII aircraft in a transfer from Jasta 18. Ltn. Raesch inherited this machine ( D.525/18 - 874/18/18 Johannistahl built) from the unit’s temporary commander Ltn.d.R. Otto Creutzmann on about 5 June 1918. The three pronged pitchfork is easily recognizable as a manure fork used in cattle and dairy farms. Both Ltn.d.R. Otto Creutzmann and. Raesch had grown up on farms so it is easy to see why it was retained.
Ltn. Raesch crashed the early machine on 25 July 1918. The markings of his late model Fokker D.VII (Alb.) are unknown at this writing. Since many pilots re-applied their old marking to newly assigned machines, I have represented it here. Ltn.d.R. Josef Raesch came from Jastaschule I at Valenciennes on 6 June1918 and served until the end of war. At that time Ltn. Raesch followed his unit to Nivelles to surrender their aircraft." The lozenge decals are the excellent the 5 colour version from the Microsculpt discussed here at Aeroscale on the DML /Dragon kit.
Kit Review here.
JackFlash
Posted: Saturday, August 11, 2012 - 01:50 PM UTC
The following is from the "When I flew with. . ." GB and the biography I created for this pilot represented there.
". . .It all began in a small town of Zweibrüken in the Pfalz Rhineland area. Coming from a family that operated a small Gesthaus and restaurant called Weinerwald. Hunting in the nearby black forest or the local Phesanery was his favorite leisure time activity. Oblt. Stefan Löwenson rose from the ranks and served inseveral Front line units. It was on 13 Sept.1918 that he was again transferred but to 2 Armee headqurters for the Gruppen Fluzeug Command. Where he acquired a roving commission as field inpector of Jasta materials and operations in and around Metz. It is believed that in his authority that he appropriated one of two aircraft destined to be assigned to the JG.I commander.
In the 147th Aero Sqdn log book for Sept 26,1918. There were 4 men on patrol at approx. 6:30pm. Brotherton and Brosnon at 1500m and Jones and Porter at 600m. It was the latter two that saw the formation above them at 1000m (approx.) The same comments are copied in the daily text. "In a flight of Fokkers . . .Leader was all-white with what looked like red crosses?. . ."
He further increased his victory total to 23 by traveling in his white Fokker D.VIIF and assigning himself to the different Jastas in that theater of operations during his inspection tours. It was his reports on Jasta 64w that noted the loss of many new Fokker D.VII aircraft due to the failure of substandard bungee shock chord during normal landings during Sept. - Oct. 1918.
Blog here.
JackFlash
Posted: Saturday, August 11, 2012 - 02:10 PM UTC
Now for some allied aircraft that will be in the diorama. (We will get back to the German machines later.)
lcarroll
KitMaker: 1,032 posts
AeroScale: 1,025 posts
Posted: Saturday, August 11, 2012 - 02:17 PM UTC
Stephen,
Incredible undertaking; and you've only begun! This should be a beautiful display....are you donating it to some cause (can't imagine how you'd lay it out at home)or organisation?
Really like the fascinating background you are adding to each airframe. Good luck with this impressive project and I'll be watching.
Lance
JackFlash
Posted: Saturday, August 11, 2012 - 02:18 PM UTC
". . .Here is a Part of Poland set with some Roden parts. Will be doing more to put in a diorama. Remember the propellers from the thread "One good turn deserves. . ." The laminations go to opposing sides because one is a left hand and one is a right hand. . ."
This will be one of several aircraft that will be an a "stripdown mode".
JackFlash
Posted: Saturday, August 11, 2012 - 04:36 PM UTC
Stephen, Incredible undertaking; and you've only begun! This should be a beautiful display....are you donating it to some cause (can't imagine how you'd lay it out at home)or organisation? Really like the fascinating background you are adding to each airframe. Good luck with this impressive project and I'll be watching.
Lance
Thank you Lance! Yes it and the other diorama will go to a non-profit museum when finished. I want to make this one a walk around display. The clear cover is going to break my wallet. I may have to win the lottery. . . Oh well. If I can finish it in time I'll put it up at the 2013 IPMS Nats. I am kind of glad I chose the British turn in depot. I just came into the possession of "a few" images from the American turn in depot. Gadzooks and Hot Marimba! I would have to live 80 more years.
JackFlash
Posted: Saturday, August 11, 2012 - 07:28 PM UTC
Jasta 7 & 29 are on the work bench getting rigging and props.
Also I will include my Fok. D.VII 247/18 build for another Jasta 30 machine.
J.30 build located here.
ludwig113
KitMaker: 1,381 posts
AeroScale: 1,110 posts
Posted: Monday, August 13, 2012 - 05:37 AM UTC
Thank you both for the kind words. Paul, I suspect the chalk inscriptions did not last long. After the aircraft landed and were sorted to one area or another. When they were noted it was probably reported to the NCO in-charge of ground operations and an officer might have been involved, but all ground crews were ordered to remove the offending marks. A simple swipe with a rag and they were gone. But! There are a couple of examples that survived. One from Jasta 3. I'll see if I have an image I can scan. I think it is in Anthology 3. It is a newer Alb. built machine and has "Baucher Jasta 3" in the pilot's left side of the fuselage below and slightly behind the cockpit.
thanks for that stephen, i got a copy of Anthology 3 as it was the only one i didn't have.
cheers paul
lcarroll
Posted: Monday, August 13, 2012 - 02:08 PM UTC
Lance
Would that we could........that is live another 80!
In the real world it's a wonderful thing you are doing; a fine gesture that will go a long way to preserving our early aviation heritage with new generations. On a selfish note I'm thoroughly enjoying both your big Threads and the great info on some, to me, previously unknown schemes.
Lance
Buckeye198
Ohio, United States
KitMaker: 596 posts
AeroScale: 197 posts
Posted: Tuesday, August 14, 2012 - 07:42 AM UTC
Simply incredible...can't wait until this is finished!
JackFlash
Posted: Wednesday, August 15, 2012 - 04:40 AM UTC
Thanks for all the encouragement!
Using some spare fuselages will also allow me to to use markings in a smaller area. Like those dismantled aiframes shown in the original images. When Jager went out of business owner Justin Young offered bits and pieces and decals for discounted prices.
JackFlash
Posted: Wednesday, August 15, 2012 - 05:16 AM UTC
Justin also donated some damaged resin fuselages to the cause.
JackFlash
Posted: Friday, August 17, 2012 - 12:35 AM UTC
Here is the highly modified DML / Dragon 1:48 Fokker D.VII in the markings of D.365/18 flown by Ltn. Josef Jacobs Cmdr of Jasta 7. He was actually in Berlin at the 3rd type testing competition and his machines (1 @ Dr.I & D.VII) were flown to Nivelles by other Jasta 7 pilots. The personal markings are from the old Eagle Strike sheet on a highly modified DML / Dragon kit.
I have portrayed it with a BMW motor, Heine propeller with a Rupp quick release prop hub.
Kit Review here.
JackFlash
Posted: Friday, August 17, 2012 - 12:39 AM UTC
Jasta 7 line up about mid June 1918.
JackFlash
Posted: Saturday, August 18, 2012 - 02:23 PM UTC
Here is my version of Jacobs last Dr.I Triplane. Dr.I 470/17 was usually his reserve machine until Dr.I 450/17 was crashed on Oct. 3, 1918. In my opinion he applied the "gonw" to this machine as well as it shows up in descriptions of his last combat reports post Oct 3, 1918.
Originally built for the "Camel vs Fokker Dr.I" GB Campaign in 2009 -10.
"Alterations to the DML Dragon kit were;
1. Replacing the kit engine with a slightly modified Eduard 1:48 Sopwith Camel Clerget and propeller.
2. Replacing the kit harness straps with Eduard prepainted lap belts.
3. Replacing the kit seat with a Roden Sopwith Strutter kit item. (its closer to the Fokker original.)
4. Replacing the kit National markings with modified Eagle Strike 1:48 Fokker D.VII items.
5. Cutting down the horizontal stabilizer & elevators for a to closer match original aircraft.
Since this is a very late war representation and during some of the most desperate times. I applied a paint normally used for RC coverage. It actually attackes the kit plastic to bond. The surface is rougher than normal to note the aircraft is in a state that it needs recovering.
Fokker Dr.I 470/17 was first used by Ltn. Jacobs on July 19, 1918. It became his reserve machine until Oct 3, 1918 when his main aircraft was destroyed while trying to force land. His combat reports note that he then applied the "gonw" motif to 470/17 and he continued to score until he was called away to the third fighter trials in Berlin. Its ultimate fate during the last days of the war are unrecorded. It could have been destroyed or turned in with the rest of the Jasta 7 aircraft after Nov. 11, 1918."
Reference;
Cross & Cockade Intl.
Vol.25 #2 1994 “Jasta 7 under Kobes Pt.I”
Vol.25 #3 1994 “Jasta 7 under Kobes Pt.II”
Vol.29 #2 1998 “Sketches and Descriptions-Kobes”
JackFlash
Posted: Wednesday, August 22, 2012 - 08:39 PM UTC
Fokker D.VII 387/18 from the top.
Here is a bit of fun on the subject right here at Aeroscale.
Just for the sake of having them in one place. For more reading on the various license built Fokker D.VII represented in 1:48 kit form.
Click here I Eduard Royal Feature
Click here II Eduard OAW Feature
Click here III Eduard Schwerin Dual Combo review
Click here IV Roden Schwerin kit #415 Feature
Click here V Eduard Schwerin Weekend kit blog
Click here VI Eduard 2nd OAW issue Review
Click here VII Eduard MAG Dual Combo Review
Click here VIII Eduard Johannistahl Review
Click here IX DML / Dragon Kit Review
Click here X Hasegawa Kit Review
Click here XI Jager Kit Review
Click here XII Roden Early Schwerin kit Review
Click here XIII Eduard OAW 1st Issue Review
Click here XIV Eduard mid OAW Limited Edition
1:28 scale kit
Click here XV Revell Kit Review.
1:32 scale kit
Click here XVIWNW Schwerin 32011
Click here XVII WNW Alb. 32027
Click here XVIII WNW OAW 32030
Here is a walkaround of a restored Fokker D.VII (Alb.) 8417/18
I think that is all available Reviews & Features at this time. More later no doubt!
ludwig113
Posted: Thursday, August 23, 2012 - 01:55 AM UTC
great stuff stephen, i especially like the Josef Jacobs machines.
paul
JackFlash
Posted: Sunday, August 26, 2012 - 04:34 PM UTC
Thanks Paul! Always good to hear from you.
Now then, here are some of my options for colour schemes as related to the units represented at Nivelles.
I. Armee Gruppe Rupprecht. Collection airfield. Nivelles. - kits used -
4 Armee.
Gruja Nr.3.
Jasta 14 SSW D.III (Old Eduard kit?)
Jasta 16b Fok. D.VII early Schwerin (white/black/white) bands around tail unit.
Jasta 29 Fok. D.VII (AM48-183)early Schwerin DML Ltn. Auffarth.
Jasta 56. Fok. D.VII early Alb. Jager
Gruja Nr.6.
Jasta 7 Fok. Dr.I 470/17 Jacobs DML / Dragon
Jasta 7 Fok. D.VII early Schwerin, Jacobs DML Eagle Strike decals.
Jasta 20 Brown fuselage w/ white tail unit? (Relation to J.30?)
Jasta 40s (PD 48-016 or Roden #421) Fok. D.VII late OAW. leaping stag Roden?
Jasta 51. Tail unit half grn half blk Kit?
Marine Feld Jagdgeschwader,
MFJ I, (AM48-612) Sachsenberg Early Schwerin (3 vent) Roden. MFJ II
MFJ III Fok. D.VII 4499/18 (AM48-611)(Mid Prod OAW) Eduard.
MFJ III Fok. E.V 144/18(DML kit decals #5909.)DML
MFJ IV
MFJ V.
6 Armee.
Gruja Nr.7.
Jasta 28 Fok. D.VII kit?
Jasta 30 Fok. D.VII early Alb. (ES48042 & Roden 421)Roden
Jasta 30 Fok. D.VII 247/18 (Hybrid kit)
Jasta 33 Fok. D.VII late OAW # 5 DML (ES48042)(loz.)
Jasta 43 Fok. D.VII early Alb. Eduard (Royal kit #20001)
Jasta 43 Fok. D.VII (Superscale 48-479, AM48-183) Eduard or Roden kit 421)
Jasta 52 Fok. D.VII Black fuselage w/ white wheels & radiator shell Eduard or Roden kit
Jasta 63 Fok. D.VII Black & white fuselage band, late model Alb. Eduard or Roden kit
17 Armee.
Jagdgeschwader Nr.3.
Jasta 2 Banding on fuselage like war ribbon tail planes half white half black.
Jasta 26 (Roden) Black & white fuselage & tail banding. DML (3 vent)
Jasta 27 Fok. D.VII(Monogram)decals # 5203 Roden kit #415
Jasta 36 Fok. D.VII(OAW)DML
Jasta 36 Fok. D.VII(OAW)Eduard
Jasta 36 Pfalz D. XII Blue Max wrecked
J.35b ?) DML or Blue Max
Gruja Nr.4
Jasta 1 Fok. D.VII Grn triangle on fin and grn and white angled stripes on horizontal tail plane and maybe a wrap around ribbon on the fuselage. Eduard Johannistahl 601/18
Jasta 57 Fok. D.VII early OAW lt blue similar to J.56 but with yellow details.
Jasta 58 Fok. D.VII(AM48-612) Eduard 8131(OAW) Mid Production
Jasta 59 Fok. D.VII late Schwerin late type black cat Roden
