Cut panels out.
book1182
KitMaker: 11 posts
AeroScale: 10 posts
Posted: Friday, May 11, 2012 - 04:49 AM UTC
Hello,
Am building a 1/48th Corsair. Looking to cut some of the wing panels out and putting gun bays in them. I built the gun bays but have never modified a model this much. Any tips or things to watch for while I'm cutting?
Thanks,
Posted: Friday, May 11, 2012 - 05:02 AM UTC
It's best to cut inside the panel lines, then sand and trim to the line to avoid cutting out too much. Drill a series of holes around the inside perimeter of the panel you want to remove, then using a sharp exacto knife cut through to join all the holes. This leaves a ragged bit of plastic around the outside to clean up. Replace the removed panel with plastic card. Take your time to avoid mistakes.
book1182
KitMaker: 11 posts
AeroScale: 10 posts
Posted: Friday, May 11, 2012 - 05:55 AM UTC
Thanks.
