Today I can show you my final completed build for 2019. It's the new Bristol Blenheim Mk. IF from Airfix in 1/48 ....
... the prototype of the Bristol Blenheim made its first flight on the 12. April 1935 as Type 142 with the name "Britain First". Later that year a first contract of 150 aircraft was placed and in March 1937 No. 114 Sqn was the first squadron of the RAF to receive the now called Blenheim Mk. I. Its speed was comparable to the speed of most biplane fighters of that time but when war broke out, the fighter development of other countries has left the Blenheim vulnerable with its speed and defensive weapons of only one 7,7 mm machine gun in a dorsal turret and a further fixed 7,7 mm machine gun in the left wing. The Blenheim was exported to many Air Forces around the globe, the most well known user during war time is probably the Finnish Air Force, where the Blenheim was also produced in licence. The Mk. IF was used as a heavy fighter and night fighter with four 7,7 mm Browning guns in a belly pack. Of 1552 built Mk. I about 200 were converted into the Mk. IF. The Blenheim had a crew of 3 and a maximum weight of 6532 kg. It was powered by two 9 cylinder air cooled Bristol Mercury radial piston engines with 920 hp each which gave the aircraft a top speed of 428 km/h at 3600 meters. It had a maximum range of 2350 km and a service ceiling of 8310 meters. There has only one Blenheim survived in airworthy conditions which was restored out of a canadian made Bolingbroke. The sole surviving original Blenheim is a Mk. IV, registered as BL-200 of the Finnish Air Force and can be seen at the Finnish Air Force Museum in Tikkakoski near Jyväskylä in Finland. And it is beautifully restored, believe me ....
.... I have built Q-YP, a machine of No. 23 Sqn, based at RAF Wittering, England, in February 1940 ....
.... Airfix came out with this long awaited kit in 2018 and it didn't stay long in my stash. The 216 parts go mostly well together, there's no need to use putty or even sanding at the transition of wings to fuselage because braces from the fuselage hold everything perfect in place. The only negative point I have to mention is the fitting of the canopy parts to the fuselage. There are only 4 parts for the whole canopy. I think more parts would do a better job here. At first I thought it was my fault, that it doesn't fit, but a friend of mine had the same problems. So it's the manufacturer's fault ....
Finally I got it together with patience, force and a bit of swearing. I hope Airfix will fix that issue in the future because we want more versions of the Blenheim! For painting I have used Revell No. 8 Black for the underside, Vallejo 71323 Dark Earth and 71324 Dark Green for the upper side. The interior was painted with Revell 45 Grey-Green and the wheel wells were painted with Revell 99 Aluminium. For the cowling rings I have used again Vallejo 71068 Copper, the same colour as on the PZL 37. I have used EX626 from Eduard for masking the canopy. It's highly recommended on this green house. The decals are taken from the kit sheet and they are very good and lay perfectly into the panel lines. There are only very few stencils on the decal sheet. Airfix offers another version, the Mk IF as an all-black nightfighter. But I think this camo looks more interesting ....
I thank you for walking around the latest member of my Plastic Air Force and I hope you've enjoyed it. This kit is a fun to build with the exception of the canopy. With a length of 26 cm and a width of 36 cm it's no small model. I would like to see a Mk. IV in 1/48 in the near future because I want to build a Suomen Ilmavoimat Blenheim. Decals are already here ....
Finally I wish you all a merry christmas and a happy new year 2020. Stay well!
Happy modelling!
