Hosted by Todd Michalak
Fletcher Class 1/144 WIP
RedDuster
KitMaker: 6,856 posts
Posted: Friday, May 26, 2017 - 01:50 PM UTC
What Stephen said!
The weathering is stunning,
Fantastic job Daniel.
Si
StephenLarsen
#474
KitMaker: 67 posts
Posted: Friday, May 26, 2017 - 12:02 AM UTC
Hi Daniel,
Beautifully done! Love the weathering.
Biggles2
KitMaker: 7,342 posts
Posted: Wednesday, June 29, 2016 - 04:25 AM UTC
Hi Daniel. I will be eventually starting my Fletcher with the same Big Ed PE set. The Eduard forecastle railings are not curved to match the sheerline of the ship. How did you resolve this issue? Is the sheer gentle enough so that you could force the railings into position without bending or kinking them? This was a very foolish error on Eduard's part not to make this railing section curved.
THEGREEK
Attica, Greece / Ελλάδα
KitMaker: 1 posts
Posted: Saturday, February 27, 2016 - 03:53 AM UTC
GREAT GREAT JOB!!!! however the davits are not hollowed...I am building the USS THE SULLIVANS in 1/350 from Trumpeter and I am doing a good ref research. The Greek navy had several vessels of the type. One is a museam at Falliron bay. The "VELOS"(is the greek word for ARROW) D16.The best thing of all is the trully amazing riple effect you have achieved!!!! How on earth you did it???
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Tuesday, November 19, 2013 - 10:46 AM UTC
Jejeje Well my version is a bit sweet !!! .... jajajjaja I it did with sugar
1- color base.
2 to moisten and to put sugar.
3 to paint the second color ... and
4 to wash below of the water faucet!!
enjoy friends !!
youngtiger1
KitMaker: 534 posts
AeroScale: 47 posts
Posted: Tuesday, November 19, 2013 - 07:11 AM UTC
It looks like Salt weathering process, but I could be wrong.
BillGorm
KitMaker: 609 posts
AeroScale: 13 posts
Posted: Tuesday, November 19, 2013 - 01:54 AM UTC
Can you describe how you achieved the chipped effects on the side of the hull and beneath the waterline? Did you paint the chips or use some other technique like a sponge, chipping fluid, hairspray, etc.?
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Monday, November 18, 2013 - 06:27 AM UTC
Amazing model Daniel. Those awards are well deserved!
I hate to nitpick, but I assume you're representing a dry-docked ship? The streaking runs vertical below the waterline, which I don't think would be correct.
But who am I to question the master!
Hello friend Samuel!! It makes me happy that it is of your pleasure....
Not!!! Not master of nothing!! Jejej I would like it but I lack a lot of work!!
Well I not lerm to represent water!!
So my models go all in entire hull in the open air ...i like too ...
some day I will throw myself to the water
Best regards Daniel
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Monday, November 18, 2013 - 06:17 AM UTC
Thank you friend Mike!! Already I had forgotten the enterteining thing that was this project Fletcher. yes, the effect " tin of oil " is in the whole hull. I did it with a curved leaf of razor knife. Luck with your Destroyer
regards Daniel
Thank you Daniel. I am sure it was fun..a lot of work but fun indeed. One more question if you don't mind..do you remember
what was the size of the square of the tin of oil effect? TIA
Jejeje Thank you my friend. Really I do not remember the measure, calculate a relation on a royal photo and the identical numeral .... this is aprox 0,9 cm x 1,8 cm of high ..... but it is not the same measure in the whole hull!!! And on having scratched with the scalpel this measure it goes away to.....
Regards Daniel ......And remember that I want to see your advances!!!
sweaver
KitMaker: 759 posts
AeroScale: 184 posts
Posted: Monday, November 18, 2013 - 04:29 AM UTC
youngtiger1
KitMaker: 534 posts
AeroScale: 47 posts
Posted: Saturday, November 16, 2013 - 09:46 AM UTC
regards Daniel
Thank you Daniel. I am sure it was fun..a lot of work but fun indeed. One more question if you don't mind..do you remember what was the size of the square of the tin of oil effect? TIA
Fordboy
Auckland, New Zealand
KitMaker: 2,169 posts
Posted: Sunday, November 03, 2013 - 11:36 AM UTC
Thanks Daniel.
Yes the images for Julians build arent there anymore shmae.
Sean
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Sunday, November 03, 2013 - 10:06 AM UTC
Since it is a custom my friend Sean ... I invite the beers!! Jajaja Here this Julians Fletcher .
http://modelshipwrights.kitmaker.net/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=170538&ord=&page=1
MMMMMM the images are not for that Julian change site of storage!!!.
Be alone I use Eduards's Big Ed
http://www.eduard.com/store/Eduard/Big-Ed/FLETCHER-1942-1-144.html?cur=2
Thanks Daniel
Fordboy
Posted: Sunday, November 03, 2013 - 09:31 AM UTC
Hi Daniel
Located Julians build I think.
Daniel what was your opinion on the Eduard PE set?
Which set was it the Big Ed set?
What other after market sets did you use?
Sean
Fordboy
Posted: Sunday, November 03, 2013 - 09:17 AM UTC
Holy smoke Daniel very nice build indeed. Inspirational in fact.
Well done.
I also need to find Julians build. I assume its somewhere on the forum?
Sean
Gremlin56
KitMaker: 3,897 posts
AeroScale: 564 posts
Posted: Saturday, November 02, 2013 - 08:11 AM UTC
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Saturday, November 02, 2013 - 08:01 AM UTC
The oil canning and the hull weathering still knock me out. A brilliant build that I am still very jealous of
Jajja thank you Julian .... but my Fletcher Class does not even shade to his Fletcher!!
Regards Daniel
We both ran into the same problem with the Fletcher: If you use Eduards PE depth charge racks you end up with empty racks unless you scratch a lot of DC's. I didn't
And I chickend out of doing the oil canning, you didn't
That is why I consider your build better, along with the best hull weathering I have seen in a long time
Uuufff coming from the teacher Julian!! It is an honor for my!!!
I will have to uncover a "Tanat" to feast!!!!
Daniel
Gremlin56
Posted: Saturday, November 02, 2013 - 06:14 AM UTC
Regards Daniel
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Saturday, November 02, 2013 - 06:07 AM UTC
Hi Daniel,
Just come across your Fletcher build.
AWESOME !!
Kev
Thank you friend Kev. A pretty Kit and a Big Ed very interesting . makes me happy be of your pleasure.
Regards Daniel
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Saturday, November 02, 2013 - 05:08 AM UTC
Regards Daniel
Longshanks8
KitMaker: 430 posts
AeroScale: 18 posts
Posted: Friday, November 01, 2013 - 05:21 AM UTC
Hi Daniel,
AWESOME !!
Kev
Gremlin56
Posted: Friday, November 01, 2013 - 04:33 AM UTC
DanielMoscatelli
Montevideo, Uruguay
KitMaker: 998 posts
AeroScale: 20 posts
Posted: Friday, November 01, 2013 - 03:17 AM UTC
regards Daniel
youngtiger1
KitMaker: 534 posts
AeroScale: 47 posts
Posted: Thursday, October 31, 2013 - 05:39 PM UTC
I'm late to the party, but I'm glad all you photos are still up. Daniel, your Fletcher Class Destroyer is totally awesome. I like the wavy/ripple body effect on the bottom part is totally awesome. Was that applied to the full body? TIA
35th-scale
Kildare, Ireland
KitMaker: 3,212 posts
Posted: Friday, December 30, 2011 - 03:57 AM UTC
Fantastic build and well deserved awards.
